stm32F103、GD32F103读写Nor Flash实战指南
一、NOR Flash基础与硬件连接1. NOR Flash简介
NOR Flash是一种非易失性存储器,支持随机访问和XIP(Execute In Place)特性,常用于存储固件代码、特定数据。典型型号如GD25Q128(128Mbit容量,SPI接口),其擦写寿命约10万次,适合嵌入式系统扩展存储。
2. GD32F103硬件设计
以SPI接口的GD25Q系列为例:
引脚连接:
二、SPI外设配置与驱动开发
1. SPI初始化代码
void SPI_FLASH_Init(void)
u32 temp;
SPI_InitTypeDefSPI_InitStructure;
/* Enable SPI1 and GPIO clocks */
/*!< SPI_FLASH_SPI_CS_GPIO, SPI_FLASH_SPI_MOSI_GPIO,
SPI_FLASH_SPI_MISO_GPIO, SPI_FLASH_SPI_DETECT_GPIO
and SPI_FLASH_SPI_SCK_GPIO Periph clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOD, ENABLE);
/*!< SPI_FLASH_SPI Periph clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
/*!< Configure SPI_FLASH_SPI pins: SCK */
GPIO_InitStructure.GPIO_Pin = GPIO_FONT_SPI_SCK;
GPIO_InitStructure.GPIO_Mode = GPIO_FONT_SPI_SCK_FLAG;
GPIO_Init(GPIO_FONT_SPI, &GPIO_InitStructure);
/*!< Configure SPI_FLASH_SPI pins: MISO */
GPIO_InitStructure.GPIO_Pin = GPIO_FONT_SPI_MISO;
/*!< Configure SPI_FLASH_SPI pins: MOSI */
GPIO_InitStructure.GPIO_Pin = GPIO_FONT_SPI_MOSI;
/*!< Configure SPI_FLASH_SPI_CS_PIN pin: SPI_FLASH Card CS pin */
GPIO_InitStructure.GPIO_Pin = GPIO_FONT_SPI_NSS;
GPIO_InitStructure.GPIO_Mode = GPIO_FONT_SPI_NSS_FLAG;
/* Deselect the FLASH: Chip Select high */
SPI_FLASH_CS_HIGH();
/* SPI1 configuration */
// W25X16: data input on the DIO pin is sampled on the rising edge of the CLK.
// Data on the DO and DIO pins are clocked out on the falling edge of CLK.
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI2, &SPI_InitStructure);
/* Enable SPI1*/
SPI_Cmd(SPI2, ENABLE);
//temp = SPI_FLASH_ReadID();
根据temp = SPI_FLASH_ReadID()返回的值,可以判断Nor Flash的一些信息,比如型号、容量大小等。
2. NOR Flash控制函数
发送一个字节数据或命令
u8 SPI_FLASH_SendByte(u8 byte)
/* Loop while DR register in not emplty */
while (SPI_I2S_GetFlagStatus(FONT_SPI, SPI_I2S_FLAG_TXE) == RESET);
/* Send byte through the SPI1 peripheral */
SPI_I2S_SendData(FONT_SPI, byte);
/* Wait to receive a byte */
while (SPI_I2S_GetFlagStatus(FONT_SPI, SPI_I2S_FLAG_RXNE) == RESET);
/* Return the byte read from the SPI bus */
return SPI_I2S_ReceiveData(FONT_SPI);
发送半字数据
u16 SPI_FLASH_SendHalfWord(u16 HalfWord)
/* Send Half Word through the SPI1 peripheral */
SPI_I2S_SendData(FONT_SPI, HalfWord);
/* Wait to receive a Half Word */
/* Return the Half Word read from the SPI bus */
读取一个字节
u8 SPI_FLASH_ReadByte(void)
return (SPI_FLASH_SendByte(Dummy_Byte));
三、关键操作实现
1. 数据读取(Read Data)
void SPI_FLASH_BufferRead(u8* pBuffer, u32 ReadAddr, u16 NumByteToRead)
/* Select the FLASH: Chip Select low */
SPI_FLASH_CS_LOW();
/* Send "Read from Memory " instruction */
SPI_FLASH_SendByte(W25X_ReadData);
/* Send ReadAddr high nibble address byte to read from */
SPI_FLASH_SendByte((ReadAddr & 0xFF0000) >> 16);
/* Send ReadAddr medium nibble address byte to read from */
SPI_FLASH_SendByte((ReadAddr& 0xFF00) >> 8);
/* Send ReadAddr low nibble address byte to read from */
SPI_FLASH_SendByte(ReadAddr & 0xFF);
while (NumByteToRead--) /* while there is data to be read */
/* Read a byte from the FLASH */
*pBuffer = SPI_FLASH_SendByte(Dummy_Byte);
/* Point to the next location where the byte read will be saved */
pBuffer++;
2. 扇区擦除(Sector Erase)
void SPI_FLASH_SectorErase(u32 SectorAddr)
/* Send write enable instruction */
SPI_FLASH_WriteEnable();
SPI_FLASH_WaitForWriteEnd();
/* Sector Erase */
SPI_FLASH_CS_LOW();
/* Send Sector Erase instruction */
SPI_FLASH_SendByte(W25X_SectorErase);
/* Send SectorAddr high nibble address byte */
SPI_FLASH_SendByte((SectorAddr & 0xFF0000) >> 16);
/* Send SectorAddr medium nibble address byte */
SPI_FLASH_SendByte((SectorAddr & 0xFF00) >> 8);
/* Send SectorAddr low nibble address byte */
SPI_FLASH_SendByte(SectorAddr & 0xFF);
/* Wait the end of Flash writing */
3. 写数据
void SPI_FLASH_BufferWrite(u8* pBuffer, u32 WriteAddr, u16 NumByteToWrite)
u8 NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0, temp = 0;
Addr = WriteAddr % SPI_FLASH_PageSize;
count = SPI_FLASH_PageSize - Addr;
NumOfPage =NumByteToWrite / SPI_FLASH_PageSize;
NumOfSingle = NumByteToWrite % SPI_FLASH_PageSize;
if (Addr == 0) /* WriteAddr is SPI_FLASH_PageSize aligned*/
if (NumOfPage == 0) /* NumByteToWrite < SPI_FLASH_PageSize */
SPI_FLASH_PageWrite(pBuffer, WriteAddr, NumByteToWrite);
else /* NumByteToWrite > SPI_FLASH_PageSize */
while (NumOfPage--)
SPI_FLASH_PageWrite(pBuffer, WriteAddr, SPI_FLASH_PageSize);
WriteAddr +=SPI_FLASH_PageSize;
pBuffer += SPI_FLASH_PageSize;
SPI_FLASH_PageWrite(pBuffer, WriteAddr, NumOfSingle);
else /* WriteAddr is not SPI_FLASH_PageSize aligned*/
if (NumOfSingle > count) /* (NumByteToWrite + WriteAddr) > SPI_FLASH_PageSize */
temp = NumOfSingle - count;
SPI_FLASH_PageWrite(pBuffer, WriteAddr, count);
WriteAddr +=count;
pBuffer += count;
SPI_FLASH_PageWrite(pBuffer, WriteAddr, temp);
else
NumByteToWrite -= count;
WriteAddr +=count;
pBuffer += count;
while (NumOfPage--)
if (NumOfSingle != 0)
四、完整代码
* ÎļþÃû£ºspi_flash.c
* ÃèÊö £ºspi µ×²ãÓ¦Óú¯Êý¿â
* ʵÑéÆ½Ì¨£ºÒ°»ðSTM32¿ª·¢°å
* Ó²¼þÁ¬½Ó ----------------------------
* | PA4-SPI1-NSS: W25X16-CS|
* | PA5-SPI1-SCK: W25X16-CLK |
* | PA6-SPI1-MISO : W25X16-DO|
* | PA7-SPI1-MOSI : W25X16-DIO |
* ¿â°æ±¾£ºST3.5.0
* ×÷Õß £º±£Áô
* ÂÛ̳ £ºhttp://www.amobbs.com/forum-1008-1.html
* ÌÔ±¦ £ºhttp://firestm32.taobao.com
#include "spi_flash.h"
/* Private typedef -----------------------------------------------------------*/
//#define SPI_FLASH_PageSize 4096
#define SPI_FLASH_PageSize 256
#define SPI_FLASH_PerWritePageSize 256
/* Private define ------------------------------------------------------------*/
#define W25X_WriteEnable 0x06
#define W25X_WriteDisable 0x04
#define W25X_ReadStatusReg 0x05
#define W25X_WriteStatusReg 0x01
#define W25X_ReadData 0x03
#define W25X_FastReadData 0x0B
#define W25X_FastReadDual 0x3B
#define W25X_PageProgram 0x02
#define W25X_BlockErase 0xD8
#define W25X_SectorErase 0x20
#define W25X_ChipErase 0xC7
#define W25X_PowerDown 0xB9
#define W25X_ReleasePowerDown 0xAB
#define W25X_DeviceID 0xAB
#define W25X_ManufactDeviceID 0x90
#define W25X_JedecDeviceID 0x9F
#define WIP_Flag 0x01/* Write In Progress (WIP) flag */
#define Dummy_Byte 0xFF
* Function Name: SPI_FLASH_Init
* Description : Initializes the peripherals used by the SPI FLASH driver.
* Input : None
* Output : None
* Return : None
#ifdef _DRIVER_IN_
u32 temp;
#endif
/* Enable SPI1*/
#ifdef _DRIVER_IN_
if ((temp == GD25Q32)||(temp == PY25Q32))
MassType = MASS_25Q32;
else
MassType = MASS_25Q16;
#else
#endif
* Function Name: SPI_FLASH_SectorErase
* Description : Erases the specified FLASH sector.
* Input : SectorAddr: address of the sector to erase.
* Output : None
* Return : None
/* Sector Erase */
SPI_FLASH_CS_LOW();
* Function Name: SPI_FLASH_BlockErase
* Output : None
* Return : None
void SPI_FLASH_BlockErase(u32 BlockAddr)
/* Sector Erase */
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(W25X_BlockErase);
SPI_FLASH_SendByte((BlockAddr & 0xFF0000) >> 16);
SPI_FLASH_SendByte((BlockAddr & 0xFF00) >> 8);
SPI_FLASH_SendByte(BlockAddr & 0xFF);
* Function Name: SPI_FLASH_BulkErase
* Description : Erases the entire FLASH.
* Input : None
* Output : None
* Return : None
void SPI_FLASH_BulkErase(void)
/* Bulk Erase */
SPI_FLASH_CS_LOW();
/* Send Bulk Erase instruction*/
SPI_FLASH_SendByte(W25X_ChipErase);
* Function Name: SPI_FLASH_PageWrite
* Description : Writes more than one byte to the FLASH with a single WRITE
* cycle(Page WRITE sequence). The number of byte can't exceed
* the FLASH page size.
* Input : - pBuffer : pointer to the buffercontaining the data to be
* written to the FLASH.
* - WriteAddr : FLASH's internal address to write to.
* - NumByteToWrite : number of bytes to write to the FLASH,
* must be equal or less than "SPI_FLASH_PageSize" value.
* Output : None
* Return : None
void SPI_FLASH_PageWrite(u8* pBuffer, u32 WriteAddr, u16 NumByteToWrite)
/* Enable the write access to the FLASH */
SPI_FLASH_CS_LOW();
/* Send "Write to Memory " instruction */
SPI_FLASH_SendByte(W25X_PageProgram);
/* Send WriteAddr high nibble address byte to write to */
SPI_FLASH_SendByte((WriteAddr & 0xFF0000) >> 16);
/* Send WriteAddr medium nibble address byte to write to */
SPI_FLASH_SendByte((WriteAddr & 0xFF00) >> 8);
/* Send WriteAddr low nibble address byte to write to */
SPI_FLASH_SendByte(WriteAddr & 0xFF);
if(NumByteToWrite > SPI_FLASH_PerWritePageSize)
NumByteToWrite = SPI_FLASH_PerWritePageSize;
//printf("\n\r Err: SPI_FLASH_PageWrite too large!");
/* while there is data to be written on the FLASH */
while (NumByteToWrite--)
/* Send the current byte */
SPI_FLASH_SendByte(*pBuffer);
/* Point on the next byte to be written */
pBuffer++;
* Function Name: SPI_FLASH_BufferWrite
* Description : Writes block of data to the FLASH. In this function, the
* number of WRITE cycles are reduced, using Page WRITE sequence.
* - NumByteToWrite : number of bytes to write to the FLASH.
* Output : None
* Return : None
while (NumOfPage--)
WriteAddr +=count;
pBuffer += count;
else
WriteAddr +=count;
pBuffer += count;
while (NumOfPage--)
//ÎÞ¼ìÑéдSPI FLASH
//±ØÐëÈ·±£ËùдµÄµØÖ··¶Î§ÄÚµÄÊý¾ÝÈ«²¿Îª0XFF,·ñÔòÔÚ·Ç0XFF´¦Ð´ÈëµÄÊý¾Ý½«Ê§°Ü!
//¾ßÓÐ×Ô¶¯»»Ò³¹¦ÄÜ
//ÔÚÖ¸¶¨µØÖ·¿ªÊ¼Ð´ÈëÖ¸¶¨³¤¶ÈµÄÊý¾Ý,µ«ÊÇҪȷ±£µØÖ·²»Ô½½ç!
//pBuffer:Êý¾Ý´æ´¢Çø
//WriteAddr:¿ªÊ¼Ð´ÈëµÄµØÖ·(24bit)
//NumByteToWrite:ҪдÈëµÄ×Ö½ÚÊý(×î´ó65535)
//CHECK OK
void SPI_Flash_Write_NoCheck(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite)
u16 pageremain;
pageremain=256-WriteAddr%256; //µ¥Ò³Ê£ÓàµÄ×Ö½ÚÊý
if(NumByteToWrite<=pageremain)pageremain=NumByteToWrite;//²»´óÓÚ256¸ö×Ö½Ú
while(1)
SPI_FLASH_PageWrite(pBuffer,WriteAddr,pageremain);
if(NumByteToWrite==pageremain)break;//дÈë½áÊøÁË
else //NumByteToWrite>pageremain
pBuffer+=pageremain;
WriteAddr+=pageremain;
NumByteToWrite-=pageremain; //¼õÈ¥ÒѾдÈëÁ˵Ä×Ö½ÚÊý
if(NumByteToWrite>256)pageremain=256; //Ò»´Î¿ÉÒÔдÈë256¸ö×Ö½Ú
else pageremain=NumByteToWrite; //²»¹»256¸ö×Ö½ÚÁË
u8 SPI_FLASH_BUF;
void SPI_Flash_Read(u8* pBuffer, u32 ReadAddr, u16 NumByteToRead);
void SPI_Flash_Write(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite)
u32 secpos;
u16 secoff;
u16 secremain;
u16 i;
secpos=WriteAddr/4096;//ÉÈÇøµØÖ· 0~511 for w25x16
secoff=WriteAddr%4096;//ÔÚÉÈÇøÄ򵀮«ÒÆ
secremain=4096-secoff;//ÉÈÇøÊ£Óà¿Õ¼ä´óС
if(NumByteToWrite<=secremain)secremain=NumByteToWrite;//²»´óÓÚ4096¸ö×Ö½Ú
while(1)
SPI_Flash_Read(SPI_FLASH_BUF,secpos*4096,4096);//¶Á³öÕû¸öÉÈÇøµÄÄÚÈÝ
for(i=0;i<secremain;i++)//УÑéÊý¾Ý
if(SPI_FLASH_BUF!=0XFF)break;//ÐèÒª²Á³ý
if(i<secremain)//ÐèÒª²Á³ý
SPI_FLASH_SectorErase(secpos * 4096);//²Á³ýÕâ¸öÉÈÇø
for(i=0;i<secremain;i++) //¸´ÖÆ
SPI_FLASH_BUF=pBuffer;
SPI_Flash_Write_NoCheck(SPI_FLASH_BUF,secpos*4096,4096);//дÈëÕû¸öÉÈÇø
}else SPI_Flash_Write_NoCheck(pBuffer,WriteAddr,secremain);//дÒѾ²Á³ýÁ˵Ä,Ö±½ÓдÈëÉÈÇøÊ£ÓàÇø¼ä.
if(NumByteToWrite==secremain)break;//дÈë½áÊøÁË
else//дÈëδ½áÊø
secpos++;//ÉÈÇøµØÖ·Ôö1
secoff=0;//Æ«ÒÆÎ»ÖÃΪ0
pBuffer+=secremain;//Ö¸ÕëÆ«ÒÆ
WriteAddr+=secremain;//дµØÖ·Æ«ÒÆ
NumByteToWrite-=secremain; //×Ö½ÚÊýµÝ¼õ
if(NumByteToWrite>4096)secremain=4096; //ÏÂÒ»¸öÉÈÇø»¹ÊÇд²»Íê
else secremain=NumByteToWrite; //ÏÂÒ»¸öÉÈÇø¿ÉÒÔдÍêÁË
* Function Name: SPI_FLASH_BufferRead
* Description : Reads a block of data from the FLASH.
* Input : - pBuffer : pointer to the buffer that receives the data read
* from the FLASH.
* - ReadAddr : FLASH's internal address to read from.
* - NumByteToRead : number of bytes to read from the FLASH.
* Output : None
* Return : None
SPI_FLASH_CS_LOW();
pBuffer++;
SPI_FLASH_BufferRead(pBuffer,ReadAddr,NumByteToRead);
return;
* Function Name: SPI_FLASH_ReadID
* Description : Reads FLASH identification.
* Input : None
* Output : None
* Return : FLASH identification
u32 SPI_FLASH_ReadID(void)
u32 Temp = 0, Temp0 = 0, Temp1 = 0, Temp2 = 0;
SPI_FLASH_CS_LOW();
/* Send "RDID " instruction */
SPI_FLASH_SendByte(W25X_JedecDeviceID);
Temp0 = SPI_FLASH_SendByte(Dummy_Byte);
Temp1 = SPI_FLASH_SendByte(Dummy_Byte);
Temp2 = SPI_FLASH_SendByte(Dummy_Byte);
Temp = (Temp0 << 16) | (Temp1 << 8) | Temp2;
return Temp;
* Input : None
* Output : None
u32 SPI_FLASH_ReadDeviceID(void)
u32 Temp = 0;
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(W25X_DeviceID);
Temp = SPI_FLASH_SendByte(Dummy_Byte);
return Temp;
* Function Name: SPI_FLASH_StartReadSequence
* Description : Initiates a read data byte (READ) sequence from the Flash.
* This is done by driving the /CS line low to select the device,
* then the READ instruction is transmitted followed by 3 bytes
* address. This function exit and keep the /CS line low, so the
* Flash still being selected. With this technique the whole
* content of the Flash is read with a single READ instruction.
* Input : - ReadAddr : FLASH's internal address to read from.
* Output : None
* Return : None
void SPI_FLASH_StartReadSequence(u32 ReadAddr)
SPI_FLASH_CS_LOW();
/* Send the 24-bit address of the address to read from -----------------------*/
/* Send ReadAddr high nibble address byte */
/* Send ReadAddr medium nibble address byte */
/* Send ReadAddr low nibble address byte */
* Function Name: SPI_FLASH_ReadByte
* Description : Reads a byte from the SPI Flash.
* This function must be used only if the Start_Read_Sequence
* function has been previously called.
* Input : None
* Output : None
* Return : Byte Read from the SPI Flash.
* Function Name: SPI_FLASH_SendByte
* Description : Sends a byte through the SPI interface and return the byte
* received from the SPI bus.
* Input : byte : byte to send.
* Output : None
* Return : The value of the received byte.
* Function Name: SPI_FLASH_SendHalfWord
* Description : Sends a Half Word through the SPI interface and return the
* Half Word received from the SPI bus.
* Input : Half Word : Half Word to send.
* Output : None
* Return : The value of the received Half Word.
* Function Name: SPI_FLASH_WriteEnable
* Description : Enables the write access to the FLASH.
* Input : None
* Output : None
* Return : None
void SPI_FLASH_WriteEnable(void)
SPI_FLASH_CS_LOW();
/* Send "Write Enable" instruction */
SPI_FLASH_SendByte(W25X_WriteEnable);
* Function Name: SPI_FLASH_WaitForWriteEnd
* Description : Polls the status of the Write In Progress (WIP) flag in the
* FLASH's statusregisterandloopuntil writeopertaion
* has completed.
* Input : None
* Output : None
* Return : None
void SPI_FLASH_WaitForWriteEnd(void)
u8 FLASH_Status = 0;
SPI_FLASH_CS_LOW();
/* Send "Read Status Register" instruction */
SPI_FLASH_SendByte(W25X_ReadStatusReg);
/* Loop as long as the memory is busy with a write cycle */
do
/* Send a dummy byte to generate the clock needed by the FLASH
and put the value of the status register in FLASH_Status variable */
FLASH_Status = SPI_FLASH_SendByte(Dummy_Byte);
while ((FLASH_Status & WIP_Flag) == SET); /* Write in progress */
//½øÈëµôµçģʽ
void SPI_Flash_PowerDown(void)
SPI_FLASH_CS_LOW();
/* Send "Power Down" instruction */
SPI_FLASH_SendByte(W25X_PowerDown);
//»½ÐÑ
void SPI_Flash_WAKEUP(void)
SPI_FLASH_CS_LOW();
SPI_FLASH_SendByte(W25X_ReleasePowerDown);
SPI_FLASH_CS_HIGH(); //µÈ´ýTRES1
/******************************END OF FILE*****************************/
这里说的完整代码并不是整个工程的全部代码,只是与Nor Flash读写有关的代码。
五、总结
通过GD32F103的SPI接口操作NOR Flash,开发者可灵活扩展嵌入式系统的存储能力。本文提供了从底层驱动NOR Flash的方式。
原文链接:https://blog.csdn.net/weald2000/article/details/147313523
页:
[1]
