dirtwillfly 发表于 2025-6-22 10:43
使用HPM5300EVK板载仿真器烧写时遇到的问题
开始下载程序:2025-06-22 10:41:22
执行完毕, 耗时:1ms.
D:\RT-ThreadStudio>cd /d D:\RT-ThreadStudio\repo\Extract\Debugger_Support_Packages\HPMicro\OpenOCD-HPMicro\0.4.0\bin
D:\RT-ThreadStudio\repo\Extract\Debugger_Support_Packages\HPMicro\OpenOCD-HPMicro\0.4.0\bin>openocd.exe -f D:/RT-ThreadStudio/workspace/hpm5300/board/debug_scripts/openocd/probes/ft2232.cfg -f D:/RT-ThreadStudio/workspace/hpm5300/board/debug_scripts/openocd/soc/hpm5300.cfg -f D:/RT-ThreadStudio/workspace/hpm5300/board/debug_scripts/openocd/boards/hpm5300evk.cfg -c "init; halt; flash write_image erase D:/RT-ThreadStudio/workspace/hpm5300/flash_debug/rtthread.elf; reset; shutdown"
Open On-Chip Debugger 0.11.0+dev-02365-g488108c93 (2023-09-18-18:58)
Licensed under GNU GPL v2
For bug reports, read
        http://openocd.org/doc/doxygen/bugs.html
DEPRECATED! use 'ftdi vid_pid' not 'ftdi_vid_pid'
DEPRECATED! use 'ftdi layout_init' not 'ftdi_layout_init'
DEPRECATED! use 'ftdi layout_signal' not 'ftdi_layout_signal'
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi tdo_sample_edge falling"
Info : clock speed 10000 kHz
Info : JTAG tap: hpm5301.cpu tap/device found: 0x1000563d (mfg: 0x31e (Andes Technology Corporation), part: 0x0005, ver: 0x1)
Info : datacount=4 progbufsize=8
Info : Examined RISC-V core; found 1 harts
Info :hart 0: XLEN=32, misa=0x4090112f
Target successfully examined.
Info : starting gdb server for hpm5301.cpu0 on 3333
Info : Listening on port 3333 for gdb connections
Info : Flash write discontinued at 0x80001090, next section at 0x80003000
Warn : Adding extra erase range, 0x80001090 .. 0x80001fff
Warn : Adding extra erase range, 0x8001d5d0 .. 0x8001dfff
shutdown command invoked
dirtwillfly 发表于 2025-6-22 13:06
用UsbDriverTool设置了,可以debug了,但直接下载还是不行
幻境之眼 发表于 2025-7-9 14:12
我看了log不是执行完毕么?没有报错呀
页: [1]
查看完整版本: 使用HPM5300EVK板载仿真器烧写时遇到的问题
