唐纳德d 发表于 2025-6-25 22:34
不能用RAM的不同部分
用STM32H7和STM32 Cube IDE在linker script中添加了这个:/* Memories definition */MEMORY{DTCMRAM    (xrw)    : ORIGIN = 0x20000000,   LENGTH = 128KITCMRAM    (xrw)    : ORIGIN = 0x00000000,   LENGTH = 64KRAM_D1    (xrw)    : ORIGIN = 0x24000000,   LENGTH = 512KRAM_D2    (xrw)    : ORIGIN = 0x30000000,   LENGTH = 288KRAM_D3    (xrw)    : ORIGIN = 0x38000000,   LENGTH = 64KFLASH    (rx)    : ORIGIN = 0x8000000,   LENGTH = 1024K} /* Sections */SECTIONS{.ramd2block :{    . = ALIGN(4);    _sramd2block = .;       /* create a global symbol at ccmram start */    *(.ramd2block)    *(.ramd2block*)      . = ALIGN(4);    _eramd2block = .;       /* create a global symbol at ccmram end */} > RAM_D2    .ramd3block (NOLOAD) :{    KEEP(*(.ramd3section))} > RAM_D3但它会一直在DTCM RAM中定位此缓冲区:uint8_tSPI1_TxBuffer __attribute__(( section(".ramd2block") )); // SPI Tx当我看.map:.ramd2block   0x00000000200001f8       0x1b load address 0x000000000800e2f4 .ramd2block    0x00000000200001f8       0x1b Core/Src/main.o                0x00000000200001f8                SPI1_TxBuffer                0x0000000020000214                . = ALIGN (0x4)0x2000000在DTCM RAM中,为什么链接器没有在RAM_D2中定位缓冲区
jf101 发表于 2025-7-7 22:39
是什么原因呢?
页: [1]
查看完整版本: 不能用RAM的不同部分
