步进电机
#include <AccelStepper.h>#include <MultiStepper.h>
#define STEPPER1_DIR_PIN 6
#define STEPPER1_STEP_PIN 7
#define STEPPER2_DIR_PIN 8
#define STEPPER2_STEP_PIN 9
#define Ena_PIN 10 //使能位为引脚10。(低电平电机禁止运动,高电平电机有效)
AccelStepper stepper1(AccelStepper::DRIVER, STEPPER1_STEP_PIN, STEPPER1_DIR_PIN); // 配置电机1 的脉冲引脚 方向引脚
AccelStepper stepper2(AccelStepper::DRIVER, STEPPER2_STEP_PIN, STEPPER2_DIR_PIN); // 配置电机2 的脉冲引脚 方向引脚
MultiStepper steppers;
#define CIRCLE_Puls 1600 //电机旋转一圈的脉冲数
long positions; //2个电机坐标位置
void setup()
Serial.begin(9600);
pinMode(Ena_PIN, OUTPUT);
digitalWrite(Ena_PIN, 1);
stepper1.setMaxSpeed(CIRCLE_Puls*1.5); //设置1#电机最大速度
stepper1.setSpeed(CIRCLE_Puls*1); //设置1#电机速度
stepper1.setAcceleration(CIRCLE_Puls/4);//设置1#电机加速度
stepper2.setMaxSpeed(CIRCLE_Puls*1.5);
stepper2.setSpeed(CIRCLE_Puls*1);
stepper2.setAcceleration(CIRCLE_Puls/4);
/*==============1、转动=========================*/
//设置电机的目标位置
positions = CIRCLE_Puls*3;
//添加到多轴中
steppers.addStepper(stepper1);
steppers.addStepper(stepper2);
//电机运行执行
steppers.moveTo(positions);
steppers.runSpeedToPosition();
//串口反馈1#电机当前的位置
Serial.print("1# Motor Current Position is: ");
Serial.println(stepper1.currentPosition());
delay(2000);
/*==============2、反转=========================*/
//设置电机的目标位置
//positions = CIRCLE_Puls*0;
positions = 1;
positions = 1;
//添加到多轴中
//电机运行执行
//串口反馈1#电机当前的位置
delay(2000);
void loop()
// put your main code here, to run repeatedly:
		页:
[1]
