左左左啊 发表于 2025-6-27 16:38
GD32F105RCT6的CAN1通讯只能发不能收,无法进入接收中断
使用GD32F105系列的官方CAN通讯Demo,CAN0可以发可以收,CAN1只能发不能收,查找了好多资料,最后感觉定位在就是滤波器的问题,但是我用keil的debug模式发现无论是CAN0还是CAN1,我更改了滤波器编号,CAN_FW始终不显示我激活了哪个滤波器。这是什么原因,求助求助大佬们,困扰了好久了{:cry:}。下面是官方的demo。/*!
    \file    main.c
    \brief   communication_among_Devices in normal mode
    \version 2024-12-20, V2.5.0, firmware for GD32F10x
    Copyright (c) 2024, GigaDevice Semiconductor Inc.
    Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
    1. Redistributions of source code must retain the above copyright notice, this
       list of conditions and the following disclaimer.
    2. Redistributions in binary form must reproduce the above copyright notice,
       this list of conditions and the following disclaimer in the documentation
       and/or other materials provided with the distribution.
    3. Neither the name of the copyright holder nor the names of its contributors
       may be used to endorse or promote products derived from this software without
       specific prior written permission.
    THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
OF SUCH DAMAGE.
#include "gd32f10x.h"
#include <stdio.h>
#include "gd32f10x_eval.h"
/* select can */
//#define CAN0_USED
#define CAN1_USED
#ifdefCAN0_USED
    #define CANX CAN0
#else
    #define CANX CAN1
#endif
FlagStatus receive_flag;
uint8_t transmit_number = 0x0;
can_trasnmit_message_struct g_transmit_message;
can_receive_message_struct g_receive_message;
void nvic_config(void);
void led_config(void);
void gpio_config(void);
ErrStatus can_networking(void);
void can_networking_init(void);
void delay(void);
    \brief      main function
    \paramnone
    \param none
    \retval   none
int main(void)
    uint8_t i = 0;
    uint32_t timeout = 0xFFFF;
    uint8_t transmit_mailbox = 0;
    receive_flag = RESET;
    /* configure Tamper key */
    gd_eval_key_init(KEY_TAMPER, KEY_MODE_GPIO);
    /* configure GPIO */
    gpio_config();
    /* configure USART */
    gd_eval_com_init(EVAL_COM0);
    /* configure NVIC */
    nvic_config();
    /* configure leds */
    led_config();
    /* set all leds off */
    gd_eval_led_off(LED2);
    gd_eval_led_off(LED3);
    gd_eval_led_off(LED4);
    /* initialize CAN */
    can_networking_init();
    /* enable CAN receive FIFO1 not empty interrupt */
    can_interrupt_enable(CANX, CAN_INT_RFNE1);
//   can_interrupt_enable(CAN1, CAN_INT_RFNE1);
    /* initialize transmit message */
    can_struct_para_init(CAN_TX_MESSAGE_STRUCT, &g_transmit_message);
    g_transmit_message.tx_sfid = 0x00;
    g_transmit_message.tx_efid = 0xaabb;
    g_transmit_message.tx_ft = CAN_FT_DATA;
    g_transmit_message.tx_ff = CAN_FF_EXTENDED;
    g_transmit_message.tx_dlen = 8;
    g_transmit_message.tx_data = 0xA0U;
    g_transmit_message.tx_data = 0xA1U;
    g_transmit_message.tx_data = 0xA2U;
    g_transmit_message.tx_data = 0xA3U;
    g_transmit_message.tx_data = 0xA4U;
    g_transmit_message.tx_data = 0xA5U;
    g_transmit_message.tx_data = 0xA6U;
    g_transmit_message.tx_data = 0xA7U;
    printf("please press the Tamper key to transmit data!\r\n");
    /* initialize receive message */
    can_struct_para_init(CAN_RX_MESSAGE_STRUCT, &g_receive_message);
    while(1) {
      /* waiting for the Tamper key pressed */
      while(0 == gd_eval_key_state_get(KEY_TAMPER)){
            /* if transmit_number is 0x10, set it to 0x00 */
            if(transmit_number == 0x10){
                transmit_number = 0x00;
            }else{
                g_transmit_message.tx_data = transmit_number++;
                printf("\r\n can transmit data:");
                for(i = 0; i < g_transmit_message.tx_dlen; i++){
                  printf(" %02x", g_transmit_message.tx_data);
                /* transmit message */
                transmit_mailbox = can_message_transmit(CANX, &g_transmit_message);
                /* waiting for transmit completed */
                timeout = 0xFFFF;
                while((CAN_TRANSMIT_OK != can_transmit_states(CANX, transmit_mailbox)) && (0 != timeout)){
                  timeout--;
                /* waiting for Tamper key up */
                while(0 == gd_eval_key_state_get(KEY_TAMPER));
      if(SET == receive_flag) {
            gd_eval_led_toggle(LED2);
            printf("\r\n receive data:");
            for(i = 0; i < g_receive_message.rx_dlen; i++){
                printf(" %02x", g_receive_message.rx_data);
    \brief      initialize CAN and filter
    \paramcan_parameter
      \arg      can_parameter_struct
    \paramcan_filter
      \arg      can_filter_parameter_struct
    \param none
    \retval   none
    can_parameter_struct            can_parameter;
    can_filter_parameter_struct   can_filter;
    can_struct_para_init(CAN_INIT_STRUCT, &can_parameter);
    can_struct_para_init(CAN_FILTER_STRUCT, &can_filter);
    /* initialize CAN register */
    can_deinit(CANX);
    can_parameter.time_triggered = DISABLE;
    can_parameter.auto_bus_off_recovery = DISABLE;
    can_parameter.auto_wake_up = DISABLE;
    can_parameter.auto_retrans = DISABLE;
    can_parameter.rec_fifo_overwrite = DISABLE;
    can_parameter.trans_fifo_order = DISABLE;
    can_parameter.working_mode = CAN_NORMAL_MODE;
    can_parameter.resync_jump_width = CAN_BT_SJW_1TQ;
    can_parameter.time_segment_1 = CAN_BT_BS1_5TQ;
    can_parameter.time_segment_2 = CAN_BT_BS2_3TQ;
    /* baudrate 250kbps */
    can_parameter.prescaler = 24;
    can_init(CANX, &can_parameter);
    /* initialize filter */
#ifdefCAN0_USED
    /* CAN0 filter number */
    can_filter.filter_number = 0;
#else
    /* CAN1 filter number */
    can_filter.filter_number = 15;
#endif
    can_filter.filter_mode = CAN_FILTERMODE_MASK;
    can_filter.filter_bits = CAN_FILTERBITS_32BIT;
    can_filter.filter_list_high = 0x0000U;
    can_filter.filter_list_low = 0x0000U;
    can_filter.filter_mask_high = 0x0000U;
    can_filter.filter_mask_low = 0x0000U;
    can_filter.filter_fifo_number = CAN_FIFO1;
    can_filter.filter_enable = ENABLE;
    can_filter_init(&can_filter);
    \brief      configure the nested vectored interrupt controller
    \paramnone
    \param none
    \retval   none
#ifdefCAN0_USED
    /* configure CAN0 NVIC */
    nvic_irq_enable(CAN0_RX1_IRQn,0,0);
#else
    /* configure CAN1 NVIC */
    nvic_irq_enable(CAN1_RX1_IRQn,0,0);
#endif
    \brief      delay
    \paramnone
    \param none
    \retval   none
void delay(void)
    uint16_t nTime = 0x0000;
    for(nTime = 0; nTime < 0xFFFF; nTime++){
    \brief      configure the leds
    \paramnone
    \param none
    \retval   none
    gd_eval_led_init(LED2);
    gd_eval_led_init(LED3);
    gd_eval_led_init(LED4);
    \brief      configure GPIO
    \paramnone
    \param none
    \retval   none
    /* enable CAN clock */
    rcu_periph_clock_enable(RCU_CAN0);
                rcu_periph_clock_enable(RCU_CAN1);
          rcu_periph_clock_enable(RCU_GPIOB);
    rcu_periph_clock_enable(RCU_AF);
    /* configure CAN0 GPIO */
    gpio_init(GPIOB,GPIO_MODE_IPU,GPIO_OSPEED_50MHZ,GPIO_PIN_8);
    gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_9);
    gpio_pin_remap_config(GPIO_CAN0_PARTIAL_REMAP,ENABLE);
          gpio_init(GPIOB,GPIO_MODE_IPU,GPIO_OSPEED_50MHZ,GPIO_PIN_5);
    gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_6);
    gpio_pin_remap_config(GPIO_CAN1_REMAP,ENABLE);
#ifdef GD_ECLIPSE_GCC
/* retarget the C library printf function to the USART, in Eclipse GCC environment */
int __io_putchar(int ch)
    usart_data_transmit(EVAL_COM0, (uint8_t) ch );
    while(RESET == usart_flag_get(EVAL_COM0, USART_FLAG_TBE));
    return ch;
#else
/* retarget the C library printf function to the USART */
int fputc(int ch, FILE *f)
    usart_data_transmit(EVAL_COM0, (uint8_t)ch);
    return ch;
#endif /* GD_ECLIPSE_GCC */
中断的回调函数如下:void CAN0_RX1_IRQHandler(void)
    /* check the receive message */
    can_message_receive(CAN0, CAN_FIFO1, &g_receive_message);
//    if((0xaabb == g_receive_message.rx_efid)&&(CAN_FF_EXTENDED == g_receive_message.rx_ff) && (8 == g_receive_message.rx_dlen)){
      receive_flag = SET;
    \brief      this function handles CAN1 RX0 exception
    \paramnone
    \param none
    \retval   none
void CAN1_RX1_IRQHandler(void)
//    printf("get!!\r\n");
    can_message_receive(CAN1, CAN_FIFO1, &g_receive_message);
      receive_flag = SET;
}使用debug模式看了CAN_FW中激活的滤波器,发现没有打√的,是不是就代表没激活,导致我进不去中断{:cry:}。图片如图
FIFO1的相应中断也开了,能接收到数据
各位大佬,请求指点迷津。
static/image/hrline/line1.png
左左左啊 发表于 2025-7-1 16:04
问题已解决,是启动文件没有配置好
问题已解决,是启动文件没有配置好
问下是启动文件哪里需要配置呀
l63t89 发表于 2025-8-31 23:45
GD32F105 的 CAN0 和 CAN1 共享同一组滤波器
页: [1]
查看完整版本: GD32F105RCT6的CAN1通讯只能发不能收,无法进入接收中断
