LIZARD925 发表于 2025-7-20 17:57
APM32E030ADC
#技术资源#
APM32E030系列使用记录--ADC的使用
[*]ADC单通道,实现ADC采样的与读取
目标:实现阻塞式读取ADC数值
程序中使用ADC1的通道2进行ADC的读取,初始化程序如下void AD_Init(void)
    RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_ADC1);
    RCM_EnableAHBPeriphClock(RCM_AHB_PERIPH_GPIOA);
      GPIO_Config_T GPIO_InitStructure;
      GPIO_InitStructure.mode = GPIO_MODE_AN;
      GPIO_InitStructure.pupd = GPIO_PUPD_NO;
      GPIO_InitStructure.pin = GPIO_PIN_2;
      GPIO_InitStructure.speed = GPIO_SPEED_50MHz;
      GPIO_Config(GPIOA, &GPIO_InitStructure);
      ADC_Reset();
      ADC_Config_T ADC_InitStructure;
      ADC_InitStructure.resolution = ADC_RESOLUTION_12B;                         //ADC数据分辨率
      ADC_InitStructure.scanDir = ADC_SCAN_DIR_UPWARD;                        //ADC扫描序列方向
      ADC_InitStructure.convMode = ADC_CONVERSION_CONTINUOUS;                //连续扫描
      ADC_InitStructure.dataAlign = ADC_DATA_ALIGN_RIGHT;                        //右对齐
      ADC_InitStructure.extTrigEdge = ADC_EXT_TRIG_EDGE_NONE;                //禁用外部触发转换模式
      ADC_InitStructure.extTrigConv = ADC_EXT_TRIG_CONV_TRG0;                //ADC外部触发转换定时器1 TRG0
      ADC_Config(&ADC_InitStructure);
      ADC_ConfigChannel(ADC_CHANNEL_2, ADC_SAMPLE_TIME_239_5);
      ADC_ReadCalibrationFactor();      //ADC 读取校准系数
    ADC_Enable();
      ADC_StartConversion();                        //开始转换
uint16_t AD_getvalue(void)
      while(ADC_ReadStatusFlag(ADC_FLAG_CC)==RESET);                //转换结束标志
      return ADC_ReadConversionValue();
}此方式的ADC数值读取使用阻塞的方式,可能会阻塞主循环的其它函数,使用滑动电阻求连接ADC引脚,通过串口将采集的数据打印出来,查看是否正确uint16_t ADvalue;
float v;
int main (void)
      LED_init();
      AD_Init();
      Serial_Init(115200);
      printf("APM32E030\r\n");
      while(1)
                ADvalue=AD_getvalue();
                v=(float)ADvalue/4095*3.3;
                printf("ADC:%f\n",v);
                LED1_turn();
                Delay_ms(1000);
                rx_test();      //串口接收
[*]ADC单通道+中断,实现ADC采样的与读取
目标:实现中断读取ADC数值
void AD_Init(void)
      RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_SYSCFG);
      ADC_Reset();
      /* Enable Interrupt*/
    ADC_EnableInterrupt(ADC_INT_CS);
    NVIC_EnableIRQRequest(ADC1_IRQn, 2);
    ADC_Enable();
      /* Wait until ADC is ready */
    while (!ADC_ReadStatusFlag(ADC_FLAG_ADRDY));
}只有ADC采集结束才会进入中断,将数据进行保存,此方式不阻塞主循环的其它函数,主循环通过串口将采集的数据进行打印,查看是否正确采集
uint16_t ADvalue;
float v;
int main (void)
      LED_init();
      AD_Init();
      while(1)
                LED1_turn();
                Delay_ms(1000);
                rx_test();      //串口接收
void ADC1_IRQHandler(void)
    if (ADC_ReadIntFlag(ADC_INT_FLAG_CS) == SET)
      ADC_ClearIntFlag(ADC_INT_FLAG_CS);
      ADvalue = ADC_ReadConversionValue();
[*]ADC多通道+DMA,实现ADC采样的与读取
目标:实现DMA读取ADC数值
程序中使用ADC1的通道0、1、2、3进行ADC的读取,初始化程序如下#define ADC_CH_SIZE         4
uint16_t adcData;
void DMA_Init(void)
    DMA_Config_T dmaConfig;
    RCM_EnableAHBPeriphClock(RCM_AHB_PERIPH_DMA1);
    dmaConfig.peripheralAddress = ((uint32_t)ADC_BASE + 0x40);
    dmaConfig.memoryAddress = (uint32_t)&adcData;
    dmaConfig.direction = DMA_DIR_PERIPHERAL;
    dmaConfig.bufferSize = ADC_CH_SIZE;
    dmaConfig.peripheralInc = DMA_PERIPHERAL_INC_DISABLE;
    dmaConfig.memoryInc = DMA_MEMORY_INC_ENABLE;
    dmaConfig.peripheralDataSize = DMA_PERIPHERAL_DATASIZE_HALFWORD;
    dmaConfig.memoryDataSize = DMA_MEMORY_DATASIZE_HALFWORD;
    dmaConfig.circular = DMA_CIRCULAR_ENABLE;
    dmaConfig.memoryTomemory = DMA_M2M_DISABLE;
    dmaConfig.priority = DMA_PRIORITY_LEVEL_HIGHT;
    DMA_Config(DMA1_CHANNEL_1, &dmaConfig);
    DMA_Enable(DMA1_CHANNEL_1);
void AD_Init(void)
      GPIO_InitStructure.pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3;
      ADC_Reset();
      ADC_ConfigChannel(ADC_CHANNEL_0, ADC_SAMPLE_TIME_239_5);
    ADC_ConfigChannel(ADC_CHANNEL_1, ADC_SAMPLE_TIME_239_5);
      ADC_ConfigChannel(ADC_CHANNEL_3, ADC_SAMPLE_TIME_239_5);
      DMA_Init();
      ADC_EnableDMA();
    ADC_DMARequestMode(ADC_DMA_MODE_CIRCULAR);
    ADC_Enable();
uint16_t AD_getvalue(uint8_t index)
      return adcData;
配置DMA进行ADC数据的搬运,我们只需要在必要的时候读取buff中的数据即可得到ADC采集的数据,主循环中通过串口将采集的数据进行打印,查看数据是否正确
uint16_t ADvalue;
float v;
int main (void)
      LED_init();
      AD_Init();
      while(1)
                ADvalue=AD_getvalue(0);
                printf("PA0ADC:%f\n",v);
                ADvalue=AD_getvalue(1);
                printf("PA1ADC:%f\n",v);
                ADvalue=AD_getvalue(2);
                printf("PA2ADC:%f\n",v);
                ADvalue=AD_getvalue(3);
                printf("PA3ADC:%f\r\n",v);
                LED1_turn();
                Delay_ms(1000);
                rx_test();      //串口接收
[*]ADC单通道+参考电压/温度,实现ADC采样的与读取
目标:实现读取ADC数值
程序中使用ADC1的通道16/17进行ADC的读取参考电压,初始化程序如下#include "ad.h"                  // Device header
void AD_Init(void)
      ADC_Reset();
//      ADC_EnableTempSensor();      //温度初始化
      ADC_EnableVrefint();      //参考电压初始化
//      ADC_ConfigChannel(ADC_CHANNEL_16, ADC_SAMPLE_TIME_239_5);
      ADC_ConfigChannel(ADC_CHANNEL_17, ADC_SAMPLE_TIME_239_5);
    ADC_Enable();
void AD_getvalue(void)
      uint32_t reference_adc_value = 0, tsen_adc_value = 0;
      ADC_DisableTempSensor();
//      ADC_StartConversion();
//      while(ADC_ReadStatusFlag(ADC_FLAG_CC)==RESET);                //转换结束标志
//      tsen_adc_value = ADC_ReadConversionValue();
//      printf("tsen_adc_value: %d\n", tsen_adc_value);
      ADC_StopConversion();
      reference_adc_value = ADC_ReadConversionValue();
      printf("reference_adc_value: %d\n", reference_adc_value);
但是读取的结果与手册写的1.2v有出入,我读到的是1.5V,不知道哪里出了问题,中断与DMA的流程和之前的一样,都可以进行读取
[*]ADC多通道+参考电压/温度,实现ADC采样的与读取
目标:实现DMA读取ADC数值
程序中使用ADC1的通道进行ADC的读取,初始化程序如下#include "ad.h"                  // Device header
#define ADC_CH_SIZE         6
uint16_t adcData;
void DMA_Init(void)
void AD_Init(void)
        ADC_Reset();
        DMA_Init();
        ADC_EnableDMA();
    ADC_Enable();
        return adcData;
将每个通道保存到buff中,进行读取即可
uint16_t ADvalue;
float v;
int main (void)
        LED_init();
        AD_Init();
        while(1)
                ADvalue=AD_getvalue(4);
                printf("TempSensor:%d\r\n",ADvalue);
                ADvalue=AD_getvalue(5);
                printf("Vref:%d\r\n",ADvalue);
                LED1_turn();
                Delay_ms(1000);
                rx_test();        //串口接收
}ADC的使用到此基本差不多了,对于基准电压的采集,以后再找问题
天体书记 发表于 2025-7-21 11:06
这个ADC的帖子也太霸气了。
我倾向于DMA按顺序周期扫描的策略。
黄昏收获 发表于 2025-7-21 15:21
这颗小芯片的ADC功能还这么丰富啊
永恒回声 发表于 2025-7-21 16:59
是不是M0内核的ADC模块都没有外部参考电压引脚。
我总觉得VCCA的电压不稳会带来ADC采样精度的偏差
lgm_sz 发表于 2025-8-5 20:53
感谢作者大佬
页: [1]
查看完整版本: APM32E030ADC
