南来之风 发表于 2025-7-27 14:38
【APM32F402R Micro-EVB】-6-FreeRTOS体验
本文体验在keil环境下CMSIS-FreeRTOS在APM32F402上的使用。
内核初始化:
Initialize the RTOS Kernel.
osStatus_t osKernelInitialize (void) {
osStatus_t stat;
BaseType_t state;
if (IRQ_Context() != 0U) {
    stat = osErrorISR;
else {
    state = xTaskGetSchedulerState();
    /* Initialize if scheduler not started and not initialized before */
    if ((state == taskSCHEDULER_NOT_STARTED) && (KernelState == osKernelInactive)) {
      #if defined(USE_TRACE_EVENT_RECORDER)
      /* Initialize the trace macro debugging output channel */
      EvrFreeRTOSSetup(0U);
      #endif
      #if defined(USE_FreeRTOS_HEAP_5) && (HEAP_5_REGION_SETUP == 1)
      /* Initialize the memory regions when using heap_5 variant */
      vPortDefineHeapRegions (configHEAP_5_REGIONS);
      #endif
      KernelState = osKernelReady;
      stat = osOK;
    } else {
      stat = osError;
/* Return execution status */
return (stat);
创建线程:
    /* Create the thread */
    ledThreadID = osThreadNew(Led_Thread, NULL, &ledThreadattr);
    if (ledThreadID == NULL)
      printf("Create led thread failed!\r\n");
    usartThreadID = osThreadNew(Usart_TestThread, NULL, &usartThreadattr);
    if (usartThreadID == NULL)
      printf("Create usart thread failed!\r\n");
启动调度器:
    /* Start the RTOS scheduler */
    osKernelStart();
其中LED线程与USART任务定义如下:
void Led_Thread(void *argument)
    UNUSED(argument);
    while (1)
      /* Toggle LED2 */
      BOARD_LED_Toggle(LED2);
      osDelay(1000);
* @brief   Usart1 test task
* @param   argumentNot used
* @retvalNone
void Usart_TestThread(void *argument)
    UNUSED(argument);
    while (1)
      /* Print message */
      printf("Hello, world!\r\n");
      osDelay(1000);
实物演示:
真的问题不大 发表于 2025-8-4 09:43
问问lz,操作运行上感觉怎么样,也想申请一块
暖茶轻语 发表于 2025-8-6 15:55
看起来你已经成功地在APM32F402上运行了FreeRTOS,并且创建了线程。你的代码示例对于初学者来说非常有用。如果遇到任何问题,社区总是乐于帮助解决。
FrostShimmer 发表于 2025-8-7 14:42
我也喜欢FreeRTOS
不过,printf()函数是不是可重入的啊?
页: [1]
查看完整版本: 【APM32F402R Micro-EVB】-6-FreeRTOS体验
