寂静之回响 发表于 2025-8-4 11:41
printf输出卡顿
/********************************** (C) COPYRIGHT *******************************
* File Name          : Main.c
* Author             : WCH
* Version            : V1.0
* Date               : 2020/08/06
* Description      : 串口1收发演示
* Copyright (c) 2021 Nanjing Qinheng Microelectronics Co., Ltd.
* Attention: This software (modified or not) and binary are used for
* microcontroller manufactured by Nanjing Qinheng Microelectronics.
#include "CH57x_common.h"
uint8_t TxBuff[] = "This is a tx exam\r\n";
uint8_t RxBuff;
uint8_t trigB;
* @fn      main
* @brief   主函数
* @returnnone
int main()
    uint8_t len;
    SetSysClock(CLK_SOURCE_PLL_60MHz);
    /* 配置串口1:先配置IO口模式,再配置串口 */
    GPIOA_SetBits(GPIO_Pin_9);
    GPIOA_ModeCfg(GPIO_Pin_8, GPIO_ModeIN_PU);      // RXD-配置上拉输入
    GPIOA_ModeCfg(GPIO_Pin_9, GPIO_ModeOut_PP_5mA); // TXD-配置推挽输出,注意先让IO口输出高电平
    UART1_DefInit();
#if 1 // 测试串口发送字符串
    UART1_SendString(TxBuff, sizeof(TxBuff));
#endif
#if 1 // 查询方式:接收数据后发送出去
PRINT("start\n");
    while(1)
      // len = UART1_RecvString(RxBuff);
      // if(len)
      //   UART1_SendString(RxBuff, len);
      //UART1_SendString("1234", 4);
      printf("666");
      DelayMs(1000);
#endif
#if 0 // 中断方式:接收数据后发送出去
    UART1_ByteTrigCfg(UART_7BYTE_TRIG);
    trigB = 7;
    UART1_INTCfg(ENABLE, RB_IER_RECV_RDY | RB_IER_LINE_STAT);
    PFIC_EnableIRQ(UART1_IRQn);
#endif
    while(1);
* @fn      UART1_IRQHandler
* @brief   UART1中断函数
* @returnnone
__attribute__((interrupt("WCH-Interrupt-fast")))
__attribute__((section(".highcode")))
void UART1_IRQHandler(void)
    volatile uint8_t i;
    switch(UART1_GetITFlag())
      case UART_II_LINE_STAT: // 线路状态错误
            UART1_GetLinSTA();
            break;
      case UART_II_RECV_RDY: // 数据达到设置触发点
            for(i = 0; i != trigB; i++)
                RxBuff = UART1_RecvByte();
                UART1_SendByte(RxBuff);
            break;
      case UART_II_RECV_TOUT: // 接收超时,暂时一帧数据接收完成
            i = UART1_RecvString(RxBuff);
            UART1_SendString(RxBuff, i);
            break;
      case UART_II_THR_EMPTY: // 发送缓存区空,可继续发送
            break;
      case UART_II_MODEM_CHG: // 只支持串口0
            break;
      default:
            break;
WCHTECH75 发表于 2025-8-27 14:06
默认的打印库需要增加\n否则累计到500字节左右才会打印,如果不需要增加\n可以根据此链接修改打印库:https://www.cnblogs.com/risc5-ble/p/15951072.html
EphemeralEchoes 发表于 2025-8-27 14:21
存不存存在有别的任务阻塞的这种情况??
穷得响叮当侠 发表于 2025-9-8 13:51
我建议你检查一下`printf`的使用,尤其是在循环中
页: [1]
查看完整版本: printf输出卡顿
