STM32F407在RCC配置后崩溃
使用STM32F407VGT7,但在上传代码时遇到了问题。我用STM32CubeIDE编写了最简单的代码:RCC配置和主循环中的一些操作。在上传代码(使用调试功能)、启动代码并稍作暂停(大约3秒左右)后,遇到了以下错误:
“Break at address "0x1fff36aa" with no debug information available, or outside of program code."”
不知道是什么原因导致这个错误。但从STM32F407的数据手册中看到,0x1fff36aa映射到“系统内存 + OPT”区域
我注意到,如果禁用中断,这个错误就不会发生。以下是相关代码。int main(void){/* USER CODE BEGIN 1 */ /* USER CODE END 1 */ /* MCU Configuration--------------------------------------------------------*/ /* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init(); /* USER CODE BEGIN Init */ /* USER CODE END Init */ /* Configure the system clock */SystemClock_Config(); /* USER CODE BEGIN SysInit */ /* USER CODE END SysInit */ /* Initialize all configured peripherals *//* USER CODE BEGIN 2 */uint32_t u32_dummy = 0;/* USER CODE END 2 */ /* Infinite loop *//* USER CODE BEGIN WHILE *///__disable_irq(); while (1){ /* USER CODE END WHILE */ u32_dummy += 24 * 56; u32_dummy -= 12; /* USER CODE BEGIN 3 */}/* USER CODE END 3 */} /*** @brief System Clock Configuration* @retval None*/void SystemClock_Config(void){RCC_OscInitTypeDef RCC_OscInitStruct = {0};RCC_ClkInitTypeDef RCC_ClkInitStruct = {0}; /** Configure the main internal regulator output voltage*/__HAL_RCC_PWR_CLK_ENABLE();__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);/** Initializes the RCC Oscillators according to the specified parameters* in the RCC_OscInitTypeDef structure.*/RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;RCC_OscInitStruct.HSIState = RCC_HSI_ON;RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK){ Error_Handler();}/** Initializes the CPU, AHB and APB buses clocks*/RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2; if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK){ Error_Handler();}
页:
[1]
