Hitomi22 发表于 2025-8-22 09:40
旧代码导入STM32CubeIDE 无法创建视图
:在导入Truestudio时出现com.atollic.truestudio.livewatch.view错误。正将用于旧代码的IDE升级以支持实时表达式功能。旧IDE是Truestudio 9.3.0,新IDE是STM32CubeIDE 1.8.0。
我目前的操作流程是使用"导入Truestudio项目"功能。下方附上了转换日志。项目可以正常构建,但在调试设置中多个视图出现此错误。
受影响的视图包括:
实时表达式
故障分析器
终端
特殊功能寄存器(SFR)
FreeRTOS任务列表
SWV跟踪日志
SWV异常跟踪日志
Project: mp-chargemodule_D
Converter: Atollic TrueSTUDIO project converter
Date: 20220110
Unknown value type "" for id com.atollic.truestudio.as.general.incpath on tool com.atollic.truestudio.exe.debug.toolchain.as
Unknown value type "" for id com.atollic.truestudio.gcc.symbols.defined on tool com.atollic.truestudio.exe.debug.toolchain.as
Unknown value type "" for id com.atollic.truestudio.common_options.target.interwork on tool com.atollic.truestudio.exe.debug.toolchain.as
Option com.atollic.truestudio.common_options.target.endianess is no longer supported
Option com.atollic.truestudio.common_options.target.instr_set is no longer supported
Unknown value type "" for id com.atollic.truestudio.common_options.target.interwork on tool com.atollic.truestudio.exe.debug.toolchain.gcc
Unknown value type "" for id com.atollic.truestudio.ld.libraries.list on tool com.atollic.truestudio.exe.debug.toolchain.ld
Unknown value type "" for id com.atollic.truestudio.ld.libraries.searchpath on tool com.atollic.truestudio.exe.debug.toolchain.ld
Unknown value type "" for id com.atollic.truestudio.common_options.target.interwork on tool com.atollic.truestudio.exe.debug.toolchain.ld
Unknown value type "" for id com.atollic.truestudio.gpp.optimization.fno_rtti on tool com.atollic.truestudio.exe.debug.toolchain.gpp
Unknown value type "" for id com.atollic.truestudio.gpp.optimization.fno_exceptions on tool com.atollic.truestudio.exe.debug.toolchain.gpp
Unknown value type "" for id com.atollic.truestudio.common_options.target.interwork on tool com.atollic.truestudio.exe.debug.toolchain.gpp
Unknown value type "" for id com.atollic.truestudio.common_options.target.interwork on tool com.atollic.truestudio.exe.debug.toolchain.ldcc
Option com.atollic.truestudio.secoutput.general.convert is no longer supported
No map found for id: com.atollic.truestudio.exe.release
豌豆爹 发表于 2025-8-22 16:11
调试视图配置不兼容
duo点 发表于 2025-8-22 16:12
项目配置迁移问题
onlycook 发表于 2025-8-22 16:12
STM32CubeIDE 可能未安装 FreeRTOS 调试插件 或 SWV 支持插件。
七毛钱 发表于 2025-8-22 16:13
重新创建调试配置,删除旧调试配置。
内政奇才 发表于 2025-8-22 16:13
修复 .launch 和 .cproject 文件,替换废弃的 TrueSTUDIO 配置。
海滨消消 发表于 2025-8-22 16:14
检查构建选项,移除不兼容的编译设置。
页: [1]
查看完整版本: 旧代码导入STM32CubeIDE 无法创建视图
