APM32E030的片内FLASH驱动
本帖最后由 口天土立口 于 2025-9-8 19:29 编辑APM32E030有64KB的主存储区,支持页/片擦除;
每页大小为1KB,有64页;
本次代码基于开发板:APM32E030R Micro-EVB
FLASH的驱动代码如下:
/* FLASH大小: 64KB */
#define FLASH_SIZE_MAX ((uint32_t)0x10000)
/* 页大小: 1KB */
#define FLASH_PAGE_SIZE ((uint32_t)0x400)/*
* @brief 擦除
* @param addr: 擦除起始地址
* len:擦除长度
* @retval 擦除长度
uint32_t bsp_flash_erase(uint32_t addr, uint32_t len)
uint32_t ret_len = 0U;
uint32_t cur_len = 0;
uint32_t erase_addr = addr;
if ((addr < FMC_BASE) || (addr >= (FMC_BASE + FLASH_SIZE_MAX)) || (len == 0)) {
} else {
__disable_irq();
/* 解锁 */
FMC_Unlock();
do {
if ((erase_addr & (FLASH_PAGE_SIZE - 1)) != 0) {
cur_len = FLASH_PAGE_SIZE - (erase_addr & (FLASH_PAGE_SIZE - 1));
erase_addr = erase_addr & (~(FLASH_PAGE_SIZE - 1));
} else {
cur_len = FLASH_PAGE_SIZE;
if (FMC_ErasePage(erase_addr) != FMC_STATE_COMPLETE) {
FMC_ClearStatusFlag(FMC_FLAG_BUSY | FMC_FLAG_PE | FMC_FLAG_WPE | FMC_FLAG_OC); /* 清除异常标志,重试 */
FMC_ClearStatusFlag(FMC_FLAG_BUSY | FMC_FLAG_PE | FMC_FLAG_WPE | FMC_FLAG_OC); /* 清除异常标志 */
break;
erase_addr += FLASH_PAGE_SIZE;
ret_len += cur_len;
} while ((ret_len < len) && (erase_addr < (FMC_BASE + FLASH_SIZE_MAX)));
/* 上锁 */
FMC_Lock();
__enable_irq();
return ret_len;
* @brief 写
* 需先手动调用擦除函数,确保待更新区域的字节全部为FF,才能正确执行写操作
* @param addr: 写起始地址
* buf:写缓存
* len:写长度
* @retval 写长度
uint32_t bsp_flash_write(uint32_t addr, uint8_t *buf, uint32_t len)
uint32_t write_len = 0U;
uint32_t write_addr = 0U;
uint16_t data = 0;
FMC_STATE_T state = FMC_STATE_COMPLETE;
if ((addr < FMC_BASE) || (addr >= (FMC_BASE + FLASH_SIZE_MAX)) || (buf == NULL) || (len == 0)) {
} else {
__disable_irq();
/* 解锁 */
FMC_Unlock();
/* 先处理单字节 */
if ((addr & 0x01) != 0) {
write_addr = addr & (0xFFFFFFFEU);
data = *(uint16_t *)write_addr;
data &= 0x00FF;
data += (((uint16_t)buf) << 8);
if (FMC_ProgramHalfWord(write_addr, data) != FMC_STATE_COMPLETE) {
/* 上锁 */
FMC_Lock();
__enable_irq();
return ret_len;
ret_len += 1;
write_addr += 2;
} else {
write_addr = addr;
if (ret_len >= len) {
/* 上锁 */
FMC_Lock();
__enable_irq();
return ret_len;
state = FMC_WaitForReady(FMC_DELAY_PROGRAM);
if (state == FMC_STATE_COMPLETE) {
/* 开启编程 */
FMC->CTRL2_B.PG = BIT_SET;
do {
/* 填充数据 */
data = 0;
if ((ret_len + 2) <= len) {
data = (((uint16_t)buf) << 8) + buf;
write_len = 2;
} else {
data = buf;
write_len = 1;
/* 写数据 */
*(__IO uint16_t *)write_addr = data;
/* 等待编程结束 */
if (state != FMC_STATE_COMPLETE) {
break;
write_addr += write_len;
ret_len += write_len;
} while ((ret_len < len) && (write_addr < (FMC_BASE + FLASH_SIZE_MAX)));
/* 结束编程 */
FMC->CTRL2_B.PG = BIT_RESET;
/* 上锁 */
FMC_Lock();
__enable_irq();
return ret_len;
* @brief 读
* @param addr: 读起始地址
* buf:读缓存
* len:读长度
* @retval 读长度
uint32_t bsp_flash_read(uint32_t addr, uint8_t *buf, uint32_t len)
} else {
/* 计算可读取的长度 */
if ((addr + len) > (FMC_BASE + FLASH_SIZE_MAX)) {
ret_len = (FMC_BASE + FLASH_SIZE_MAX) - addr;
} else {
ret_len = len;
memcpy(buf, (uint32_t *)addr, ret_len);
return ret_len;
* @brief 直写
* 无需先手动擦除,可直接写FLASH,函数内部自动计算并执行擦除操作,
* 但函数内部每次都执行擦除,所以执行效率比较慢
* @param addr: 直写起始地址
* buf:直写缓存
* len:直写长度
* @retval 直写长度
static uint8_t flash_write_buf;
uint32_t bsp_flash_write_direct(uint32_t addr, uint8_t *buf, uint32_t len)
uint32_t cur_len = 0U;
uint32_t single_len = 0U;
uint32_t write_addr = addr;
uint32_t erase_addr = 0U;
uint16_t data = 0;
} else {
__disable_irq();
/* 解锁 */
FMC_Unlock();
do {
// 起始地址非扇区对齐或写长度不足一个扇区
if (((write_addr % FLASH_PAGE_SIZE) != 0U) || ((ret_len + FLASH_PAGE_SIZE) > len)) {
// 获取FLASH现有数据
erase_addr = write_addr & (~(FLASH_PAGE_SIZE - 1));
bsp_flash_read(erase_addr, flash_write_buf, FLASH_PAGE_SIZE);
// 计算需更新的数据长度
cur_len = FLASH_PAGE_SIZE - (write_addr % FLASH_PAGE_SIZE);
cur_len = ((ret_len + cur_len) > len) ? (len - ret_len) : cur_len;
// 更改缓存数据
memcpy(&flash_write_buf, &buf, cur_len);
} else {
erase_addr = write_addr;
// 更改缓存数据
memcpy(flash_write_buf, &buf, cur_len);
// 擦除扇区
break;
single_len = 0;
/* 开启编程 */
/* 需回写已被擦除的完整扇区 */
do {
/* 填充数据 */
data = (((uint16_t)flash_write_buf) << 8) + flash_write_buf;
/* 写数据 */
*(__IO uint16_t *)erase_addr = data;
/* 等待编程结束 */
break;
erase_addr += 2;
single_len += 2;
/* 真正更新数据到FLASH */
if (erase_addr > write_addr) {
/* 可能当前2个字节的高位字节才是需更新的数据起点
* 或 后续回写的字节不是需更新的数据
if ((ret_len + (erase_addr - write_addr)) >= len) {
ret_len = len;
} else {
ret_len += (erase_addr - write_addr);
write_addr = erase_addr;
} while (single_len < FLASH_PAGE_SIZE);
/* 结束编程 */
break;
/* 上锁 */
FMC_Lock();
__enable_irq();
return ret_len;
注意:频繁的中断,可能会导致FLASH的擦写产生异常,进而死机,所以需加入禁止中断操作!
驱动测试代码如下:
// FLASH测试
int8_t flag_flash_test_e_w_r, flag_flash_test_w_direct;
uint32_t test_addr = 0;
static void flash_test(void)
#define TEST_SIZE_SINGLE (11)
#define TEST_FLASH_ST_ADDR(FMC_BASE + 0x400 * 3 + 5) /* 程序自身需 2KB+ FLASH空间 */
uint32_t flash_max_addr = FMC_BASE + 0x10000;
uint32_t cur_test_len = 0;
uint8_t test_buf_w, test_buf_r;
uint8_t test_magic_num = 0;
uint8_t i = 0;
static uint8_t flag_flash_test = 0;
if (flag_flash_test != 0) {
return;
/* FLASH 擦除/写/读测试 */
flag_flash_test_e_w_r = 0;
test_addr = TEST_FLASH_ST_ADDR;
do {
/* 计算测试的数据长度 */
if ((test_addr + TEST_SIZE_SINGLE) <= flash_max_addr) {
cur_test_len = TEST_SIZE_SINGLE;
} else {
cur_test_len = flash_max_addr - test_addr;
/* 填充数据 */
for (i = 0; i < TEST_SIZE_SINGLE; i++) {
test_buf_w = test_magic_num++;
/* 擦除 */
if (bsp_flash_erase(test_addr, cur_test_len) < cur_test_len) {
flag_flash_test_e_w_r = -1;
break;
/* 写 */
if (bsp_flash_write(test_addr, test_buf_w, cur_test_len) != cur_test_len) {
break;
/* 读 */
memset(test_buf_r, 0, sizeof(test_buf_r));
if (bsp_flash_read(test_addr, test_buf_r, cur_test_len) != cur_test_len) {
break;
/* 比较 */
for (i = 0; i < cur_test_len; i++) {
if (test_buf_w != test_buf_r) {
break;
test_addr += cur_test_len;
} while (test_addr < flash_max_addr);
if (flag_flash_test_e_w_r == 0) {
flag_flash_test_e_w_r = 2;
/* FLASH 直写测试 */
flag_flash_test_w_direct = 0;
do {
/* 计算测试的数据长度 */
} else {
/* 填充数据 */
/* 直写 */
if (bsp_flash_write_direct(test_addr, test_buf_w, cur_test_len) != cur_test_len) {
flag_flash_test_w_direct = -1;
break;
/* 读 */
break;
/* 比较 */
break;
if (flag_flash_test_w_direct == 0) {
flag_flash_test_w_direct = 2;
flag_flash_test = 1;
}// 应用初始化
void app_init(void)
flash_test();
// 应用任务
void app_task(void)
详细代码,请查看附件:
我也在犹豫是不是把flash的操作放在bsp里面更合适。
看了楼主的帖子,我觉得就是应该把flash的操作放到bps里面 楼主的代码是不是写错了。怎么先unlock_flash()之后要打开irq,再操作flash的写入操作?
是不是在unlock_flash()之后,要关闭中断啊 银河漫步 发表于 2025-9-8 10:12
是不是在unlock_fl ...
感谢,确实写反了 嘿嘿
页:
[1]
