jingong0392 发表于 2012-8-6 12:00
STM32的CAN总线引脚无波形输出,附代码,请教编程错在何处。
红牛开发板,STM32f103ZET6的芯片,板子上的CAN收发器为MCP2551。用STM32与周立功的CAN-1模块通信,因此CAN总线是有两个节点的。两个节点均配有终端电阻。之前用Loopback模式自测通过。使用重映射,STM32的PB8和PB9引脚上无任何波形。代码如下。不知道是哪里配置错了,求指正,不胜感激!
但求CAN引脚能有波形输出就好。
#include "stm32f10x.h"
#include "stdio.h"
void RCC_Configuration(void);
void GPIO_Configuration(void);
void CAN_Config(void);
CanTxMsg TxMessage;
CanRxMsg RxMessage;
CAN_InitTypeDef      CAN_InitStructure;
CAN_FilterInitTypeDefCAN_FilterInitStructure;
int main(void)
    RCC_Configuration();
    CAN_Config();
    while(1)
CAN_Transmit(CAN1,&TxMessage);
ErrorStatus HSEStartUpStatus;
/* RCC system reset(for debug purpose) */
RCC_DeInit();
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK */
    RCC_PCLK1Config(RCC_HCLK_Div1);
    /* Select HSE as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_HSE);
    /* Wait till HSE is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x04)
GPIO_InitTypeDefGPIO_InitStructure;
/* GPIO clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
/* Configure CAN pin: RX */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* Configure CAN pin: TX */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_PinRemapConfig(GPIO_Remap1_CAN1 , ENABLE);
/* CANx Periph clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
/* CAN register init */
CAN_DeInit(CAN1);
CAN_StructInit(&CAN_InitStructure);
/* CAN cell init */
CAN_InitStructure.CAN_TTCM = DISABLE;
CAN_InitStructure.CAN_ABOM = DISABLE;
CAN_InitStructure.CAN_AWUM = DISABLE;
CAN_InitStructure.CAN_NART = DISABLE;
CAN_InitStructure.CAN_RFLM = DISABLE;
CAN_InitStructure.CAN_TXFP = DISABLE;
CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
/* CAN Baudrate = 1MBps*/
CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
CAN_InitStructure.CAN_BS1 = CAN_BS1_3tq;
CAN_InitStructure.CAN_BS2 = CAN_BS2_5tq;
CAN_InitStructure.CAN_Prescaler = 4;
CAN_Init(CAN1, &CAN_InitStructure);
/* CAN filter init */
CAN_FilterInitStructure.CAN_FilterNumber = 0;
CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
CAN_FilterInit(&CAN_FilterInitStructure);
/* Transmit */
TxMessage.StdId = 0x321;
TxMessage.ExtId = 0x01;
TxMessage.IDE = CAN_ID_STD;
TxMessage.RTR = CAN_RTR_DATA;
TxMessage.DLC = 1;
jingong0392 发表于 2012-8-6 12:07
Keil的工程。求指导啊。卡在这个问题上好久了。
IJK 发表于 2012-8-6 15:39
2个建议。
1.使用重映射,需要打开AFIO的时钟
2.先检查CAN_TX引脚,看是否有数据发出
lxj19901115 发表于 2012-8-6 20:11
AFIO,和CAN BUS 时钟没有开启,,,,,,
jingong0392 发表于 2012-8-7 13:53
3# IJK
jingong0392 发表于 2012-8-7 13:54
3# IJK 重映射
jingong0392 发表于 2012-8-7 13:56
4# lxj19901115 重映射时钟开了的,在CAN—Config()一开始就开了。Tx引脚没有波形啊
jingong0392 发表于 2012-8-7 13:57
4# lxj19901115 CAN总线时钟也开启了,在CAN—config()函数的中间部分
jingong0392 发表于 2012-8-7 13:58
3# IJK 时钟都开了的,没有任何波形啊啊啊啊
jingong0392 发表于 2012-8-12 14:37
问题解决了。是MCP2551芯片的问题。换了VP230就正常了。
kingsabbit 发表于 2013-7-22 20:05
楼主这种情况是没有外接芯片导致的,接上芯片后就正常了
页: [1]
查看完整版本: STM32的CAN总线引脚无波形输出,附代码,请教编程错在何处。
