嵌嵌dsp论坛 发表于 2013-1-15 10:57
TMS320F28335_ADEXAMPLE
#include "DSP2833x_Device.h"   // DSP2833x Headerfile Include File
#include "DSP2833x_Examples.h"   // DSP2833x Examples Include File
// Determine when the shift to right justify the data takes place
// Only one of these should be defined as 1.
// The other two should be defined as 0.
#define POST_SHIFT   0// Shift results after the entire sample table is full
#define INLINE_SHIFT 1// Shift results as the data is taken from the results regsiter
#define NO_SHIFT   0// Do not shift the results
#define LED (*(unsigned short int *)0x180000)
zhangmangui 发表于 2013-1-15 17:35
支持ing
页: [1]
查看完整版本: TMS320F28335_ADEXAMPLE
