sxggj 发表于 2013-2-27 23:03
帮忙看一下message日志
下面的日志导致服务器运行不正常,请帮忙分析一下。(redhat)
Feb6 09:53:05 localhost gconfd (root-7512): 正在启动(版本 2.14.0),pid 7512 用户“root”
Feb6 09:53:05 localhost gconfd (root-7512): 地址“xml:readonly:/etc/gconf/gconf.xml.mandatory”解析为位于 0 的只读配置源
Feb6 09:53:05 localhost gconfd (root-7512): 地址“xml:readwrite:/root/.gconf”解析为位于 1 的可写入配置源
Feb6 09:53:05 localhost gconfd (root-7512): 地址“xml:readonly:/etc/gconf/gconf.xml.defaults”解析为位于 2 的只读配置源
Feb6 10:15:35 localhost setroubleshoot: SELinux is preventing nautilus (unconfined_t) "write" to ./fd (unconfined_t). For complete SELinux messages. run sealert -l 71d0b5c8-4247-4ce1-9794-e29b26e765dc
Feb6 10:15:59 localhost automount: create_udp_client:101: hostname lookup failed: Unknown server error
Feb6 10:15:59 localhost automount: create_tcp_client:341: hostname lookup failed: Unknown server error
Feb6 10:15:59 localhost automount: lookup_mount: exports lookup failed for .hidden
Feb6 10:15:59 localhost automount: update_negative_cache: key ".hidden" not found in map.
Feb 10 04:02:22 localhost syslogd 1.4.1: restart.
Feb 12 00:01:01 localhost auditd: Audit daemon has no space left on logging partition
Feb 12 00:01:01 localhost auditd: Audit daemon is suspending logging due to no space left on logging partition.
应该是安装时分区不合理,/ 或/var分区太小。
页: [1]
查看完整版本: 帮忙看一下message日志
