tianwen_4524 发表于 2013-3-18 14:43
PieVectorTable的初始化
#include "DSP28_Device.h"
const struct PIE_VECT_TABLE PieVectTableInit = {
      PIE_RESERVED,// Reserved space
      PIE_RESERVED,
      PIE_RESERVED,
      PIE_RESERVED,
      PIE_RESERVED,
      PIE_RESERVED,
      PIE_RESERVED,
      PIE_RESERVED,
      PIE_RESERVED,
      PIE_RESERVED,
      PIE_RESERVED,
      PIE_RESERVED,
      PIE_RESERVED,
// Non-Peripheral Interrupts
      INT13_ISR,   // XINT13 or CPU-Timer 1
      INT14_ISR,   // CPU-Timer2
      DATALOG_ISR,   // Datalogging interrupt
      RTOSINT_ISR,   // RTOS interrupt
      EMUINT_ISR,    // Emulation interrupt
      NMI_ISR,       // Non-maskable interrupt
      ILLEGAL_ISR,   // Illegal operation TRAP
      USER0_ISR,   // User Defined trap 0
      USER1_ISR,   // User Defined trap 1
      USER2_ISR,   // User Defined trap 2
      USER3_ISR,   // User Defined trap 3
      USER4_ISR,   // User Defined trap 4
      USER5_ISR,   // User Defined trap 5
      USER6_ISR,   // User Defined trap 6
      USER7_ISR,   // User Defined trap 7
      USER8_ISR,   // User Defined trap 8
      USER9_ISR,   // User Defined trap 9
      USER10_ISR,    // User Defined trap 10
      USER11_ISR,    // User Defined trap 11
// Group 1 PIE Vectors
      PDPINTA_ISR,   // EV-A
      PDPINTB_ISR,   // EV-B
      rsvd_ISR,
      XINT1_ISR,
      XINT2_ISR,
      ADCINT_ISR,    // ADC
      TINT0_ISR,   // Timer 0
      WAKEINT_ISR,   // WD
// Group 2 PIE Vectors
      CMP1INT_ISR,   // EV-A
      CMP2INT_ISR,   // EV-A
      CMP3INT_ISR,   // EV-A
      T1PINT_ISR,    // EV-A
      T1CINT_ISR,    // EV-A
      T1UFINT_ISR,   // EV-A
      T1OFINT_ISR,   // EV-A
      rsvd_ISR,
// Group 3 PIE Vectors
      T2PINT_ISR,    // EV-A
      T2CINT_ISR,    // EV-A
      T2UFINT_ISR,   // EV-A
      T2OFINT_ISR,   // EV-A
      CAPINT1_ISR,   // EV-A
      CAPINT2_ISR,   // EV-A
      CAPINT3_ISR,   // EV-A
      rsvd_ISR,
// Group 4 PIE Vectors
      CMP4INT_ISR,   // EV-B
      CMP5INT_ISR,   // EV-B
      CMP6INT_ISR,   // EV-B
      T3PINT_ISR,    // EV-B
      T3CINT_ISR,    // EV-B
      T3UFINT_ISR,   // EV-B
      T3OFINT_ISR,   // EV-B
      rsvd_ISR,
// Group 5 PIE Vectors
      T4PINT_ISR,    // EV-B
      T4CINT_ISR,    // EV-B
      T4UFINT_ISR,   // EV-B
      T4OFINT_ISR,   // EV-B
      CAPINT4_ISR,   // EV-B
      CAPINT5_ISR,   // EV-B
      CAPINT6_ISR,   // EV-B
      rsvd_ISR,
// Group 6 PIE Vectors
      SPIRXINTA_ISR,   // SPI-A
      SPITXINTA_ISR,   // SPI-A
      rsvd_ISR,
      rsvd_ISR,
      MRINTA_ISR,    // McBSP-A
      MXINTA_ISR,    // McBSP-A
      rsvd_ISR,
      rsvd_ISR,
// Group 7 PIE Vectors
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
// Group 8 PIE Vectors
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
// Group 9 PIE Vectors
      SCIRXINTA_ISR, // SCI-A
      SCITXINTA_ISR, // SCI-A
      SCIRXINTB_ISR, // SCI-B
      SCITXINTB_ISR, // SCI-B
      ECAN0INTA_ISR, // eCAN
      ECAN1INTA_ISR, // eCAN
      rsvd_ISR,
      rsvd_ISR,
// Group 10 PIE Vectors
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
// Group 11 PIE Vectors
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
// Group 12 PIE Vectors
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
      rsvd_ISR,
// InitPieVectTable:
// This function initializes the PIE vector table to a known state.
// This function must be executed after boot time.
void InitPieVectTable(void)
        int16        i;
        Uint32 *Source = (void *) &PieVectTableInit;
        Uint32 *Dest = (void *) &PieVectTable;
        EALLOW;
        for(i=0; i < 128; i++)
                *Dest++ = *Source++;
        EDIS;
        // Enable the PIE Vector Table
        PieCtrl.PIECRTL.bit.ENPIE = 1;
这是一种初始化,这种初始化就是将具体地址赋值给变量向量!
        int16        i;
        //Uint32 *Source = (void *) &PieVectTableInit;
        EALLOW;
                *Dest++ =0;
        EDIS;
这又是一种初始化,这种初始化就是将0赋值给变量向量!
请问这两种初始化有什么区别?哪种初始化会更好?同时不好的,会出现什么问题???
hhuguodong 发表于 2013-3-19 07:50
楼主自己也说了,第一种是将PieVectTableInit值全部传递给了Struct PieVectTable。而你说的第二种是将0全都赋值给Struct PieVectTable这个变量。这不就是一种初始化方法吗?只是赋的值不一样而已啊,怎么会是两种初始化方法呢。循环里面的*Dest++ = *Source++;*Dest++ =0;并不是传递的地址,而是传递的内容。
tianwen_4524 发表于 2013-3-20 15:54
hhuguodong 发表于 2013-3-19 07:50 static/image/common/back.gif
楼主自己也说了,第一种是将PieVectTableInit值全部传递给了Struct PieVectTable。而你说的第二种是将0全都 ...
也对!那问下,*Dest++=0和*Dest++=*Source++的值有什么区别吗???
tianwen_4524 发表于 2013-3-22 17:10
怎么回音的?????
tianwen_4524 发表于 2013-3-26 11:35
页: [1]
查看完整版本: PieVectorTable的初始化
