ygd163163 发表于 2013-8-4 15:27
Error 0x80000200/-1031(已解决)
编了一下程序,在测试引脚的电压时,一部小心短接了,一直连接不上,提示这个,请问要怎样解决呢,才刚刚接触dsp,啥也不懂
Error connecting to the target:
Fatal Error during: OCS,
Device driver: Problem with the Emulation Controller.
It is recommended to RESET EMULATOR.This will disconnect each
target from the emulator.The targets should then be power cycled
or hard reset followed by an emureset and reconnect to each target.
Sequence ID: 0
Error Code: -1031
Error Class: 0x80000200
I/O Port = 240
Board Name: F2810 XDS510 Emulator
Cpu Name: CPU_1
Abort:
ygd163163 发表于 2013-8-4 15:48
已解决了,短接后电脑的usb口出现问题了,换了另外一个usb口就正常了
jlass 发表于 2013-8-5 08:50
楼主的意思是USB口烧了?
ygd163163 发表于 2013-8-5 15:30
jlass 发表于 2013-8-5 08:50 static/image/common/back.gif
楼主的意思是USB口烧了?
不知道是不是,换了就好了,具体怎样,懒得再试,可以用就好了
zhangmangui 发表于 2013-8-6 12:28
感谢问题解决方法的分享
页: [1]
查看完整版本: Error 0x80000200/-1031(已解决)
