line 27: error: expected an expression 求解
出现"main_nonBIOS.c", line 27: error: expected an expression这个错误不知道错在哪void main(void)
/*** CPU Initialization ***/
InitSysCtrl(); //Initialize the CPU (FILE: SysCtrl.c)
DINT;
IER = 0x0000; // Disable CPU interrupts
IFR = 0x0000; // Clear all CPU interrupt flags
InitXintf(); //Initialize the external memory interface (FILE: Xintf.c)
//InitGpio(); // Initialize the shared GPIO pins (FILE: Gpio.c)
InitPieCtrl(); // Initialize and enable the PIE (FILE: PieCtrl.c)
InitEv(); // Initialize the EV(FILE: Ev.c)--And initialize the Timer1
InitCpuTimers();
// Initialize the time (FILE: DSP281x_CpuTimers.c)
FFT(float DataR,float DataI);
InitForFFT();
EALLOW; // This is needed to write to EALLOW protected registers
PieVectTable.TINT0 = &cpu_timer0_isr;//timer0中断服务子程序重定位
EDIS; // This is needed to disable write to EALLOW protected registers
IER |= M_INT1; // EV Interrupt
IFR &= 0x0000; //Clear all interrupt flag
// Enable TINT0 in the PIE: Group 1 interrupt 7
PieCtrlRegs.PIEIER1.bit.INTx7 = 1;
有颜色的那句话就是错误所在行 如果去掉括号里的东西 也报错说是too few arguments in function call
我在头文件中定义了这个函数
extern float sin_tab,cos_tab;
extern float fWaveR,fWaveI,w;
extern void InitForFFT();
extern void FFT(float DataR,float DataI); FFT(float DataR,float DataI);
这句话 好像在头文件中去掉fft括号里面的东西 然后在主函数初始化中也不要括号里面的就好了。 帮忙顶 高手解答 本帖最后由 aresc 于 2013-8-11 10:03 编辑
把两个float去掉先! 另外DataR, DataI, ADsample是个啥??应该写成FFT( DataR, DataI)。
页:
[1]
