fupingzuo 发表于 2008-8-8 13:40
IC器件开短路测试
各位业界大佬,有谁知道IC件的开短路测试方**主要测试各管脚对地/电源是否开短路和相邻管脚是否短路.有知道的,请赐教,多谢!
elnino1983 发表于 2008-8-15 10:24
如何测开短路
一般IC引脚都有钳位二极管,可以用万用表二极管档测量
enddy 发表于 2008-8-25 19:23
re
https://bbs.21ic.com/upfiles/img/200710/20071010193838946.jpg
enddy 发表于 2008-8-25 19:26
re
for&nbsp;picture1:<br /><br />Ground&nbsp;all&nbsp;pins&nbsp;(including&nbsp;VDD)<br />Program&nbsp;dynamic&nbsp;loads&nbsp;to&nbsp;+400uA&nbsp;at&nbsp;3V<br />Set&nbsp;VOL/VOH&nbsp;Z&nbsp;Mode&nbsp;(fail/pass/fail)<br />Run&nbsp;functional&nbsp;pattern&nbsp;(test&nbsp;one&nbsp;pin&nbsp;at&nbsp;a&nbsp;time)<br />Test&nbsp;for&nbsp;diode&nbsp;voltage<br />Fails&nbsp;if&nbsp;voltage&nbsp;is&nbsp;greater&nbsp;than&nbsp;1.5V<br />Fails&nbsp;if&nbsp;voltage&nbsp;is&nbsp;less&nbsp;than&nbsp;0.2V<br /><br /><br /><br />for&nbsp;picture2<br /><br />Ground&nbsp;all&nbsp;pins&nbsp;(including&nbsp;VDD)<br />Program&nbsp;dynamic&nbsp;loads&nbsp;to&nbsp;-400uA&nbsp;at&nbsp;-3V<br />Set&nbsp;VOL/VOH&nbsp;Z&nbsp;Mode&nbsp;(fail/pass/fail)<br />Run&nbsp;functional&nbsp;pattern&nbsp;(test&nbsp;all&nbsp;pins&nbsp;at&nbsp;once)<br />Test&nbsp;for&nbsp;diode&nbsp;voltage<br />Fails&nbsp;if&nbsp;voltage&nbsp;is&nbsp;more&nbsp;than&nbsp;-0.2V<br />Fails&nbsp;if&nbsp;voltage&nbsp;is&nbsp;less&nbsp;than&nbsp;-1.5V<br /><br /><br />this&nbsp;test&nbsp;method&nbsp;is&nbsp;from&nbsp;softtest.&nbsp;it&nbsp;is&nbsp;suit&nbsp;for&nbsp;IC&nbsp;test!https://bbs.21ic.com/upfiles/img/200710/20071010194016676.jpg
kingyou 发表于 2009-3-13 17:06
那要电源和电源之间短路呢???
那要电源和电源,电源和地之间短路又怎么测试呢.
页: [1]
查看完整版本: IC器件开短路测试
