itoa() 函数的转换原理是什么啊
static char *itoa(int value, char *string, int radix){
int i, d;
int flag = 0;
char *ptr = string;
/* This implementation only works for decimal numbers. */
if (radix != 10)
*ptr = 0;
return string;
if (!value)
*ptr++ = 0x30;
*ptr = 0;
return string;
/* if this is a negative value insert the minus sign. */
if (value < 0)
*ptr++ = '-';
/* Make the value positive. */
value *= -1;
for (i = 10000; i > 0; i /= 10)
d = value / i;
if (d || flag)
*ptr++ = (char)(d + 0x30);
value -= (d * i);
flag = 1;
/* Null terminate the string. */
*ptr = 0;
return string;
}/* NCL_Itoa */
求换算原理 不就是 字符'2'=0x32数字 2 =0x2;
如 value = 222 ==>"222";
其他代码 自己看看就明白了
for (i = 10000; i > 0; i /= 10)==> int 表示的最大位数 9
if (value < 0) ==> 负数 - li880wert 发表于 2013-10-25 10:43 static/image/common/back.gif
看明白了! li880wert 发表于 2013-10-25 10:43 static/image/common/back.gif
看明白了!
页:
[1]
