raoxianbin 发表于 2014-2-22 19:25
2812关于SPI的一个测试程序
// TI File $Revision: /main/4 $
// Checkin $Date: July 2, 2007   11:27:41 $
// FILE:   Example_281xSpi_FFDLB_int.c
// TITLE:DSP281x Device Spi Digital Loop Back porgram.
// ASSUMPTIONS:
//         This program requires the DSP281x V1.00 header files.
//         As supplied, this project is configured for "boot to H0" operation.
//         Other then boot mode pin configuration, no other hardware configuration
//         is required.
// DESCRIPTION:
// This program is a SPI example that uses the internal loopback of
// the peripheral.Both interrupts and the SPI FIFOs are used.
// A stream of data is sent and then compared to the recieved stream.
// The sent data looks like this:
// 0000 0001 0002 0003 0004 0005 0006 0007
// 0001 0002 0003 0004 0005 0006 0007 0008
// 0002 0003 0004 0005 0006 0007 0008 0009
// FFFE FFFF 0000 0001 0002 0003 0004 0005
// FFFF 0000 0001 0002 0003 0004 0005 0006
// etc..
// This pattern is repeated forever.
// Watch Variables:
//   sdata    - Data to send
//   rdata    - Received data
//   rdata_point - Used to keep track of the last position in
//                   the receive stream for error checking
// $TI Release: DSP281x C/C++ Header Files V1.20 $
// $Release Date: July 27, 2009 $
#include "DSP281x_Device.h"   // DSP281x Headerfile Include File
#include "DSP281x_Examples.h"   // DSP281x Examples Include File
// Prototype statements for functions found within this file.
// interrupt void ISRTimer2(void);
interrupt void spiTxFifoIsr(void);
interrupt void spiRxFifoIsr(void);
void delay_loop(void);
void spi_fifo_init(void);
void error();
Uint16 sdata;   // Send data buffer
Uint16 rdata;   // Receive data buffer
Uint16 rdata_point;// Keep track of where we are
                     // in the data stream to check received data
void main(void)
   Uint16 i;
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP281x_SysCtrl.c file.
   InitSysCtrl();
// Step 2. Initalize GPIO:
// This example function is found in the DSP281x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio();// Skipped for this example
// Setup only the GP I/O only for SPI functionality
   EALLOW;
   GpioMuxRegs.GPFMUX.all=0x000F;      // Select GPIOs to be SPI pins
                                    // Port F MUX - x000 0000 0000 1111
   EDIS;
// Step 3. Initialize PIE vector table:
// Disable and clear all CPU interrupts
   DINT;
   IER = 0x0000;
   IFR = 0x0000;
// Initialize PIE control registers to their default state:
// This function is found in the DSP281x_PieCtrl.c file.
   InitPieCtrl();
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example.This is useful for debug purposes.
// The shell ISR routines are found in DSP281x_DefaultIsr.c.
// This function is found in DSP281x_PieVect.c.
   InitPieVectTable();
// Interrupts that are used in this example are re-mapped to
// ISR functions found within this file.
   EALLOW;      // This is needed to write to EALLOW protected registers
   PieVectTable.SPIRXINTA = &spiRxFifoIsr;
   PieVectTable.SPITXINTA = &spiTxFifoIsr;
   EDIS;   // This is needed to disable write to EALLOW protected registers
// Step 4. Initialize all the Device Peripherals:
// This function is found in DSP281x_InitPeripherals.c
// InitPeripherals(); // Not required for this example
   spi_fifo_init();          // Initialize the SPI only
// Step 5. User specific code, enable interrupts:
// Initalize the send data buffer
   for(i=0; i<8; i++)
      sdata = i;
   rdata_point = 0;
// Enable interrupts required for this example
   PieCtrlRegs.PIECRTL.bit.ENPIE = 1;   // Enable the PIE block
   PieCtrlRegs.PIEIER6.bit.INTx2=1;   // Enable PIE Group 6, INT 2
   PieCtrlRegs.PIEIER6.bit.INTx1=1;   // Enable PIE Group 6, INT 1
   IER=0x20;                            // Enable CPU INT6
   EINT;                              // Enable Global Interrupts
// Step 6. IDLE loop. Just sit and loop forever (optional):
      for(;;);
// Some Useful local functions
void delay_loop()
    long      i;
    for (i = 0; i < 1000000; i++) {}
void error(void)
    asm("   ESTOP0");         //Test failed!! Stop!
    for (;;);
void spi_fifo_init()
// Initialize SPI FIFO registers
   SpiaRegs.SPICCR.bit.SPISWRESET=0; // Reset SPI
   SpiaRegs.SPICCR.all=0x001F;       //16-bit character, Loopback mode
   SpiaRegs.SPICTL.all=0x0016;       //Interrupt enabled, Master/Slave XMIT enabled
   SpiaRegs.SPISTS.all=0x0000;
   SpiaRegs.SPIBRR=0x0063;         // Baud rate
   SpiaRegs.SPIFFTX.all=0xC028;      // Enable FIFO's, set TX FIFO level to 8
   SpiaRegs.SPIFFRX.all=0x0028;      // Set RX FIFO level to 8
   SpiaRegs.SPIFFCT.all=0x00;
   SpiaRegs.SPIPRI.all=0x0010;
   SpiaRegs.SPICCR.bit.SPISWRESET=1;// Enable SPI
   SpiaRegs.SPIFFTX.bit.TXFIFO=1;
   SpiaRegs.SPIFFRX.bit.RXFIFORESET=1;
      Uint16 i;
    for(i=0;i<8;i++)
         SpiaRegs.SPITXBUF=sdata;      // Send data
    for(i=0;i<8;i++)                  // Increment data for next cycle
         sdata++;
    SpiaRegs.SPIFFTX.bit.TXFFINTCLR=1;// Clear Interrupt flag
      PieCtrlRegs.PIEACK.all|=0x20;                  // Issue PIE ACK
    Uint16 i;
    for(i=0;i<8;i++)
            rdata=SpiaRegs.SPIRXBUF;                // Read data
      for(i=0;i<8;i++)                  // Check received data
            if(rdata != rdata_point+i) error();
      rdata_point++;
      SpiaRegs.SPIFFRX.bit.RXFFOVFCLR=1;// Clear Overflow flag
      SpiaRegs.SPIFFRX.bit.RXFFINTCLR=1;         // Clear Interrupt flag
      PieCtrlRegs.PIEACK.all|=0x20;       // Issue PIE ack
// No more.
如题,我的疑问是,程序在主函数里面又没有向发送缓冲区里面写数据,怎么能触发中断呢?我个人觉得是不是因为这里将发送的中断级别为设置为8,而此时的状态为0,小于8,所以触发中断?
但是我经过测试确实可以进入中断,不知道理解对不对,请求指导一下。。
zhangmangui 发表于 2014-2-23 10:34
你有没有测试一下   是不是只是上电后会进入一次发送中断而已
接下来就不会自动进入了
这里的8应该不是中断级别    应该是指8个字节后才触发中断
zhangmangui 发表于 2014-2-23 10:35
我曾经用过的   记得不大清楚啦
应该是接收fifo中有4个字节之后就会触发中断
发送中断没有使用
void InitSci(void)
        // Initialize SCI-A:
        EALLOW;
        GpioMuxRegs.GPFMUX.all = 0x0030;
        EDIS;
    SciaRegs.SCIFFTX.bit.SCIRST=0; //复位SCI的发送和接收通道
        /* loopback   8 bit data */
        SciaRegs.SCICCR.all = 0x07;        // 1 bit stop, disable parity, idle mode, 8 bits data
                                  //一个停止位,奇校验,奇偶校验禁止,自测试模式禁止,空闲位模式协议选择,字符长度为8位
        //地址位模式在帧中增加了一个附加位,空闲线模式常用于正常通信
        SciaRegs.SCICTL1.all = 0x03; // 发送器使能,接收器使能
                                  //接收错误中断禁止,SCI复位,无唤醒模式,睡眠模式禁止
//        SciaRegs.SCICTL2.all = 0x03; //使能RXRDY/BRKDT中断,使能TXRDY中断
    SciaRegs.SCIFFTX.bit.SCIFFENA=1;//使能SCI FIFO增强功能
    SciaRegs.SCIFFTX.bit.TXFFILIL=0;//设置发送FIFO中断等级位
    SciaRegs.SCIFFRX.bit.RXFFIL=4;    //设置接收FIFO中断等级位,匹配中断
    SciaRegs.SCIFFRX.bit.RXFFIENA=1;// 禁止SCIA FIFO接收中
        SciaRegs.SCIFFTX.bit.TXFFIENA=0;// 禁止SCIA FIFO发送中
    SciaRegs.SCIFFTX.bit.TXINTCLR=1;//清除中断标志位
        SciaRegs.SCIFFRX.bit.RXFFINTCLR=1;//清除中断标志位
        ////////////////////9600///19200/////
//        SciaRegs.SCIHBAUD = 0x00;//0x01;//0x00;
//        SciaRegs.SCILBAUD = 0xF3;//0x44;//0xa2;
//        SciaRegs.SCICTL1.all = 0x23;//SCI退出复位
        //tbd...
        //退出复位状态
    SciaRegs.SCICTL1.bit.SWRESET=1;
        SciaRegs.SCIFFTX.bit.SCIRST=1;
        // Initialize SCI-B:
        //tbd...
raoxianbin 发表于 2014-2-23 14:32
zhangmangui 发表于 2014-2-23 10:34 static/image/common/back.gif
接下来就不会自动进入了
这里的8应该不是中断 ...
恩   是   不是中断级别,是不是发送状态位为TXFFST的值0小于中断触发级位TXFFIL就会触发中断,斑竹下面给出的是SCI的代码,虽然有点类似,但不是一个东西,SCI不向缓冲区里写数据应该是不会触发中断的
raoxianbin 发表于 2014-2-23 15:29
我觉得应该是斑竹说的,上电默认的话会进入一次中断,有别的解释没,求告知。。
zhangmangui 发表于 2014-2-23 16:40
2812的SCI使用中发些   好像有些硬件bug
如自动波特率检测的时候第一次总是不成功复位一下接下来一切就正常了
如果发送中断用不到可以关闭
不知不觉vicent 发表于 2014-4-2 15:11
zhangmangui 发表于 2014-2-23 16:40 static/image/common/back.gif
如自动波特率检测的时候第一次总是不成功复位一下接下来一切就正 ...
你好,我最近遇到一个问题,用2812的串口,不加上校验的时候数据的帧格式的对的,加上奇偶校验后,数据的帧格式就反了,开始接收到的第一位是停止位,然后是校验位,随后才是数据位和起始位,感觉帧的格式都反了,不知道什么原因,求解啊,很着急啊
zhangmangui 发表于 2014-4-2 21:43
不知不觉vicent 发表于 2014-4-2 15:11 static/image/common/back.gif
你好,我最近遇到一个问题,用2812的串口,不加上校验的时候数据的帧格式的对的,加上奇偶校验后,数据的 ...
啊??你是用FPGA采集的吗?还是你用示波器抓到看的
怎么会这样啊   示波器看到的数据应该是反的   先低后高
页: [1]
查看完整版本: 2812关于SPI的一个测试程序
