新人,遇到一个问题,一直找不出原因,求解答undefined symbol in debug/*.obj
DSP/BIOS中测试log程序,一个简单的LOG_printf()函数输出程序,BIOS配置没有问题,并且将一系列源文件和头文件已添加,编译通过,连接时出现以下错误:"C:\CCStudio_v3.3\C6000\cgtools\bin\cl6x" -@"Debug.lkf"
<Linking>
undefined first referenced
symbol in file
_CLK_start C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
SWI_D_rdytab C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
IRAM$B C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_GBL_procId C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
__HOOK_knlId C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_KNL_exit C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
IRAM$L C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
TSK_VCREATEFXN C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_UTL_doError C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
PIP_F_start C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
GBL_boot C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
TSK_VDELETEFXN C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
KNL_glue C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_UTL_doAbort C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
IDL_F_loop C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_CLK_DFLTMICROSECS C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_CLK_htimePerLtime C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
GBL_stackbeg C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_UTL_doPutc C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_MEM C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
PRD_F_tick C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
__HOOK_NUMHOOKS C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_CLK_D_microseconds C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_GBL_cslCacheInit64 C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
RTA_F_or C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
TRC_R_mask C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
GBL_stackend C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_TSK_config C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_OBJ_table C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
HWI_A_VECS C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_FXN_F_nop C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
__MPC_init C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
IDL_D_calibrate C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_TSK C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_KNL_run C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
LNK_dspFrameRequestMask C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
CLK_F_isr C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
PIP_D_tabbeg C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
TRC_cinit C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_UTL_halt C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_MEM_init C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
RTA_F_dispatch C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_TSK_startup C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_TSK_setup C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_KNL_queues C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
CLK_A_TABBEG C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
LNK_F_dataPump C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
TSK_VEXITFXN C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
HWI_D_ccmask C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
HWI_F_dispatch C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_RTDX_Poll C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_TSK_init C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
IDL_D_busyObj C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_TSK_exit C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
SWI_F_enable C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
FXN_F_run C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_GBL_getVersion C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
GBL_initdone C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_CLK_stop C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_HWI_dispatchTab C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
LNK_dspFrameReadyMask C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
IDL_F_busy C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\hellowordcfg.obj
_LOG_printf C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\helloworld1.obj
_trace C:\\CCStudio_v3.3\\MyProjects\\Experiments\\hello\\Debug\\helloworld1.obj
>> error: symbol referencing errors - './Debug/HelloWorld.out' not built
>> Compilation failure
Build Complete,
2 Errors, 0 Warnings, 0 Remarks.
一直搞不明白出错的原因,求各位大神指导! 在.cmd文件里加上
-lbios.a64P /* DSP/BIOS support */
根据不同CPU选择不同的后缀 先试试楼上建议的方法
msblast 发表于 2014-3-13 13:02 static/image/common/back.gif
在.cmd文件里加上
你好!我按你说的在.cmd文件中加上-lbios.a64e,编译通过,连接时出现以下错误:
<Linking>
symbol in file
_memcpy C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
PIP_A_TABLEN C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
CLK_TIMEFXN C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
HST_A_TABBEG C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
IDL_CALIBRFXN C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
HST_A_TABEND C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
SWI_RUNFXN C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
SWI_EXECFXN C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
PRD_A_TABBEG C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
SWI_EHOOKFXN C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
PRD_A_TABLEN C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
CLK_A_TABBEG C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
CLK_HOOKFXN C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
PIP_A_TABBEG C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
IDL_A_CALBEG C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
PRD_THOOKFXN C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
SWI_IHOOKFXN C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
IDL_A_TABBEG C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
_SYS_PUTCBEG C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
_SYS_PUTCEND C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
CLK_F_itime C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
_KNL_swi C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
_HWI_STKTOP C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
_HWI_STKBOTTOM C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
__register_lock C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
__register_unlock C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
_CLK_itime C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
CLK_F_gethtime C:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/lib/bios.a64e
>> Compilation failure
Build Complete,
出现这个问题的原因是,工程中的cmd文件时自己写的,将自己写的cmd文件替换成BIOS配置时自动生成的*cfg.cmd文件后,连接出现:
<Linking>
symbol in file
>> Compilation failure
Build Complete,
请教各位大神,这是什么原因?按理来说,link自动生成的cmd文件,链接应该没问题的 出现问题的原因是:cmd文件不完善等各种原因,还在探索。 myduanning 发表于 2014-3-24 20:58 static/image/common/back.gif
不行先找个例程跑跑然后用哪个cmd再慢慢修改 先按版主的试试,这个问题我也遇到过。
1.先把LIB文件加入
2.程序有语法错误,一个个排查了。
页:
[1]
