关于12864液晶显示的问题 下面是程序代码 下载进2812以后胡乱显示
求大神指导,究竟要怎么写才对啊!!弄了好几天也弄不出来:'(ps:12864为串行,sclk为clk,std为sid)#define comm0//指令0
#define datt 1 //数据1
void delay(unsigned int t);
void lcd_wcmd(uchar dat_comm,uint content);
void lcd_init_();
void lcd_pos(uchar X,uchar Y);
void clrram ();
void wr_byte0();
void wr_byte1();
//void chn_dat(int f);
void chn_disp (uchar*chn) ;
uchar tab1[]={"当前纸浆浓度为:"};
uchar tab2[]={"比例系数为: "};
uchar tab3[]={"K=10 "};
while(t>0) t--;
/*----------------LCD写位操作0 -----------------*/
void wr_byte0()
sclk=0;
std=0;
delay(1);
sclk=1;
std=0;
delay(2);
sclk=0;
std=0;
delay(1);
/*----------------LCD写位操作1 -----------------*/
void wr_byte1()
{ sclk=0;
std=0;
delay(1);
std=1;
sclk=1;
delay(2);
sclk=0;
std=0;
delay(1);
void lcd_wcmd(uchar dat_comm, uint content)
uint i,j;
sclk=0;
std=0;
delay(1);
for(i=0;i<5;i++)
wr_byte1();
wr_byte0();
if(dat_comm)
wr_byte1(); //data
else
wr_byte0(); //comman
wr_byte0();
for(j=0;j<2;j++)
for(i=0;i<4;i++)
if(content&0x80)
wr_byte1();
else
wr_byte0();
content=content<<1;
for(i=0;i<4;i++)
wr_byte0();
delay(3);
/* 液晶初始化-字库 */
void lcd_init_() //LCD字库初始化程序
CSOUT;
SIDOUT;
CLKOUT;
RSTOUT;
RST0;
delay(100);
RST1;
lcd_wcmd (comm,0x30);//30---基本指令动作
lcd_wcmd (comm,0x01); // 清屏,地址指针指向00H
lcd_wcmd (comm,0x06);//光标的移动方向
lcd_wcmd (comm,0x0a);//开显示,关游标
uchar pos;
if(X==0)
{X=0x80;}
else if(X==1)
{X=0x90;}
else if(X==2)
{X=0x88;}
else if(X==3)
{X=0x98;}
pos=X+Y;
lcd_wcmd(comm,pos);
void clrram ()
lcd_wcmd(comm,0x34);
delay(5);
delay(5);
delay(5);
uchar i,j;
lcd_wcmd (comm,0x80);
for (j=0;j<4;j++)
for (i=0;i<16;i++)
lcd_wcmd (datt,chn);
// void chn_dat(int f)
// int K;
// volatile int c;
// K=10;
// c=K/f;
// printf("c=%d/n,c");
/* 主程序 */
void main(void)
{InitSysCtrl();
InitPieCtrl();
InitPieVectTable();
InitGpio();
delay(1000);
clrram();
delay(0xffff);
lcd_init_();
while(1)
lcd_pos(0,0);
//for (i=0;i<16;i++)
chn_disp(tab2);
delay(1000);
lcd_pos(1,0);
chn_disp(tab1);
delay(1000);
/*lcd_pos(3,0);
chn_dat(5);
delay(1000);
/* lcd_pos(3,0);
chn_disp(tab3);
delay(0xffff);
for(i=0;i<50;i++)
delay(0xffff);
clrram();
目的就是想让他分行显示,控制每一行怎么显示,可是老是显示乱码,不知道问题出在哪里,还望大神赐教!! 用IO口模拟的吗 zhangmangui 发表于 2014-3-18 19:10 static/image/common/back.gif
用IO口模拟的吗
用的GPIO口 我有实验板 程序下载到板子里以后老是胡乱显示 不知道为什么 小梨儿 发表于 2014-3-19 17:55 static/image/common/back.gif
重点看看延时等是否符合时序
页:
[1]
