求教F28M35的工程C28xx总是显示in low-power mode?
在CCS4上load F28M35的工程C28xx总是显示in low-power mode 问题,从而无**常运行,这个是什么原因?还有就是F28M35不是双核芯片吗,但【HV_SOLAR_DC_AC_v1.1】给了三个程序——“Solar_HV_DCAC_Concerto_M3”、“Solar_HV_DCAC_Concerto_C28x”、“SolarHV_DCAC”,这三个程序都要load才行吗?还是只需load第三个主程序就行?谢谢
CCS4对F28M35编程Error -1156 Device may be operating in low-power mode请问怎么解决?报错如下:
Cortex_M3_0: GEL Output: Memory Map Initialization Complete
C28xx_0: GEL Output:
C28xx_0: GEL: Error while executing OnReset(0): identifier not found: XAR0.
RAM Initialization Complete
C28xx_0: Flash operation timed out waiting for the algorithm to complete. Operation cancelled.
C28xx_0: Flash Programmer: Error initializing device.
C28xx_0: Flash Programmer: Error erasing Flash memory.
C28xx_0: Trouble Writing Memory Block at 0x13fcc2 on Page 0 of Length 0xcf: (Error -1156 @ 0x4E26) Device may be operating in low-power mode. Do you want to bring it out of this mode? (Release 5.0.429.0)
C28xx_0: Error: (Error -1135 @ 0x8000) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Release 5.0.429.0) http://e2e.ti.com/support/microcontrollers/c2000/f/171/t/279911.aspx chybeyond 发表于 2014-3-25 16:26 static/image/common/back.gif
谢谢分享
页:
[1]
