音频输入输出实验,只听到刺刺的声音,这个是什么原因?
音频输入输出实验,有一点不太明白的是 音频信号是如何采集到的?是要通过音频数据线和外部的音频播放设备连接?按照例程,只能听到刺刺的声音,并没有听到警报声。。。。 程序呢?会不会是声音数据已经在程序里了,不用采集。 什么硬件平台? wangch_sh 发表于 2014-6-1 18:51 static/image/common/back.gif程序呢?会不会是声音数据已经在程序里了,不用采集。
#include <csl.h>
#include <csl_i2c.h>
#include <stdio.h>
#include <csl_pll.h>
#include <csl_mcbsp.h>
#define CODEC_ADDR 0x1A
/*锁相环的设置*/
PLL_ConfigmyConfig = {
0, //IAI: the PLL locks using the same process that was underway
//before the idle mode was entered
1, //IOB: If the PLL indicates a break in the phase lock,
//it switches to its bypass mode and restarts the PLL phase-locking
//sequence
12, //PLL multiply value; multiply 24 times
1 //Divide by 2 PLL divide value; it can be either PLL divide value
//(when PLL is enabled), or Bypass-mode divide value
//(PLL in bypass mode, if PLL multiply value is set to 1)
MCBSP_Config Mcbsptest;
/*设置McBSP,使用McBSP1来发送和接收来自DSP 和 AIC23的数据*/
/*McBSP set,we use mcbsp1 to send and recieve the data between DSP and AIC23*/
MCBSP_Config Mcbsp1Config = {
MCBSP_SPCR1_RMK(
MCBSP_SPCR1_DLB_OFF, /* DLB = 0,禁止数字回环方式 */
MCBSP_SPCR1_RJUST_LZF, /* RJUST= 2 接收数据符号扩展和调节方式*/
MCBSP_SPCR1_CLKSTP_DISABLE, /* CLKSTP = 0 */
MCBSP_SPCR1_DXENA_ON, /* DXENA= 1 DX引脚延时使能打开*/
0, /* ABIS = 0 */
MCBSP_SPCR1_RINTM_RRDY, /* RINTM= 0 接收中断模式*/
0, /* RSYNCER = 0 接收帧同步错误标志*/
MCBSP_SPCR1_RRST_DISABLE /* RRST = 0 禁止接收器复位*/
MCBSP_SPCR2_RMK(
MCBSP_SPCR2_FREE_NO, /* FREE = 0 */
MCBSP_SPCR2_SOFT_NO, /* SOFT = 0 */
MCBSP_SPCR2_FRST_FSG, /* FRST = 0 帧同步逻辑复位 */
MCBSP_SPCR2_GRST_CLKG, /* GRST = 0 采样率发生器复位 */
MCBSP_SPCR2_XINTM_XRDY, /* XINTM= 0 发送中断模式*/
0, /* XSYNCER = N/A */
MCBSP_SPCR2_XRST_DISABLE /* XRST = 0 发送器复位*/
/*单数据相,接受数据长度为16位,每相2个数据*/
MCBSP_RCR1_RMK(
MCBSP_RCR1_RFRLEN1_OF(1), /* RFRLEN1 = 1 接收阶段1的帧长为1个字 */
MCBSP_RCR1_RWDLEN1_16BIT /* RWDLEN1 = 2 接收阶段1的字长为16位 */
MCBSP_RCR2_RMK(
MCBSP_RCR2_RPHASE_SINGLE, /* RPHASE= 0 接收帧的阶段数*/
MCBSP_RCR2_RFRLEN2_OF(0), /* RFRLEN2 = 0 接收阶段2关闭*/
MCBSP_RCR2_RWDLEN2_8BIT, /* RWDLEN2 = 0 接收阶段2的字长为8位*/
MCBSP_RCR2_RCOMPAND_MSB, /* RCOMPAND = 0 接收数据压扩模式*/
MCBSP_RCR2_RFIG_YES, /* RFIG = 0忽略不期望接收的帧同步信号 */
MCBSP_RCR2_RDATDLY_1BIT /* RDATDLY = 1 接收数据延时*/
MCBSP_XCR1_RMK(
MCBSP_XCR1_XFRLEN1_OF(1), /* XFRLEN1 = 1 发送阶段1的帧长(一个)*/
MCBSP_XCR1_XWDLEN1_16BIT /* XWDLEN1 = 2 发送阶段1的字长16位*/
MCBSP_XCR2_RMK(
MCBSP_XCR2_XPHASE_SINGLE, /* XPHASE= 0 */
MCBSP_XCR2_XFRLEN2_OF(0), /* XFRLEN2 = 0 */
MCBSP_XCR2_XWDLEN2_8BIT, /* XWDLEN2 = 0 */
MCBSP_XCR2_XCOMPAND_MSB, /* XCOMPAND = 0 */
MCBSP_XCR2_XFIG_YES, /* XFIG = 0 */
MCBSP_XCR2_XDATDLY_1BIT /* XDATDLY = 1 发送数据延时*/
MCBSP_SRGR1_DEFAULT,
MCBSP_SRGR2_DEFAULT,
MCBSP_MCR1_DEFAULT,
MCBSP_MCR2_DEFAULT,
MCBSP_PCR_RMK(
MCBSP_PCR_IDLEEN_RESET, /* IDLEEN = 0 */
MCBSP_PCR_XIOEN_SP, /* XIOEN = 0 */
MCBSP_PCR_RIOEN_SP, /* RIOEN = 0 */
MCBSP_PCR_FSXM_EXTERNAL, /* FSXM = 0 */
MCBSP_PCR_FSRM_EXTERNAL, /* FSRM = 0 */
0, /* DXSTAT = N/A */
MCBSP_PCR_CLKXM_INPUT, /* CLKXM = 0 */
MCBSP_PCR_CLKRM_INPUT, /* CLKRM = 0 */
MCBSP_PCR_SCLKME_NO, /* SCLKME = 0 */
MCBSP_PCR_FSXP_ACTIVEHIGH, /* FSXP = 0 */
MCBSP_PCR_FSRP_ACTIVEHIGH, /* FSRP = 1 */
MCBSP_PCR_CLKXP_FALLING, /* CLKXP = 1 */
MCBSP_PCR_CLKRP_RISING /* CLKRP = 1 */
MCBSP_RCERA_DEFAULT,
MCBSP_RCERB_DEFAULT,
MCBSP_RCERC_DEFAULT,
MCBSP_RCERD_DEFAULT,
MCBSP_RCERE_DEFAULT,
MCBSP_RCERF_DEFAULT,
MCBSP_RCERG_DEFAULT,
MCBSP_RCERH_DEFAULT,
MCBSP_XCERA_DEFAULT,
MCBSP_XCERB_DEFAULT,
MCBSP_XCERC_DEFAULT,
MCBSP_XCERD_DEFAULT,
MCBSP_XCERE_DEFAULT,
MCBSP_XCERF_DEFAULT,
MCBSP_XCERG_DEFAULT,
MCBSP_XCERH_DEFAULT
/*创建和初始化I2C模块*/
/* This next struct shows how to use the I2C API */
/* Create and initialize an I2C initialization structure */
I2C_Setup I2Cinit = {
0, /* 7 bit address mode */
0, /* own address - don't care if master */
84, /* clkout value (Mhz)*/
50, /* a number between 10 and 400*/
0, /* number of bits/byte to be received or transmitted (8)*/
0, /* DLB mode on*/
1 /* FREE mode of operation on*/
I2C_Config testI2C;
/*数字音频接口格式设置
AIC23为主模式,数据为DSP模式,数据长度16位*/
Uint16 digital_audio_inteface_format={0x0e,0x53};
/*AIC23的波特率设置,采样率为44.1K*/
Uint16 sample_rate_control = {0x10,0x23};
/*AIC23寄存器复位*/
Uint16 reset ={0x1e,0x00};
/*AIC23节电方式设置,所有部分均所与工作状态*/
Uint16 power_down_control ={0x0c,0x03};
/*AIC23模拟音频的控制
DAC使能,ADC输入选择为Line*/
Uint16 analog_aduio_path_control ={0x08,0x10};
/*AIC23数字音频通路的控制*/
Uint16 digital_audio_path_control ={0x0a,0x05};
/*AIC23数字接口的使能*/
Uint16 digital_interface_activation ={0x12,0x01};
/*AIC23左通路音频调节*/
Uint16 left_line_input_volume_control ={0x00,0x17};
/*AIC23右通路音频调节*/
Uint16 right_line_input_volume_control ={0x02,0x17};
/*AIC23耳机左通路音频调节*/
Uint16 left_headphone_volume_control ={0x05,0xFF};
/*AIC23耳机右通路音频调节*/
Uint16 right_headphone_volume_control = {0x07,0xFF};
/*定义McBSP的句柄*/
MCBSP_Handle hMcbsp;
Uint16 i2c_status;
Uint16 i,temp;
void delay(Uint32 k)
while(k--);
void main(void)
Uint16 aic23data = 0;
i2c_status = 1;
/* Initialize CSL library - This is REQUIRED !!! */
/*初始化CSL库*/
CSL_init();
/*设系统的运行速度为140MHz*/
PLL_config(&myConfig);
/* Initialize I2C, using parameters in init structure */
/*初始化I2C的格式*/
// I2C_config(&Config);
// I2C_start();
// I2C_getConfig(&Config1);
/*I2C is undet reset*/
I2C_RSET(I2CMDR,0);
/*设置预分频寄存器,I2C的mode clock is 10MHz*/
delay(100);
I2C_RSET(I2CSAR,0x001A);
I2C_RSET(I2CMDR,0x0620);
I2C_setup(&I2Cinit);
/*设置I2C的Mater clock*/
I2C_RSET(I2CCLKL,100);
I2C_RSET(I2CCLKH,100);
I2C_getConfig(&testI2C);
/*初始化McBSP0*/
hMcbsp = MCBSP_open(MCBSP_PORT1,MCBSP_OPEN_RESET);
/*设置McBSP0*/
MCBSP_config(hMcbsp,&Mcbsp1Config);
/*启动McBSP0*/
MCBSP_start(hMcbsp,
MCBSP_RCV_START | MCBSP_XMIT_START,
0);
MCBSP_getConfig(hMcbsp,&Mcbsptest);
/*reset AIC23*/
i2c_status = I2C_write( reset, //pointer to data array指向发送数据的数组
2, //length of data to be transmitted发送数据的长度16位
1, //master or slaver 主模式
CODEC_ADDR, //slave address to transmit to 从地址发送
1, //transfer mode of operation 传输模式
30000 //time out for bus busy 延时
delay(1000);
/*设置AIC23各部分均工作*/
i2c_status = I2C_write( power_down_control,//pointer to data array 省电控制
/*设置AIC23的数字接口*/
i2c_status = I2C_write( digital_audio_inteface_format,//pointer to data array 数字音频格式
/*设置AIC23模拟通路*/
/* i2c_status = I2C_write( analog_aduio_path_control,//pointer to data array模拟音频格式
/*设置数字通路*/
i2c_status = I2C_write( digital_audio_path_control,//pointer to data array 数字音频通路控制
/*设置AIC23的采样率*/
i2c_status = I2C_write( sample_rate_control,//pointer to data array 采样速率
/*设置耳机音量*/
i2c_status = I2C_write( left_headphone_volume_control,//pointer to data array 耳机左声道音量调节
i2c_status = I2C_write( right_headphone_volume_control,//pointer to data array耳机右声道音量调节
/*设置Line输入的音量*/
i2c_status = I2C_write( left_line_input_volume_control,//pointer to data array左声道音量调节
i2c_status = I2C_write( right_line_input_volume_control,//pointer to data array右声道音量调节
/*启动AIC23*/
i2c_status = I2C_write( digital_interface_activation,//pointer to data array数字接口激活
/*回放音频*/
while(TRUE)
while(!MCBSP_rrdy(hMcbsp)){};
aic23data = MCBSP_read16(hMcbsp);
MCBSP_write16(hMcbsp,aic23data);
* End of i2c2.c
gxliu08 发表于 2014-6-2 20:32 static/image/common/back.gif
什么硬件平台?
TMS320VC5509A 我听到警报声啦,在绿色耳机插孔上插上耳机,运行程序,就能听到。 wangch_sh 发表于 2014-6-3 14:11 static/image/common/back.gif
是这个例程吗?我听得不太像警报声。。那这个警报声是如何采集得到呢?还望解释下 我也不知道怎么采集到的,反正是听到了。 注释掉代码里音频回访部分还有声音吗? 注释掉代码里音频回访部分还有声音吗? 注释掉代码里音频回访部分还有声音吗? gxliu08 发表于 2014-6-4 16:51 static/image/common/back.gif
注释掉代码里音频回访部分还有声音吗?
基本听不到声音。 说明程序中采集以及回放均已工作 gxliu08 发表于 2014-6-4 20:30 static/image/common/back.gif
说明程序中采集以及回放均已工作
但是听到的声音并不是很清晰的警报声,只是刺刺的声音,另外,内部已经完成音频采集,怎么体现的? 用的是什么版本的CCS? amosjie 发表于 2014-12-23 21:39 static/image/common/back.gif
用的是什么版本的CCS?
欢迎新朋友楼主近日没来了
应该是3.3吧 希望你能指教 zhangmangui 发表于 2014-12-25 21:46 static/image/common/back.gif
欢迎新朋友楼主近日没来了
应该是3.3吧 希望你能指教
音频输入输出实验不是听到警报声吧。电脑耳机出口接5509的linein口,电脑播放音乐,能通过5509 的耳机口听到音乐 zhangmangui 发表于 2014-12-25 21:46 static/image/common/back.gif
欢迎新朋友楼主近日没来了
应该是3.3吧 希望你能指教
回复错人了,原来是版主大人,本人小白,还要多多学习请教。 amosjie 发表于 2015-1-4 19:28 static/image/common/back.gif
相互学习各有所长 ttxs_2013 发表于 2014-6-3 13:47 static/image/common/back.gif
TMS320VC5509A
LZ啊,为什么我的连声音都没啊,程序跟你的一样,要想有声音,只能自己定义aic23data的值啊。。
页:
[1]
