wangch_sh 发表于 2014-9-20 11:06
CPLD译码编程的问题
我们公司出了一个DSP5509开发板,用CPLD扩展了好多IO口。
其中蜂鸣器地址
把CPLD烧进去以后,贴片灯正常亮了。
我写蜂鸣器程序,
souraddr =(int *)0x83C000;
    for(;;)
   *souraddr=0xff;
delay();
delay();
*souraddr=0;
delay();
delay();
可是蜂鸣器不响。
请问高手,怎么解决?谢谢!
wangch_sh 发表于 2014-9-20 14:10
高手支招啊!
zhangmangui 发表于 2014-9-20 23:22
首先要配置好EMIF接口
EMIF_Config emiffig = {
0x221,         //EGCR: the MEMFREQ = 00,the clock for the memory is equal to cpu frequence
                        //                  the WPE = 0 ,forbiden the writing posting when we debug the EMIF
                        //      the MEMCEN = 1,the memory clock is reflected on the CLKMEM pin
                        //      the NOHOLD = 1,HOLD requests are not recognized by the EMIF
0xFFFF,        //EMI_RST: any write to this register resets the EMIF state machine
0x3FFF,        //CE0_1:CE0 space control register 1
                        //      MTYPE = 011,Synchronous DRAM(SDRAM),16-bit data bus width
0xFFFF,   //CE0_2:CE0 space control register 2
0x00FF,   //CE0_3:CE0 space control register 3
                        //      TIMEOUT = 0xFF;
0x1FFF,        //CE1_1:CE0 space control register 1
            //      Asynchronous, 16Bit
0xFFFF,        //CE1_2:CE0 space control register 2
0x00FF,        //CE1_3:CE0 space control register 3
0x1FFF,        //CE2_1:CE0 space control register 1
0xFFFF,        //CE2_2:CE0 space control register 2
0x00FF,        //CE2_3:CE0 space control register 3
0x1FFF,        //CE3_1:CE0 space control register 1
0xFFFF,        //CE3_2:CE0 space control register 2
0x00FF,        //CE3_3:CE0 space control register 3
0x2911,   //SDC1:   SDRAM control register 1
                        //                  TRC = 8
                        //      SDSIZE = 0;SDWID = 0
                        //      RFEN = 1
                        //      TRCD = 2
                        //      TRP= 2
0x0410,        //SDPER : SDRAM period register
                        //                  7ns *4096
0x07FF,    //SDINIT: SDRAM initialization register
                        //      any write to this register to init the all CE spaces,
                        //      do it after hardware reset or power up the C55x device
0x0131        //SDC2:          SDRAM control register 2
                        //      SDACC = 0;
                        //      TMRD = 01;
                        //      TRAS = 0101;
                        //      TACTV2ACTV = 0001;
EMIF_config(&emiffig);
zhangmangui 发表于 2014-9-20 23:25
如果EMIF接口配置好了
就考虑你的指针变量定义是否合适
Uint16*souraddr;有没有声明
wangch_sh 发表于 2014-9-21 11:28
int *souraddr,*deminaddr;
EMIF配置有什么需要注意的地方吗?
zhangmangui 发表于 2014-9-22 23:26
关于CSL的EMIF配置 还真没深入研究过
一直用的配置好的代码
页: [1]
查看完整版本: CPLD译码编程的问题
