Maximilianliebe 发表于 2014-10-1 22:44
SRF08超声波传感器和dsPIC33E I2C通信问题
以下是我的代码,实在不知道哪里出了错误,求求大哥们帮忙!!
#include "p33EP512MU810.h"
#include "i2c.h"
#include <Initialisierung.h>
#include "Timer.h"
//Schritt 1
/*Configuring the general features of the microcontroller*/
_FGS(GSS_OFF & GWRP_OFF);
// External Oscillator
_FOSCSEL(FNOSC_PRIPLL);
_FOSC(FCKSM_CSECMD & OSCIOFNC_OFF& POSCMD_XT);
// Clock Switching is enabled and Fail Safe Clock Monitor is disabled
// OSC2 Pin Function: OSC2 is Clock Output
// Primary Oscillator Mode: XT Crystal
_FWDT(FWDTEN_OFF);
// Watchdog Timer Enabled/disabled by user software
_FICD(ICS_PGD3 &JTAGEN_OFF & RSTPRI_PF);
_FPOR( BOREN_ON & ALTI2C1_OFF & ALTI2C2_OFF );
// Brown-out Reset (BOR) Detection Enable bit (BOR is enabled)
// Alternate I2C pins for I2C1 (SDA1/SCK1 pins are selected as the I/O pins for I2C1)
// Alternate I2C pins for I2C2 (SDA2/SCK2 pins are selected as the I/O pins for I2C2)
//Schritt 2
#define CFG_I2C2BRG0x188
// (40MHz/100KHz)-2 = 0x188//I2C2=[(1/Fscl-PGD)*Fcy]-2
#define SONAR1 0xE0
unsigned int get_srf08(unsigned int SONAR);
/*** Global functions for the I2C2******************************************/
main(void)
   unsigned int range1=0;
   f_Initialisierung();
    unsigned int Config1; // ConfigI2c2 represents I2C2CON register.
         Config1 = (   I2C2_ON & I2C2_IDLE_CON & I2C2_CLK_HLD &
                     I2C2_IPMI_DIS & I2C2_7BIT_ADD & I2C2_SLW_DIS &
                     I2C2_SM_DIS & I2C2_GCALL_DIS & I2C2_STR_DIS &
                     I2C2_NACK & I2C2_ACK_DIS & I2C2_RCV_DIS &
                     I2C2_STOP_DIS & I2C2_RESTART_DIS & I2C2_START_DIS
    OpenI2C2(Config1,CFG_I2C2BRG);/*The following function initializes the I2C2 bus and
                                       set the I2C2 Bus Speed to 100KHz I2C2 used to communicate with the Ultrasonic sensors*/
    IdleI2C2();
/*End Configuration I2C2*/
    while(1)
      range1=get_srf08(SONAR1);
//Schritt 3
// Start Condition
unsigned int get_srf08 (unsigned int SONAR)
    unsigned int range;//range=Reichweiten
    unsigned char hi,lo; //high Byte,low Byte
   //StartI2C2();
      I2C2CONbits.SEN=1;         //send start bit
      while(I2C2CONbits.SEN);    //and wait fot it to clear
   //MasterWriteI2C2(SRF08_ADDR);
      MasterWriteI2C2(0xE0);   //SRF08 I2C address
      while(I2C2STATbits.TBF);
      while(!IFS3bits.MI2C2IF);       // Wait for 9th clock cycle.
      while(I2C2STATbits.ACKSTAT);
   //MasterWriteI2C2(0x01);
      MasterWriteI2C2(0x01);    //Verstärkungsregister Adresse
      while(I2C2STATbits.ACKSTAT);       //then clear it
   //MasterWriteI2C2(0x00);
      MasterWriteI2C2(0x00);   //Verstärkung
   //StopI2C2();
         I2C2CONbits.PEN=1;         //send stop bit
         while(I2C2CONbits.PEN);
   //StartI2C2();
   //MasterWriteI2C2(0x02);
      MasterWriteI2C2(0x02);    //Reichweiten-Register Adresse
   //MasterWriteI2C2(0xA0);
      MasterWriteI2C2(0xA0);   //Reichweiten=160    160*43mm+43mm = 6,9m
   //StopI2C2();
//Schritt 4
    /*now wait for the ranging to complete. This delay is 104ms*/
   //Timer off; 16-bit mode; Prescaler 2; Input clk CPU/64
   //delay_ms(80);
      T6CON = 0x0000;
      T6CONbits.TCKPS = 2;
      // Timer6 period 419.424 ms = 2.384222171 Hz
      PR6 = 0xFFFF-0x001;         //w:?
      // 40MHz/64 = 625KHz , 625KHz/65535 = 9.537 Hz
      //                                           = 104,855 ms
      // later on 80ms required form this timer for the utrasonic
      // initializing. the calculation as it shown below:
      //PeriodofChecking80ms      65535
      // --------------------- = --------- ===> PeriodtoCheck
      //          80ms         104,855ms
      IFS2bits.T6IF = 0;                //clear old interrupt request.
      IEC2bits.T6IE = 0;                //disable interrupt.
      T6CONbits.TON = 0;                //switch timer off.
//Schritt 5
      //finally get the range form the SRF08
   //StartI2C2();
    //??????? //MasterWriteI2C2(SRF08_ADDR+1);
      MasterWriteI2C2(0xE0|0x01);   //SRF08 I2C address+Read
      hi = MasterReadI2C2();      //read Most Significant Bit
      AckI2C2();   //start acknowledge sequence
      while(I2C2CONbits.ACKEN);//wait for ack.sequence to end;
      lo = MasterReadI2C2();      //read Least significant Bit
      NotAckI2C2();   //start acknowledge sequence
   //StopI2C2();
      range = ((hi<<8)+lo);
页: [1]
查看完整版本: SRF08超声波传感器和dsPIC33E I2C通信问题
