wangch_sh 发表于 2014-10-22 09:44
DSP编程的问题
我搞DSP编程遇到一个问题。
在程序中有一个函数:
void mdefir1(int l,int iband,float fl,float fh,float fs,int iwindow,
float b[],float w[],int *ierror)
Subroutine mdesfir: To Design FIR Filter By Windowed Fourier Series.
fl:low cut-off frequency. fh:high cut-off(For BP,BS). fl,fh,fs in Hz
Digital filter coefficients are returned in b(l)
                h(z)=b(0)+b(1)z^(-1)+ ... +b(l-1)z^(-l+1)
Input parameters:
   l    : the length of FIR filter.l must be odd.
   iband:iband=1 lowpass FIR filter.
         iband=2 high pass FIR filter.
         iband=3 band pass FIR filter.
         iband=4 band stop FIR filter.
   fln,fhn: the edge frequency desired,in normalized form,0.<=fln,fhn<=.5
          0fln      0fln      0 flnfhn      0flnfhn
             fhn=*       fhn=*
      iband=1 LP    iband=2 HP      iband=3 BP      iband=4 BS
iwindow: window type desired.
         iwindow=1: rectangular window ,   =2: triangular window ,
                  =3: cosin window ,         =4: Hanning window ,
                  =5: Hamming window ,       =6: Blackman window ,
                  =7: Papoulis window .
      w: l dimensioned real work array.
Output parameters:
   b: l dimensioned real array.the result is in b(0) to b(l-1).
   ierror: ierror=0:      no errors detected
               =1:      invalid length(l<=0)
               =2:      invalid window type
               =3:      invalid filter type
               =4:      invalid cut-off frequency
                                    in Chapter 8
      float pi,fln,fhn,wc1,wc2,s;
      int lim,i;
      float dly;
      pi=4.*atan(1.);
      fln=fl/fs;
      fhn=fh/fs;
      for(i=0;i<l;i++) b=0.;
       *ierror=0;
          dly=l/2.;
      lim=l/2;
      if(dly==(float)lim) *ierror=1;
      if(iwindow<1||iwindow>7) *ierror=2;
      if(iband<1||iband>4) *ierror=3;
      if(fln<0.||fln>0.5) *ierror=4;
      if(iband>=3&&fln>=fhn) *ierror=4;
      if(iband>=3&&fhn>=0.5) *ierror=4;
      if(*ierror!=0) return;
      dly-=.5;
      lim-=1;
      wc1=2.*pi*fln;
      if(iband>=3) wc2=2.*pi*fhn;
      mwindow(w,l,iwindow,ierror);
      switch (iband)
              /*Low pass */
             case 1:
                     for(i=0;i<=lim;i++)
                           s=i-dly;
                           b=((sin(wc1*s))/(pi*s));
                           b=b*w;
                           b=b;
                     b[(l-1)/2]=wc1/pi;
                     return;
               /*High pass */
             case 2:
                        for(i=0;i<=lim;i++)
                           {s=i-dly;
                            b=((sin(pi*s)-sin(wc1*s))/(pi*s));
                            b=b*w;
                            b=b;
                           b[(l-1)/2]=1.-wc1/pi;
                           return;
               /*band pass */
             case 3:
                           for(i=0;i<=lim;i++)
                           {s=i-dly;
                              b=((sin(wc2*s)-sin(wc1*s))/(pi*s));
                              b=b*w;
                              b=b;
                              b[(l-1)/2]=(wc2-wc1)/pi;
                              return;
               /*band stop */
             case 4:
                           for(i=0;i<=lim;i++)
                                   {s=i-dly;
                                    b=((sin(wc1*s)+sin(pi*s)-sin(wc2*s))/(pi*s));
                                    b=b*w;
                                    b=b;
                                b[(l-1)/2]=(wc1+pi-wc2)/pi;
                                return;
               default:break;
主程序:
int main()
        int l=29;
    int iband=1;
    float fl=PI/4;
    float fh=PI/3;
    float fs=1000;
    int iwindow=5;
    float b;
    float w;
    int ierror;
    int i;
    float amp;
    float phase;
    //FILE *fp;
    complex x;
    for(i=0;i<N;i++)
         x.real=0;
         x.imag=0;
         //w=(sin((i-14)*PI/6)+sin((i-14))+sin())/
    mdefir1(l,iband,fl,fh,fs,iwindow,b,w,&ierror);
    mfirres(b,28,N,x);
    mampres(x,amp,N,100,0);
        i=6;
        while(1);
这样就好使。
如果改成如下:
int main()
        int l=29;
    int iband=1;
    float fl=PI/4;
    float fh=PI/3;
    float fs=1000;
    int iwindow=5;
    float b;
    float w;
    int *ierror;
    int i;
    float amp;
    float phase;
    //FILE *fp;
    complex x;
    for(i=0;i<N;i++)
         x.real=0;
         x.imag=0;
    mdefir1(l,iband,fl,fh,fs,iwindow,b,w,ierror);
    mfirres(b,28,N,x);
        i=6;
        while(1);
红色的那个地方就运行不过去,出错。
wangch_sh 发表于 2014-10-22 09:49
再详细说明一下。
就是函数void mdefir1(int l,int iband,float fl,float fh,float fs,int iwindow,
有一个参数:int *ierror
我在调用时,如果定义int *ierror;
调用时mdefir1(l,iband,fl,fh,fs,iwindow,b,w,ierror);
这样写,红色的哪行代码*ierror=0;就卡在那儿,过不去。
如果定义成int ierror;
调用时mdefir1(l,iband,fl,fh,fs,iwindow,b,w,&ierror);
就没问题。
我搞不懂,请高手解惑。谢谢!
wangch_sh 发表于 2014-10-22 14:05
高手支招啊!
aresc 发表于 2014-10-22 20:23
不行的那个ierror只是个指针变量,你要让它指到一个整形变量上,类似这种:
int p;
int *ierror = &p;
否则你那个指针没有赋值,就执行非法写操作了。
wangch_sh 发表于 2014-10-23 08:19
谢谢!
不过应该是这样:
int p;
int *ierror;
ierror = &p;
NWPU_CHEN 发表于 2014-10-23 09:45
这应该属于一个指针与内存的问题,指针定义完后,如没有赋给给定可访问的内存地址,那它的地址是随机的,也就是你的ierror所指向地址是随机的,极可能碰到该地址指向内存不能访问(没权利访问),当你子函数赋值的时候会出现不能赋值不能访问这地址的尴尬,程序死到那了,而定义成整形变量后这个变量所在内存区域一定是可以访问的,所以你的&ierror没一点问题,所以用之前一定要给定一个可访问的地址,楼上那位说的也对
wangch_sh 发表于 2014-10-23 10:39
谢谢!
页: [1]
查看完整版本: DSP编程的问题
