lfwh1517 发表于 2014-12-11 15:40
STC单片机和si4463模块调试
单片机STC12LE5A08S2
无线模块si4463
无线模块一直驱动不了求大侠指导
#include "reg51.h"
//#include "radio_config_Si4463.h"
#include <intrins.h>
#define MASTER                  //define:master undefine:slave
#define FOSC      11059200L
#define BAUD      (256 - FOSC / 32 / 2400)
typedef unsigned char BYTE;
typedef unsigned int WORD;
typedef unsigned long DWORD;
sfrAUXR       =   0x8e;       //Auxiliary register
sfr SPSTAT      =   0xcd;       //SPI status register
#define SPIF      0x80      //SPSTAT.7
#define WCOL      0x40      //SPSTAT.6
sfr SPCTL       =   0xce;       //SPI control register
#define SSIG      0x80      //SPCTL.7
#define SPEN      0x40      //SPCTL.6
#define DORD      0x20      //SPCTL.5
#define MSTR      0x10      //SPCTL.4
#define CPOL      0x08      //SPCTL.3
#define CPHA      0x04      //SPCTL.2
#define SPDHH       0x00      //CPU_CLK/4
#define SPDH      0x01      //CPU_CLK/16
#define SPDL      0x02      //CPU_CLK/64
#define SPDLL       0x03      //CPU_CLK/128
sfr SPDAT       =   0xcf;       //SPI data register
sbit SPISS      =   P1^4;       //SPI slave select, connect to slave' SS(P1.4) pin
sbit Irq       =        P3^2;
sbit EZRP_SDN        =        P0^4;
sfr P3M0 = 0xB2; //        0000,0000
sfr P3M1 = 0xB1; //        0000,0000
#define SI_CSN_LOW( )   SPISS=0;
#define SI_CSN_HIGH( )SPISS=1;
#define MAX_CTS_RETRY        2500
void InitUart();
void InitSPI();
void SendUart(BYTE dat);      //send data to PC
BYTE RecvUart();                //receive data from PC
BYTE SPISwap(BYTE dat);         //swap SPI data between master and slave
BYTE bApi_SendCommand(BYTE bCmdLength, BYTE *pbCmdData);
void bSpi_SendDataNoResp(BYTE bCmdLength, BYTE *pbCmdData);
void bSpi_SendDataGetResp(BYTE GetRespLength,BYTE *GetResp);
BYTE vApi_WaitforCTS(void);
BYTE bApi_GetResponse(BYTE bRespLength, BYTE *pbRespData);
void Delay10ms();
void Delay100us();
BYTE abApi_Write={0};
BYTE abApi_Read={0};
void main()
BYTE i;
WORD wDelay;
    InitUart();               //initial UART
    InitSPI();                  //initial SPI
    Irq=1;
// Reset the radio
EZRP_SDN = 1;
// Wait ~300us (SDN pulse width)
for(wDelay=0; wDelay<330; wDelay++);
// Wake up the chip from SDN
EZRP_SDN = 0;
// Wait for POR (power on reset); ~5ms
for(wDelay=0; wDelay<5500; wDelay++);
// Start the radio
for(i=0;i<64;i++)
{abApi_Write=0;}
abApi_Write = 0x02; // Use API command to power up the radio IC
abApi_Write = 0x01; // Write global control registers
abApi_Write = 0x00; // Write global control registers //使用内部晶振
abApi_Write = 0x01; //30M
abApi_Write = 0xc9;
abApi_Write = 0xc3;
abApi_Write = 0x80;
bApi_SendCommand(7,abApi_Write); // Send command to the radio IC
// Wait for boot
while(vApi_WaitforCTS()); // Wait for CTS
// Read CTs, clear pending ones
for(i=0;i<64;i++)
{abApi_Write=0;}
abApi_Write = 0x20; // Use interrupt status command
abApi_Write = 0; // Clear PH_CLR_PEND
abApi_Write = 0; // Clear MODEM_CLR_PEND
abApi_Write = 0; // Clear CHIP_CLR_PEND
bApi_SendCommand(4,abApi_Write); // Send command to the radio IC
for(i=0;i<64;i++)
{abApi_Read=0;}
bApi_GetResponse(8,abApi_Read); // Make sure that CTS is ready, then get the response
while (1)
   for(i=0;i<8;i++)
                     SendUart(abApi_Read);
void InitUart()
    SCON = 0x5a;                //set UART mode as 8-bit variable baudrate
    TMOD = 0x20;                //timer1 as 8-bit auto reload mode
    AUXR = 0x40;                //timer1 work at 1T mode
    TH1 = TL1 = BAUD;         //115200 bps
    TR1 = 1;
void InitSPI()
    SPDAT = 0;                  //initial SPI data
    SPSTAT = SPIF | WCOL;       //clear SPI status
#ifdef MASTER
    SPCTL = SPEN | MSTR | SSIG | CPHA | SPDHH ;      //master mode
#else
    SPCTL = SPEN | CPHA | SPDH ;               //slave mode
#endif
    while (!TI);                //wait pre-data sent
    TI = 0;                     //clear TI flag
    SBUF = dat;               //send current data
BYTE RecvUart()
    while (!RI);                //wait receive complete
    RI = 0;                     //clear RI flag
    return SBUF;                //return receive data
    SPDAT = dat;            //trigger SPI send
    while (!(SPSTAT & SPIF));   //wait send complete
    return SPDAT;               //return received SPI data
BYTE bApi_SendCommand(BYTE bCmdLength, BYTE *pbCmdData) // Send a command + data to the chip
SI_CSN_LOW( ); // select radio IC by pulling its nSEL pin low
bSpi_SendDataNoResp(bCmdLength, pbCmdData); // Send data array to the radio IC via SPI
SI_CSN_HIGH( ); // de-select radio IC by putting its nSEL pin high
return 0;
    while( bCmdLength -- )
      SPISwap( *pbCmdData++ );
    while( GetRespLength -- )
      *GetResp++=SPISwap(0xff);
BYTE bCtsValue = 0;
WORD bErrCnt = 0;
while (bCtsValue!=0xFF) // Wait until radio IC is ready with the data
SendUart(0x06);
SPISwap(0x44); // Read command buffer; send command byte
SendUart(0x07);
bSpi_SendDataGetResp(1, &bCtsValue); // Read command buffer; get CTS value
SendUart(0x10);
SI_CSN_HIGH( ); // If CTS is not 0xFF, put NSS high and stay in waiting
if(++bErrCnt>MAX_CTS_RETRY)
return 1; // Error handling; if wrong CTS reads exceeds a limit
return 0;
BYTE bApi_GetResponse(BYTE bRespLength, BYTE *pbRespData) //Get response from the chip (used after a command)
BYTE bCtsValue = 0;
WORD bErrCnt = 0;
_nop_();
_nop_();
if(bCtsValue!=0xFF)
bSpi_SendDataGetResp(bRespLength, pbRespData); // CTS value ok, get the response data from the radio IC
return 0;
void Delay10ms()       //@11.0592MHz
unsigned char i, j;
i = 108;
j = 145;
do
while (--j);
} while (--i);
void Delay100us()       //@11.0592MHz
unsigned char i, j;
_nop_();
_nop_();
i = 2;
j = 15;
do
while (--j);
} while (--i);
更多 0
ljhaijy01 发表于 2014-12-12 09:47
我也搞这个搞不明白一起讨论一下   你QQ多少啊我加你
ljhaijy01 发表于 2014-12-20 22:05
2B不回复我爷调出来了错误那么明显都看不出来   就不告诉你
武力戡乱 发表于 2014-12-23 21:10
呵呵,至于吗!我qq441747863,正在搞这个。
piaoyuhanxin 发表于 2014-12-25 15:28
我有A7139无线模块驱动程序,以及无线唤醒的解析文档 ,需要的找我QQ:182529743
我有A7139无线模块驱动程序,以及无线唤醒的解析文档 ,需要的找我QQ:182529743 ...
最近也在看无线唤醒,你那个无线唤醒文档能共享下不?
piaoyuhanxin 发表于 2015-1-26 14:03
numenjian 发表于 2015-1-9 10:43 static/image/common/back.gif
可以啊 你加我QQ吧
lijiankun 发表于 2015-10-22 11:38
楼主调通了没,最近也在调试SI4463,可是一直调不通,连无线模块的设备信息都回读不出来,请问最后是怎么调通的,谢谢了
song9644 发表于 2015-10-22 18:58
在北京可合作,QQ:1625422362,
罗乐乐 发表于 2017-4-10 17:27
si4463芯片谁弄过啊,有没有相关资料,麻烦分享一下啊
页: [1]
查看完整版本: STC单片机和si4463模块调试
