用5509配置的SPI ,数据一直写不进,求有心人帮忙看看 分析
本帖最后由 wushaojay 于 2015-1-9 15:09 编辑#include <stdio.h>
#include <csl.h>
#include <csl_pll.h>
#include <csl_gpio.h>
#include <csl_mcbsp.h>
//#include <csl_irq.h>
//---------Global constants---------
#define N 20
/*锁相环的设置*/
PLL_ConfigmyConfig = {
0, //IAI: the PLL locks using the same process that was underway
//before the idle mode was entered
1, //IOB: If the PLL indicates a break in the phase lock,
//it switches to its bypass mode and restarts the PLL phase-locking
//sequence
10, //PLL multiply value; multiply 24 times
1 //Divide by 2 PLL divide value; it can be either PLL divide value
//(when PLL is enabled), or Bypass-mode divide value
//(PLL in bypass mode, if PLL multiply value is set to 1)
//---------Global data definition---------
MCBSP_Config Configclockstop8= {
MCBSP_SPCR1_RMK(
MCBSP_SPCR1_DLB_OFF, /* DLB = 0 禁止数字回环*/
MCBSP_SPCR1_RJUST_RZF, /* RJUST= 0 接收数据符号拓展和调整方式*/
MCBSP_SPCR1_CLKSTP_NODELAY, /* 重要CLKSTP = 10 时钟停止模式 与CLKXP有关*/
MCBSP_SPCR1_DXENA_NA, /* DXENA= 0 DX引脚延时使能*/
MCBSP_SPCR1_ABIS_DISABLE, /* ABIS = 0 关闭abis*/
MCBSP_SPCR1_RINTM_RRDY, /* RINTM= 0 接收中断模式*/
0, /* RSYNCER = 0 接收帧同步错误标志*/
MCBSP_SPCR1_RRST_DISABLE /* RRST = 0 接收器复位*/
MCBSP_SPCR2_RMK(
MCBSP_SPCR2_FREE_NO, /* FREE = 0 */
MCBSP_SPCR2_SOFT_NO, /* SOFT = 0 */
MCBSP_SPCR2_FRST_RESET, /* FRST = 0 */
MCBSP_SPCR2_GRST_RESET, /* GRST = 0 */
MCBSP_SPCR2_XINTM_XRDY, /* XINTM= 0 */
0, /* XSYNCER = N/A */
MCBSP_SPCR2_XRST_DISABLE /* XRST = 0 */
MCBSP_RCR1_RMK(
MCBSP_RCR1_RFRLEN1_OF(0), /* RFRLEN1 = 0 帧长为一字*/
MCBSP_RCR1_RWDLEN1_8BIT /* RWDLEN1 = 0 每字为8bite*/
MCBSP_RCR2_RMK(
MCBSP_RCR2_RPHASE_SINGLE, /* RPHASE= 0 模式一:只与RCR1有关*/
MCBSP_RCR2_RFRLEN2_OF(0), /* RFRLEN2 = 0 */
MCBSP_RCR2_RWDLEN2_8BIT, /* RWDLEN2 = 0 */
MCBSP_RCR2_RCOMPAND_MSB, /* RCOMPAND = 0 非压缩模式*/
MCBSP_RCR2_RFIG_YES, /* 重要RFIG = 0 忽略错误的帧同步信号 */
MCBSP_RCR2_RDATDLY_1BIT /* RDATDLY = 1 延时1bit*/
MCBSP_XCR1_RMK(
MCBSP_XCR1_XFRLEN1_OF(0), /* XFRLEN1 = 0 帧长为一字*/
MCBSP_XCR1_XWDLEN1_8BIT /* XWDLEN1 = 0 每字8bite*/
MCBSP_XCR2_RMK(
MCBSP_XCR2_XPHASE_SINGLE, /* XPHASE= 0 模式一:帧长只与XCR1有关*/
MCBSP_XCR2_XFRLEN2_OF(0), /* XFRLEN2 = 0 */
MCBSP_XCR2_XWDLEN2_8BIT, /* XWDLEN2 = 0 */
MCBSP_XCR2_XCOMPAND_MSB, /* XCOMPAND = 0 不拓展*/
MCBSP_XCR2_XFIG_YES, /* 重要XFIG = 0 忽略错误的帧同步信号*/
MCBSP_XCR2_XDATDLY_1BIT /* XDATDLY =1 发送数据延时1bit*/
MCBSP_SRGR1_RMK(
MCBSP_SRGR1_FWID_OF(0), /* 停止模式无效**重要FWID = 0 帧同步信号的脉宽周期数*/
MCBSP_SRGR1_CLKGDV_OF(5) /* 停止模式无效**重要CLKGDV=9 CLKG时钟频率*/
MCBSP_SRGR2_RMK(
MCBSP_SRGR2_GSYNC_FREE, /* FREE = 0 内部时钟帧同步 */
MCBSP_SRGR2_CLKSP_RISING, /* 重要CLKSP = 0 CLKS 引脚极性*/
MCBSP_SRGR2_CLKSM_INTERNAL, /* 重要CLKSM = 1 cpu时钟*/
MCBSP_SRGR2_FSGM_DXR2XSR, /* FSGM = 0 发送帧同步模式,如果FXSM=1,当DXR->XSR时,McBSP产生帧同步信号*/
MCBSP_SRGR2_FPER_OF(10) /*重要 FPER = 0 FSG信号帧同步时钟周期数,应该是7*/
MCBSP_MCR1_DEFAULT,
MCBSP_MCR2_DEFAULT,
MCBSP_PCR_RMK(
MCBSP_PCR_IDLEEN_RESET, /* IDLEEN = 0 省电使能*/
MCBSP_PCR_XIOEN_SP, /* XIOEN = 0 发送GPIO使能*/
MCBSP_PCR_RIOEN_SP, /* RIOEN = 0 接收GPIO使能*/
MCBSP_PCR_FSXM_INTERNAL, /* 重要FSXM = 1发送帧同步模式,0由FSX引脚提供,1由McBSP提供*/
MCBSP_PCR_FSRM_INTERNAL, /* 重要FSRM = 1 接收帧同步模式,0由FSR引脚提供,1由McBSP提供*/
MCBSP_PCR_CLKXM_OUTPUT, /* 关键CLKXM = 1 主从模式*/
MCBSP_PCR_CLKRM_INPUT, /* 关键CLKRM= 0 主从模式*/
MCBSP_PCR_SCLKME_NO, /* SCLKME = 0 与CLKSM配合使用,cpu时钟模式*/
0, /* DXSTAT = N/A DX引脚上的电平*/
1,//MCBSP_PCR_FSXP_ACTIVELOW, /* 重要FSXP = 0 发送帧同步极性,0正极性,1负极性*/
1,//MCBSP_PCR_FSRP_ACTIVELOW, /* 重要FSRP = 0 接收帧同步极性,0正极性,1负极性*/
MCBSP_PCR_CLKXP_RISING, /* 重要CLKXP = 0 发送时钟极性,0正极性,1负极性*/
MCBSP_PCR_CLKRP_FALLING /* 重要CLKRP = 0 接收时钟极性,0正极性,CLKR引脚上的上升沿,产生CLKG的上升沿,1负极性*/
MCBSP_RCERA_DEFAULT,
MCBSP_RCERB_DEFAULT,
MCBSP_RCERC_DEFAULT,
MCBSP_RCERD_DEFAULT,
MCBSP_RCERE_DEFAULT,
MCBSP_RCERF_DEFAULT,
MCBSP_RCERG_DEFAULT,
MCBSP_RCERH_DEFAULT,
MCBSP_XCERA_DEFAULT,
MCBSP_XCERB_DEFAULT,
MCBSP_XCERC_DEFAULT,
MCBSP_XCERD_DEFAULT,
MCBSP_XCERE_DEFAULT,
MCBSP_XCERF_DEFAULT,
MCBSP_XCERG_DEFAULT,
MCBSP_XCERH_DEFAULT
/* Define a MCBSP_Handle object to be used with MCBSP_open function */
MCBSP_Handle mhMcbsp;
** SPI定义与函数
/*************长延时,待使用*********/
void Delay(unsigned int s)
unsigned int i;
for(i=0; i<s; i++);
for(i=0; i<s; i++);
延时函数,依照时钟频率而定,待使用
void inerDelay_us(unsigned char n)
for(;n>0;n--)
_nop();
函数:uint SPI_RW(uint uchar)
功能:SPI写时序 已修改
Uchar SPI_RW(MCBSP_Handle mh_Mcbsp,Uchar uchar_d)
Uchar get_data;
while(!MCBSP_xrdy(mh_Mcbsp));
MCBSP_write16(mh_Mcbsp,uchar_d); //写寄存器地址
while(!MCBSP_rrdy(mh_Mcbsp));
get_data=MCBSP_read16(mh_Mcbsp); //读寄存器中的值
// printf("%d\n",get_data);
return(get_data); // return read uchar
函数:uchar SPI_Read(uchar reg) 已修改
功能:SPI读时序
Uchar SPI_Read(MCBSP_Handle mh_Mcbsp,Uchar reg)
Uchar reg_val;
SPI_RW(mh_Mcbsp,reg); // 写寄存器地址.
reg_val = SPI_RW(mh_Mcbsp,0); // 读该寄存器中的数据
// printf("%d\n",reg_val);
return(reg_val); // 返回寄存器的值
功能:读写寄存器函数 已修改
Uchar SPI_RW_Reg(MCBSP_Handle mh_Mcbsp,Uchar reg, Uchar value)
Uchar status;
status = SPI_RW(mh_Mcbsp,reg); // 写寄存器地址
_nop(); _nop();
SPI_RW(mh_Mcbsp,value); //写数据到该寄存器
return(status); // 返回写入的数据
** SPI定义与函数
//---------main routine---------
void main(void)
int a;
/*初始化CSL库*/
CSL_init();
/*EMIF为全EMIF接口*/
CHIP_RSET(XBSR,0x0a01);
/*设置系统的运行速度为144MHz*/
PLL_config(&myConfig);
mhMcbsp = MCBSP_open(MCBSP_PORT0, MCBSP_OPEN_RESET);
MCBSP_config(mhMcbsp, &Configclockstop8);
MCBSP_start(mhMcbsp,
MCBSP_RCV_START|MCBSP_XMIT_START|MCBSP_SRGR_START|MCBSP_SRGR_FRAMESYNC,
0x300u);
Delay(100);
while(1)
SPI_RW_Reg(mhMcbsp,0x80,1);
a=SPI_Read(mhMcbsp,0x01);
printf("%d",a);
主要使用SPI配置AD9857寄存器
这是我在示波器上观察的 FSX引脚和 CLKX引脚
FSXP=1设置的是低电平有效 但不知为何观察的波形是这样的
另外CLKX不是连续发送的吗 我观察的波形都是一段一段的 每段8个上升沿
在帧引脚低电平有效的时候,正好是因为8个脉冲时钟上升沿,因为用得无压缩模式,所以采用的是8bit数据传输。
但是在AD9857中 一个通信周期是分两段,先写寄存器地址再写数据,地址八位 数据八位,那么只好要16个时钟周期,而上面设置的SPI一帧(FSX为低电平时)只有8bit,所以我猜是不是这样导致我一直操作不成功。不知道该怎么设置了,感觉这块有点乱 你这是啥型号的DSP,我咋感觉挺别扭呢,SPI怎么跟多路缓冲扯到一块去了 wang168506 发表于 2015-1-9 14:57 static/image/common/back.gif
ti5509 这是我写的专门写0和写1的程序,测试各个引脚的图,这是程序
这是FSX引脚
这是DX
最后两个是CLKX
页:
[1]
