jianhua0722的个人空间 https://bbs.21ic.com/?597102 [收藏] [复制] [RSS]
日志
ISD4002系列语音芯片程序
已有 864 次阅读2009-11-3 08:44 |系统分类:单片机| ISD4002, 语音, 程序
1。两个按键:AN和STOP。
2。一个跳线选择开关P/R,选择放音/录音
3。录音状态下,按住AN键,LED灯亮起,开始录音。直到AN松开,或者芯片溢出(溢出后LED闪烁提示)
     AN松开后生成一段,再次按下则开始录下一段,如此反复。按下STOP后,复位。
4。放音状态下,按下AN键,LED灯亮起,开始放音,知道该段结束,或到芯片末尾。
      再次按下AN键后,放下一段,如此反复。按下STOP后,复位。
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit SS=P1^0;
sbit SCLK=P1^1;
sbit MOSI=P1^2;
sbit MISO=P1^3;
sbit LED=P2^0;
sbit ISD_INT=P3^2;
sbit AN=P1^6;
sbit STOP=P1^5;
sbit PR=P1^4;
void delay(uint time)
 while(time!=0)
  time--;
void delayms(uint time)
 TMOD=0x01;
 for(time;time>0;time--)
  TH0=0xfc;
  TL0=0x18;
  TR0=1;
  while(TF0!=1)
  TF0=0;
  TR0=0;
void spi_send(uchar isdx)
 uchar isx_counter;
 SS=0;
 SCLK=0;
 for(isx_counter=0;isx_counter<8;isx_counter++)
  if((isdx&0x01)==1)
   MOSI=1;
     else
   MOSI=0;
  isdx=isdx>>1;
  SCLK=1;
  delay(2);
  SCLK=0;
  delay(2);
void isd_stop(void)
 delay(10);
 spi_send(0x30);
 SS=1;
 delayms(50);
void isd_pu(void)
 delay(10);
 SS=0;
 spi_send(0x20);
 SS=1;
 delayms(50);
void isd_pd(void)
 delay(10);
 spi_send(0x10);
 SS=1;
 delayms(50);
void isd_play(void)
 LED=0;
 spi_send(0xf0);
 SS=1;
void isd_rec(void)
 LED=0;
 spi_send(0xb0);
 SS=1;
void isd_setplay(uchar adl,uchar adh)
 spi_send(adl);
 adh=adh|0xe0;
 spi_send(adh);
 SS=1;
void isd_setrec(uchar adl,uchar adh)
 spi_send(adl);
 adh=adh|0xa0;
 spi_send(adh);
 SS=1;
void isd_overflow(void)
 while(AN==0)
  LED=1;
  delayms(300);
  LED=0;
  delayms(300);
uchar chk_isdovf(void)
 SS=0;
 delay(2);
 SCLK=0;
 delay(2);
 SCLK=1;
 SCLK=0;
 delay(2);
 if(MISO==1)
  SCLK=0;
  SS=1;
  isd_stop();
  return 1;
 else
  SCLK=0;
  SS=1;
  isd_stop();
  return 0;
void main()
 uchar ovflog;
 while(1)
  P0=P1=P2=P3=0xff;
  while(AN==1)
   if(AN==0)
    delayms(20);
  isd_pu();
  isd_pd();
  isd_pu();
  if(PR==1)
   delayms(500);
   isd_setrec(0x00,0x00);
   do
    isd_rec();
    delay(20);
    while(AN==0)
     if(ISD_INT==0)
     isd_overflow();
    if(ISD_INT==0)
     break;
    LED=1;
    isd_stop();
    while(AN==1)
     if(STOP==0)
     break;
     if(AN==0)
     delayms(500);
   }while(AN==0);
  else
   while(AN==0)
   isd_setplay(0x00,0x00);
   do
    isd_play();
    delay(20);
    while(ISD_INT==1)
    LED=1;
    isd_stop();
    if(ovflog=chk_isdovf())
     break;
    while(AN==1)
     if(STOP==0)
      delayms(20);
     if(STOP==0)
      break;
     if(AN==0)
      delayms(20);
    LED=0;
   }while(AN==0);
  isd_stop();
  isd_pd();
路过
鸡蛋
鲜花
握手
雷人
全部作者的其他最新日志
评论 (0 个评论)
