alexant的笔记 https://bbs.21ic.com/?72205 [收藏] [复制] [RSS] 这里记录的是我上网时发现的一些比较好的文章和比较值得记录的知识,希望对大家有点帮助。
日志
原创:我在项目中使用FreeRTOS的源码连载-makefile
已有 2834 次阅读2007-3-21 19:54 |系统分类:ARM| FreeRTOS, makefile
makefile是什么?我就不多说了,网上资料挺多的。下面直接贴代码:
# Hey Emacs, this is a -*- makefile -*-
# WinARM makefile for the FreeRTOS-demo on LPC2138
# based in information from the FreeRTOS LPC2106 example
# by Martin Thomas, Kaiserslautern, Germany
# <eversmith@heizung-thomas.de>
# based on the WinAVR makefile written by Eric B. Weddington, J鰎g Wunsch, et al.
# Released to the Public Domain
# Please read the make user manual!
# On command line:
# make all = Make software.
# make clean = Clean out built project files.
# make program = Download the hex file to the device
# (TODO: make filename.s = Just compile filename.c into the assembler code only)
# To rebuild project do "make clean" then "make all".
# Changelog:
# - 17. Feb. 2005  - added thumb-interwork support (mth)
# - 28. Apr. 2005  - added C++ support (mth)
# - 29. Arp. 2005  - changed handling for lst-Filename (mth)
# -  1. Nov. 2005  - exception-vector placement options (mth)
# - 15. Nov. 2005  - added library-search-path (EXTRA_LIB...) (mth)
# -  2. Dec. 2005  - fixed ihex and binary file extensions (mth)
# - 22. Feb. 2006  - added AT91LIBNOWARN setting (mth)
# - 19. Apr. 2006  - option FLASH_TOOL (default lpc21isp); variable IMGEXT (mth)
# - 19. Mai. 2006  - USE_THUMB_MODE switch, ROM_RUN->RUN_FROM_ROM RAM_RUN->RUN_FROM_RAM
# - 10. Sep. 2006  - added FRQ_XTL and PLL_MUL settings by alexant.
# - 30. Sep. 2006  - added CODE_PROTECTION settings by alexant.
#FLASH_TOOL = UVISION
#FLASH_TOOL = OPENOCD
# MCU name and submodel
MCU      = arm7tdmi-s
SUBMDL   = lpc2142
#USE_THUMB_MODE = NO
USE_THUMB_MODE = YES
## Create ROM-Image (final)
RUN_MODE=RUN_FROM_ROM
## Create RAM-Image (debugging) - not used in this example
#RUN_MODE=RUN_FROM_RAM
# Configue code read protection
#CODE_PROTECTION = YES
# Processor frequency.
#     This will define a symbol, F_CPU, in all source code files equal to the
#     processor frequency. You can then use this symbol in your source code to
#     calculate timings. Do NOT tack on a 'UL' at the end, this will be done
#     automatically to create a 32-bit value in your source code.
#     Typical values are:
FRQ_XTL = 11059200
# Processor PLL Multiple.
# Note: Must >= 1
PLL_MUL = 2
# Target file name (without extension).
TARGET = rfwm-handset
#### FreeRTOS
RTOS_SRC_DIR   = freertos
RTOS_PORT_DIR  = $(RTOS_SRC_DIR)/portable/GCC/ARM7_LPC2000
# List C source files here. (C dependencies are automatically generated.)
# use file-extension c for "c-only"-files
SRC  = main.c
SRC += rtc/rtc.c
SRC += serial/serial.c
SRC += lcd/lcd_text.c lcd/lcd_graphic.c lcd/lcd_hardware.c
#### FreeRTOS
SRC += $(RTOS_SRC_DIR)/tasks.c
SRC += $(RTOS_SRC_DIR)/list.c
SRC += $(RTOS_SRC_DIR)/queue.c
SRC += $(RTOS_PORT_DIR)/heap_2.c
SRC += $(RTOS_PORT_DIR)/port.c
# List C source files here which must be compiled in ARM-Mode.
#### FreeRTOSSRCARM +=
SRCARM  = $(RTOS_PORT_DIR)/portISR.c
SRCARM += rtc/rtcISR.c
SRCARM += serial/serialISR.c
# List C++ source files here.
# use file-extension cpp for C++-files (use extension .cpp)
CPPSRC =
# List C++ source files here which must be compiled in ARM-Mode.
#CPPSRCARM = $(TARGET).cpp
CPPSRCARM =
# List Assembler source files here.
# Make them always end in a capital .S.  Files ending in a lowercase .s
# will not be considered source files but generated files (assembler
# output from the compiler), and will be deleted upon "make clean"!
# Even though the DOS/Win* filesystem matches both .s and .S the same,
# it will preserve the spelling of the filenames, and gcc itself does
# care about how the name is spelled on its command-line.
ASRC =
# List Assembler source files here which must be assembled in ARM-Mode..
ASRCARM  = startup.S
## Output format. (can be ihex or binary)
## (binary i.e. for openocd and SAM-BA, hex i.e. for lpc21isp and uVision)
FORMAT = ihex
#FORMAT = binary
# Optimization level, can be [0, 1, 2, 3, s].
# 0 = turn off optimization. s = optimize for size.
# (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
OPT = s
#OPT = 0
# Debugging format.
# Native formats for AVR-GCC's -g are stabs [default], or dwarf-2.
# AVR (extended) COFF requires stabs, plus an avr-objcopy run.
#DEBUG = stabs
DEBUG = dwarf-2
# List any extra directories to look for include files here.
#     Each directory must be seperated by a space.
#### FreeRTOS
EXTRAINCDIRS  =  ./serial ./rtc ./rf ./lcd ./storage
EXTRAINCDIRS +=  $(RTOS_PORT_DIR)
EXTRAINCDIRS +=  $(RTOS_SRC_DIR)/include
# List any extra directories to look for library files here.
#EXTRA_LIBDIRS = ../arm7_efsl_0_2_4
EXTRA_LIBDIRS =
## Using the Atmel AT91_lib produces warning with
## the default warning-levels.
## yes - disable these warnings; no - keep default settings
#AT91LIBNOWARN = yes
AT91LIBNOWARN = no
# Compiler flag to set the C Standard level.
# c89   - "ANSI" C
# gnu89 - c89 plus GCC extensions
# c99   - ISO C99 standard (not yet fully implemented)
# gnu99 - c99 plus GCC extensions
CSTANDARD = -std=gnu99
# Place -D or -U options for C here
CDEFS =  -D$(RUN_MODE)
CDEFS += -DFRQ_XTL=$(FRQ_XTL)UL
CDEFS += -DPLL_MUL=$(PLL_MUL)
#### FreeRTOS
CDEFS += -DGCC_ARM7
# Place -I options here
CINCS =
# Place -D or -U options for ASM here
ADEFS =  -D$(RUN_MODE)
ADEFS += -DFRQ_XTL=$(FRQ_XTL)UL
ADEFS += -DPLL_MUL=$(PLL_MUL)
ifeq ($(CODE_PROTECTION),YES)
ADEFS += -DCODE_PROTECTION
endif
ifdef VECTOR_LOCATION
CDEFS += -D$(VECTOR_LOCATION)
ADEFS += -D$(VECTOR_LOCATION)
endif
CDEFS += -D__WinARM__
ADEFS += -D__WinARM__
ifeq ($(USE_THUMB_MODE),YES)
THUMB    = -mthumb
THUMB_IW = -mthumb-interwork
#### FreeRTOS
CDEFS   += -D THUMB_INTERWORK
endif
# Compiler flags.
#  -g*:          generate debugging information
#  -O*:          optimization level
#  -f...:        tuning, see GCC manual and avr-libc documentation
#  -Wall...:     warning level
#  -Wa,...:      tell GCC to pass this to the assembler.
#    -adhlns...: create assembler listing
# Flags for C and C++ (arm-elf-gcc/arm-elf-g++)
CFLAGS = -g$(DEBUG)
CFLAGS += $(CDEFS) $(CINCS)
CFLAGS += -O$(OPT)
CFLAGS += -Wall -Wextra  -Wimplicit -Wcast-align
CFLAGS +=  -Wswitch -Wpointer-arith
#-Wredundant-decls
CFLAGS +=  -Wreturn-type -Wshadow -Wunused
CFLAGS += -Wbad-function-cast -Wsign-compare -Waggregate-return
CFLAGS += -Wa,-adhlns=$(subst $(suffix $<),.lst,$<)
CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
# flags only for C
#-Wnested-externs
CONLYFLAGS +=
CONLYFLAGS += $(CSTANDARD)
ifneq ($(AT91LIBNOWARN),yes)
#AT91-lib warnings with:
#CFLAGS += -Wcast-qual
#CONLYFLAGS += -Wmissing-prototypes
CONLYFLAGS += -Wstrict-prototypes
#CONLYFLAGS += -Wmissing-declarations
endif
# flags only for C++ (arm-elf-g++)
# CPPFLAGS = -fno-rtti -fno-exceptions
CPPFLAGS =
# Assembler flags.
#  -ahlns:     create listing
#  -g$(DEBUG): have the assembler create line number information
ASFLAGS = $(ADEFS) -Wa,-adhlns=$(<:.S=.lst),--g$(DEBUG)
#Additional libraries.
# Extra libraries
#    Each library-name must be seperated by a space.
#    To add libxyz.a, libabc.a and libefsl.a:
#    EXTRA_LIBS = xyz abc efsl
#EXTRA_LIBS = efsl
EXTRA_LIBS =
#Support for newlibc-lpc (file: libnewlibc-lpc.a)
#NEWLIBLPC = -lnewlib-lpc
MATH_LIB = -lm
# CPLUSPLUS_LIB = -lstdc++
# Linker flags.
#  -Wl,...:     tell GCC to pass this to linker.
#    -Map:      create map file
#    --cref:    add cross reference to  map file
LDFLAGS = -nostartfiles -Wl,-Map=$(TARGET).map,--cref
LDFLAGS += -lc
LDFLAGS += $(NEWLIBLPC) $(MATH_LIB)
LDFLAGS += -lc -lgcc
LDFLAGS += $(CPLUSPLUS_LIB)
LDFLAGS += $(patsubst %,-L%,$(EXTRA_LIBDIRS))
LDFLAGS += $(patsubst %,-l%,$(EXTRA_LIBS))
# Set Linker-Script Depending On Selected Memory and Controller
ifeq ($(RUN_MODE),RUN_FROM_RAM)
LDFLAGS +=-T$(SUBMDL)-RAM.ld
else
LDFLAGS +=-T$(SUBMDL)-ROM.ld
endif
# Flash-Programming support using lpc21isp by Martin Maurer
# only for Philips LPC and Analog ADuC ARMs
# Settings and variables:
#LPC21ISP = lpc21isp
LPC21ISP = lpc21isp
LPC21ISP_PORT = com1
LPC21ISP_BAUD = 57600
LPC21ISP_XTAL = 11059
LPC21ISP_FLASHFILE = $(TARGET).hex
# verbose output:
#LPC21ISP_DEBUG = -debug
# enter bootloader via RS232 DTR/RTS (only if hardware supports this
# feature - see Philips AppNote):
LPC21ISP_CONTROL = -control
# Define directories, if needed.
## DIRARM = c:/WinARM/
## DIRARMBIN = $(DIRAVR)/bin/
## DIRAVRUTILS = $(DIRAVR)/utils/bin/
# Define programs and commands.
SHELL = sh
CC = arm-elf-gcc
CPP = arm-elf-g++
OBJCOPY = arm-elf-objcopy
OBJDUMP = arm-elf-objdump
SIZE = arm-elf-size
NM = arm-elf-nm
REMOVE = rm -f
COPY = cp
# Define Messages
# English
MSG_ERRORS_NONE = Errors: none
MSG_BEGIN = "-------- begin (mode: $(RUN_MODE)) --------"
MSG_END = --------  end  --------
MSG_SIZE_BEFORE = Size before:
MSG_SIZE_AFTER = Size after:
MSG_FLASH = Creating load file for Flash:
MSG_EXTENDED_LISTING = Creating Extended Listing:
MSG_SYMBOL_TABLE = Creating Symbol Table:
MSG_LINKING = Linking:
MSG_COMPILING = Compiling C:
MSG_COMPILING_ARM = "Compiling C (ARM-only):"
MSG_COMPILINGCPP = Compiling C++:
MSG_COMPILINGCPP_ARM = "Compiling C++ (ARM-only):"
MSG_ASSEMBLING = Assembling:
MSG_ASSEMBLING_ARM = "Assembling (ARM-only):"
MSG_CLEANING = Cleaning project:
MSG_FORMATERROR = Can not handle output-format
MSG_LPC21_RESETREMINDER = You may have to bring the target in bootloader-mode now.
# Define all object files.
COBJ      = $(SRC:.c=.o)
AOBJ      = $(ASRC:.S=.o)
COBJARM   = $(SRCARM:.c=.o)
AOBJARM   = $(ASRCARM:.S=.o)
CPPOBJ    = $(CPPSRC:.cpp=.o)
CPPOBJARM = $(CPPSRCARM:.cpp=.o)
# Define all listing files.
LST = $(ASRC:.S=.lst) $(ASRCARM:.S=.lst) $(SRC:.c=.lst) $(SRCARM:.c=.lst)
LST += $(CPPSRC:.cpp=.lst) $(CPPSRCARM:.cpp=.lst)
# Compiler flags to generate dependency files.
### GENDEPFLAGS = -Wp,-M,-MP,-MT,$(*F).o,-MF,.dep/$(@F).d
GENDEPFLAGS = -MD -MP -MF .dep/$(@F).d
# Combine all necessary flags and optional flags.
# Add target processor to flags.
ALL_CFLAGS  = -mcpu=$(MCU) $(THUMB_IW) -I. $(CFLAGS) $(GENDEPFLAGS)
ALL_ASFLAGS = -mcpu=$(MCU) $(THUMB_IW) -I. -x assembler-with-cpp $(ASFLAGS)
# Default target.
all: begin gccversion sizebefore build sizeafter finished end
ifeq ($(FORMAT),ihex)
build: elf hex lss sym
hex: $(TARGET).hex
IMGEXT=hex
else
ifeq ($(FORMAT),binary)
build: elf bin lss sym
bin: $(TARGET).bin
IMGEXT=bin
else
$(error "$(MSG_FORMATERROR) $(FORMAT)")
endif
endif
elf: $(TARGET).elf
lss: $(TARGET).lss
sym: $(TARGET).sym
# Eye candy.
begin:
 @echo
 @echo $(MSG_BEGIN)
finished:
 @echo $(MSG_ERRORS_NONE)
end:
 @echo $(MSG_END)
 @echo
# Display size of file.
HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
ELFSIZE = $(SIZE) -B $(TARGET).elf
sizebefore:
 @if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); echo; fi
sizeafter:
 @if [ -f $(TARGET).elf ]; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); echo; fi
# Display compiler version information.
gccversion :
 @$(CC) --version
# Program the device.
ifeq ($(FLASH_TOOL),UVISION)
# Program the device with Keil's uVision (needs configured uVision-Workspace).
program: $(TARGET).$(IMGEXT)
 @echo
 @echo "Programming with uVision"
 C:\Keil\uv3\Uv3.exe -f uvisionflash.Uv2 -ouvisionflash.txt
else
ifeq ($(FLASH_TOOL),OPENOCD)
# Program the device with Dominic Rath's OPENOCD in "batch-mode", needs cfg and "reset-script".
 @echo
 @echo "Programming with OPENOCD"
 C:\WinARM\utils\openocd\openocd_svn59\openocd.exe -f oocd_sam7_flash.cfg
else
# Program the device.  - lpc21isp will not work for SAM7
 @echo
 @echo $(MSG_LPC21_RESETREMINDER)
 $(LPC21ISP) $(LPC21ISP_CONTROL) $(LPC21ISP_DEBUG) $(LPC21ISP_FLASHFILE) $(LPC21ISP_PORT) $(LPC21ISP_BAUD) $(LPC21ISP_XTAL)
endif
endif
# Create final output file (.hex) from ELF output file.
%.hex: %.elf
 @echo
 @echo $(MSG_FLASH) $@
 $(OBJCOPY) -O $(FORMAT) $< $@
# Create final output file (.bin) from ELF output file.
%.bin: %.elf
 @echo
# Create extended listing file from ELF output file.
# testing: option -C
%.lss: %.elf
 @echo
 @echo $(MSG_EXTENDED_LISTING) $@
 $(OBJDUMP) -h -S -C $< > $@
# Create a symbol table from ELF output file.
%.sym: %.elf
 @echo
 @echo $(MSG_SYMBOL_TABLE) $@
 $(NM) -n $< > $@
# Link: create ELF output file from object files.
.SECONDARY : $(TARGET).elf
.PRECIOUS : $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ) $(CPPOBJ) $(CPPOBJARM)
%.elf:  $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ) $(CPPOBJ) $(CPPOBJARM)
 @echo
 @echo $(MSG_LINKING) $@
 $(CC) $(THUMB) $(ALL_CFLAGS) $(AOBJARM) $(AOBJ) $(COBJARM) $(COBJ) $(CPPOBJ) $(CPPOBJARM) --output $@ $(LDFLAGS)
# Compile: create object files from C source files. ARM/Thumb
$(COBJ) : %.o : %.c
 @echo
 @echo $(MSG_COMPILING) $<
 $(CC) -c $(THUMB) $(ALL_CFLAGS) $(CONLYFLAGS) $< -o $@
# Compile: create object files from C source files. ARM-only
$(COBJARM) : %.o : %.c
 @echo
 @echo $(MSG_COMPILING_ARM) $<
 $(CC) -c $(ALL_CFLAGS) $(CONLYFLAGS) $< -o $@
# Compile: create object files from C++ source files. ARM/Thumb
$(CPPOBJ) : %.o : %.cpp
 @echo
 @echo $(MSG_COMPILINGCPP) $<
 $(CPP) -c $(THUMB) $(ALL_CFLAGS) $(CPPFLAGS) $< -o $@
# Compile: create object files from C++ source files. ARM-only
$(CPPOBJARM) : %.o : %.cpp
 @echo
 @echo $(MSG_COMPILINGCPP_ARM) $<
 $(CPP) -c $(ALL_CFLAGS) $(CPPFLAGS) $< -o $@
# Compile: create assembler files from C source files. ARM/Thumb
## does not work - TODO - hints welcome
##$(COBJ) : %.s : %.c
## $(CC) $(THUMB) -S $(ALL_CFLAGS) $< -o $@
# Assemble: create object files from assembler source files. ARM/Thumb
$(AOBJ) : %.o : %.S
 @echo
 @echo $(MSG_ASSEMBLING) $<
 $(CC) -c $(THUMB) $(ALL_ASFLAGS) $< -o $@
# Assemble: create object files from assembler source files. ARM-only
$(AOBJARM) : %.o : %.S
 @echo
 @echo $(MSG_ASSEMBLING_ARM) $<
 $(CC) -c $(ALL_ASFLAGS) $< -o $@
# Target: clean project.
clean: begin clean_list finished end
clean_list :
 @echo
 @echo $(MSG_CLEANING)
 $(REMOVE) ../Common_WinARM/$(TARGET).hex
 $(REMOVE) $(TARGET).hex
 $(REMOVE) $(TARGET).bin
 $(REMOVE) $(TARGET).obj
 $(REMOVE) $(TARGET).elf
 $(REMOVE) $(TARGET).map
 $(REMOVE) $(TARGET).a90
 $(REMOVE) $(TARGET).sym
 $(REMOVE) $(TARGET).lnk
 $(REMOVE) $(TARGET).lss
 $(REMOVE) $(COBJ)
 $(REMOVE) $(CPPOBJ)
 $(REMOVE) $(AOBJ)
 $(REMOVE) $(COBJARM)
 $(REMOVE) $(CPPOBJARM)
 $(REMOVE) $(AOBJARM)
 $(REMOVE) $(LST)
 $(REMOVE) $(SRC:.c=.s)
 $(REMOVE) $(SRC:.c=.d)
 $(REMOVE) $(SRCARM:.c=.s)
 $(REMOVE) $(SRCARM:.c=.d)
 $(REMOVE) $(CPPSRC:.cpp=.s)
 $(REMOVE) $(CPPSRC:.cpp=.d)
 $(REMOVE) $(CPPSRCARM:.cpp=.s)
 $(REMOVE) $(CPPSRCARM:.cpp=.d)
 $(REMOVE) .dep/*
# Include the dependency files.
-include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
# Listing of phony targets.
.PHONY : all begin finish end sizebefore sizeafter gccversion \
build elf hex bin lss sym clean clean_list program
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
