[USB接口] USB3.0控制器件FT600 USB to FIFO bridge
2999|4
 楼主| caijin 发表于 2015-7-14 17:06 | 显示全部楼层 |阅读模式
批量6美金,规格参数如下,有意联系:
 Supports USB 3.0 Super Speed (5Gbps)/USB 2.0 High Speed (480Mbps)/USB 2.0 Full Speed (12Mbps) transfer.
 Supported USB Transfer Type: Control/Bulk/Interrupt
 Up to 8 configurable endpoints (PIPEs).
 Supports 2 parallel slave FIFO bus protocols, data bursting rate is up to 400MB/s.
 Supports 4 IN channels and 4 OUT channels on FIFO bus connectivity.
 Built-in 16kB FIFO data buffer RAM.
 Supports Remote Wakeup capability.
 Supports multi voltage I/O: 1.8V, 2.5V and 3.3V.
 Configurable GPIO support.
 Internal LDO 1.0V regulator.
 Integrated power-on-reset circuit.
 User programmable USB descriptors.
 Supports Battery Charging spec. BC1.2.
 Available as FT600-16bit/FT601-32bit FIFO interface.
 Industrial operating temperature range: -40 to 85⁰C.
 Available in compact Pb-free QFN-76(32bit) and QFN-56(16bit) packages (both RoHS compliant).
hexenzhou 发表于 2015-7-21 11:21 来自手机 | 显示全部楼层
cool,现在有供货吗?
 楼主| caijin 发表于 2015-7-22 09:38 | 显示全部楼层
cool,现在有供货吗?
有的。。。。
hevry 发表于 2015-8-21 20:54 | 显示全部楼层
有意思,请发Datasheet,hevry_jon*126.com,*换成@
 楼主| caijin 发表于 2015-8-24 09:51 | 显示全部楼层
个人签名:库存好无线鼠标9元一个,5个起包邮,有意联系微信,13560797469。提供蓝牙双模模块。
66
