[技术问答]
新唐M051 pwm使用程序
1364|6
仙女山|  楼主 | 2015-7-16 15:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "PWM.h"
#define EN_EXT_OSC       0
#define COMPLEMENT_MODE         0x00000020
#define DEAD_ZONE_INTERVAL      0xC8FF0000
#define PWM_ENABLE              0x01010101
#if     EN_EXT_OSC
#define PWM_CLOCK_SOURCE        0x00000000  //使用外部振荡12MHz
#else
#define PWM_CLOCK_SOURCE        0xF0000000  //使用内部RC振荡22.1184MHz
#endif
#define PWM_PRESCALAE           0x0000C731  //PWM01预分频0x31(49),PWM23预分频0xC7(199)
#define PWM_CLOCK_DIVIDER       0x00004444  //输入时钟分频1
#define PWM_OUTPUT_INVERT       0x00040000
#define PWM_OUTPUT_ENABLE       0x0000000F   //PWM0、1、2、3输出使能
#define PWM_CMR_VALUE   0x0
#define PWM_CNR_VALUE       0x1000      //4096
PWM频率=PWMxy_CLK/(prescale+1)*(clock divider)/(CNR+1)
(1)使用外部晶振12MHz
PWM频率=12000000/(49+1)*4097 =58.57Hz
(2)使用内部RC振荡22.1184MHz
PWM频率=22118400/(49+1)*4097 =107.97Hz
#define LED_DARKING             0
#define LED_BRIGHTING   1
STATIC UINT32 g_unPWMCMRValue=PWM_CNR_VALUE;
STATIC UINT32 g_unLedStat=LED_DARKING;
*函数名称:PWMInit
*输    入:无
*输    出:无
*功    能:PWM初始化
VOID PWMInit(VOID)
    P2_MFP |= ~(P20_AD8_PWM0 | P21_AD9_PWM1 | P22_AD10_PWM2 | P23_AD11_PWM3);
P2_MFP |= (PWM0 | PWM1 | PWM2 | PWM3);   //使能P2.0~P2.3为PWM输出
    P2_PMD &= ~Px0_PMD;                       //配置P2.0~P2.3为推挽输出
P2_PMD |= Px0_OUT;
P2_PMD &= ~Px1_PMD;
P2_PMD |= Px1_OUT;
P2_PMD &= ~Px2_PMD;
P2_PMD |= Px2_OUT;
P2_PMD &= ~Px3_PMD;
P2_PMD |= Px3_OUT;
    APBCLK |= PWM01_CLKEN | PWM23_CLKEN;                        //使能PWM0~3时钟
CLKSEL1 = PWM_CLOCK_SOURCE;                 //选择PWM0~3时钟源
PPRA = PWM_PRESCALAE | DEAD_ZONE_INTERVAL;                  //选择PWM0~3时钟预分频和死区间隔
    CSRA = PWM_CLOCK_DIVIDER;                                   //选择PWM0~3时钟分频
    PCRA = 0x08080808 | PWM_OUTPUT_INVERT | COMPLEMENT_MODE;    //PWM0~3自动重装载
    CNR0A = CNR1A = CNR2A = CNR3A = PWM_CNR_VALUE;              //PWM0~3计数值
    CMR0A = CMR1A = CMR2A = CMR3A = PWM_CMR_VALUE;              //PWM0~3比较值
    PIERA  |= PWMIE3 | PWMIE2 | PWMIE1 | PWMIE0 ;    //使能PWM0~3中断
    NVIC_ISER |= PWMA_INT;                                      //使能PWM0~3中断
    POEA = PWM_OUTPUT_ENABLE;                                   //PWM输出使能
    PCRA |= PWM_ENABLE;                                         //PWM使能,启动
*函数名称:PWMA_IRQHandler
*输    入:无
*输    出:无
*功    能:中断服务函数-PWMA
VOID PWMA_IRQHandler(VOID)
  switch(g_unLedStat)            //检查LED状态
   case  LED_DARKING:         //LED状态渐暗
    if(g_unPWMCMRValue < PWM_CNR_VALUE)
     g_unPWMCMRValue+=50;
    else
       g_unLedStat = LED_BRIGHTING;
  }break;
  case  LED_BRIGHTING:         //LED状态渐亮
    if(g_unPWMCMRValue>=50)
     g_unPWMCMRValue-=50;
    else
       g_unLedStat = LED_DARKING;
     g_unPWMCMRValue=PWM_CMR_VALUE;
  }break;
  default:break;
  CMR0A = CMR1A = CMR2A = CMR3A = g_unPWMCMRValue;  //设置PWM0~3比较值
     PIIRA = PIIRA;
*函数名称:main
*输    入:无
*输    出:无
*功    能:函数主体
INT32 main(VOID)
   PROTECT_REG                         //ISP下载时保护FLASH存储器
   PWRCON |= XTL12M_EN;                   //默认时钟源为外部晶振
   while((CLKSTATUS & XTL12M_STB) == 0);                //等待12MHz时钟稳定
   CLKSEL0 = (CLKSEL0 & (~HCLK)) | HCLK_12M;              //设置外部晶振为系统时钟
   PWMInit();              //PWM初始化
     while(1);
643757107| | 2015-7-16 19:22 | 只看该作者
这个不知道是如何实现时钟稳定判断的。
734774645| | 2015-7-16 20:09 | 只看该作者
这种连续赋值挺有意思。
598330983| | 2015-7-16 21:24 | 只看该作者
VOID PWMInit(VOID)
P2_PMD |= Px0_OUT;
P2_PMD &= ~Px1_PMD;
P2_PMD |= Px1_OUT;
P2_PMD &= ~Px2_PMD;
P2_PMD |= Px2_OUT;
P2_PMD &= ~Px3_PMD;
P2_PMD |= Px3_OUT;
初始化好麻烦,封装起来容易多了。
mintspring| | 2015-7-17 09:16 | 只看该作者
*函数名称:PWMInit
*输    入:无
*输    出:无
*功    能:PWM初始化
VOID PWMInit(VOID)
这种无输入无输出的,更不应该放主函数里。
598330983| | 2015-7-17 15:16 | 只看该作者
初始化那一段,是可以修改的吗?
李香兰| | 2015-7-18 22:06 | 只看该作者
时硬件pwm,不是模拟出来的
