[ZLG-ARM] LPC1000 的芯片成熟了没有?
2660|6
 楼主| TRUE_ARM 发表于 2008-9-27 12:41 | 显示全部楼层 |阅读模式
不知道12 ADC 性能怎么样呢?
发表于 2008-9-27 16:04 | 显示全部楼层
hehe...
zlgarm 发表于 2008-9-27 17:53 | 显示全部楼层
RE:TRUE_ARM
呵呵、、、<br />第四季度出样片。。。。
linghu886 发表于 2008-9-27 22:21 | 显示全部楼层
Q4?
黄金周过后就是Q4了<br />看样子就快了<br />第四季度可以这样理解了吧?<br />也就几十天而已了<br />不知道<br />资料是否已经写好了<br />
发表于 2008-9-28 09:18 | 显示全部楼层
呵呵.估计的明年了...一般都迟后..
林枫 发表于 2008-10-14 22:11 | 显示全部楼层
关注
linghu886 发表于 2008-10-15 12:23 | 显示全部楼层
以后我们都直接到ARM的官方网站看
http://www.arm.com/iqonline/news/partnernews/23194.html<br /><br />07&nbsp;October&nbsp;2008<br /><br /><br />NXP&nbsp;Rolls&nbsp;Out&nbsp;Speedy&nbsp;MCUs&nbsp;Based&nbsp;On&nbsp;ARM&nbsp;Cortex-M3<br /><br />NXP&nbsp;Semiconductors,&nbsp;the&nbsp;independent&nbsp;semiconductor&nbsp;company&nbsp;founded&nbsp;by&nbsp;Philips,&nbsp;has&nbsp;take&nbsp;the&nbsp;wraps&nbsp;of&nbsp;the&nbsp;LPC1700&nbsp;series,&nbsp;which&nbsp;it&nbsp;says&nbsp;are&nbsp;the&nbsp;the&nbsp;industry’s&nbsp;fastest&nbsp;microcontroller&nbsp;family&nbsp;based&nbsp;on&nbsp;the&nbsp;ARM&nbsp;Cortex-M3&nbsp;processor.<br /><br />NXP&nbsp;said&nbsp;that&nbsp;with&nbsp;running&nbsp;speeds&nbsp;up&nbsp;to&nbsp;100&nbsp;MHz,&nbsp;the&nbsp;LPC1700&nbsp;series&nbsp;of&nbsp;microcontrollers&nbsp;operates&nbsp;from&nbsp;28&nbsp;–&nbsp;64%&nbsp;faster&nbsp;than&nbsp;any&nbsp;competitive&nbsp;Cortex-M3&nbsp;microcontroller&nbsp;available&nbsp;today.&nbsp;This&nbsp;performance&nbsp;enables&nbsp;the&nbsp;LPC1700&nbsp;series&nbsp;to&nbsp;operate&nbsp;high-bandwidth&nbsp;communications&nbsp;peripherals&nbsp;such&nbsp;as&nbsp;Ethernet,&nbsp;USB&nbsp;On-The-Go/Host/Device,&nbsp;and&nbsp;CAN&nbsp;simultaneously&nbsp;without&nbsp;bottlenecks.&nbsp;The&nbsp;LPC1700&nbsp;series&nbsp;targets&nbsp;a&nbsp;wide&nbsp;range&nbsp;of&nbsp;applications,&nbsp;including&nbsp;eMetering,&nbsp;lighting,&nbsp;industrial&nbsp;networking,&nbsp;alarm&nbsp;systems,&nbsp;white&nbsp;goods&nbsp;and&nbsp;motor&nbsp;control.<br /><br />The&nbsp;LPC1700,&nbsp;based&nbsp;on&nbsp;the&nbsp;Cortex-M3&nbsp;Revision&nbsp;2&nbsp;core,&nbsp;adds&nbsp;tightly&nbsp;integrated&nbsp;power&nbsp;control,&nbsp;including&nbsp;a&nbsp;unique&nbsp;Wake-up&nbsp;Interrupt&nbsp;Controller&nbsp;(WIC).&nbsp;In&nbsp;addition,&nbsp;the&nbsp;LPC1700&nbsp;is&nbsp;pin-to-pin&nbsp;compatible&nbsp;with&nbsp;the&nbsp;ARM7-based&nbsp;NXP&nbsp;LPC2300&nbsp;series.&nbsp;This&nbsp;compatibility&nbsp;allows&nbsp;customers&nbsp;to&nbsp;evaluate&nbsp;both&nbsp;the&nbsp;Cortex-M3&nbsp;and&nbsp;ARM7-based&nbsp;products&nbsp;in&nbsp;the&nbsp;same&nbsp;socket&nbsp;and&nbsp;to&nbsp;choose&nbsp;the&nbsp;right&nbsp;microcontrollers&nbsp;for&nbsp;their&nbsp;applications,&nbsp;NXP&nbsp;said.<br /><br />“LPC1700&nbsp;is&nbsp;the&nbsp;fastest&nbsp;Cortex-M3&nbsp;microcontrollers&nbsp;available,&nbsp;and&nbsp;has&nbsp;been&nbsp;designed&nbsp;for&nbsp;customers&nbsp;requiring&nbsp;simultaneous&nbsp;high&nbsp;bandwidth&nbsp;data&nbsp;streams&nbsp;from&nbsp;Ethernet,&nbsp;USB&nbsp;and&nbsp;CAN,”&nbsp;said&nbsp;Geoff&nbsp;Lees,&nbsp;vice&nbsp;president&nbsp;and&nbsp;general&nbsp;manager,&nbsp;microcontroller&nbsp;product&nbsp;line,&nbsp;NXP&nbsp;Semiconductors.&nbsp;“As&nbsp;always,&nbsp;we&nbsp;are&nbsp;committed&nbsp;to&nbsp;offering&nbsp;our&nbsp;customers&nbsp;the&nbsp;broadest&nbsp;range&nbsp;of&nbsp;choice&nbsp;available&nbsp;in&nbsp;32-bit&nbsp;MCUs.”<br /><br />The&nbsp;NXP&nbsp;LPC1700&nbsp;will&nbsp;be&nbsp;demonstrated&nbsp;at&nbsp;Embedded&nbsp;Systems&nbsp;Conference&nbsp;Boston,&nbsp;US&nbsp;running&nbsp;October&nbsp;26-30,&nbsp;2008.&nbsp;Engineering&nbsp;samples&nbsp;will&nbsp;be&nbsp;available&nbsp;starting&nbsp;in&nbsp;December&nbsp;2008,&nbsp;NXP&nbsp;confirmed.<br />
