[STM32F1] 求一个dma控制fsmc的程序,只会写
910|2
 楼主| liyye 发表于 2015-7-17 11:14 | 显示全部楼层 |阅读模式
uint16 DMABuff[65534];
#define I2C1_DR_Address    ((u32)0x40005400+0x4c)
* Function Name  : FSMC_DMA_Init
* 功能:初始化FSMC的DMA
* 参数:PeripheralBaseAddr外设地址,即图片存储地址
                BufferSize为DMA传输数据量
void FSMC_DMA_Init(uint32 PeripheralBaseAddr,uint32 BufferSize)
        DMA_InitTypeDef DMA_InitStructure;
        /* DMA channel6 configuration */
        DMA_DeInit(DMA1_Channel6);
        DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32)(I2C1_DR_Address);
        DMA_InitStructure.DMA_MemoryBaseAddr = (uint32)DMABuff;
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
        DMA_InitStructure.DMA_BufferSize = 0xfffe;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Enable;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;
        DMA_InitStructure.DMA_M2M = DMA_M2M_Enable;
        DMA_Init(DMA1_Channel6, &DMA_InitStructure);
        //允许发送完成中断
//        DMA_NVICConfig();
                DMA_Cmd(DMA1_Channel6, ENABLE);
然后发送部分就不会了
 楼主| liyye 发表于 2015-7-17 11:17 | 显示全部楼层
amanda_s 发表于 2015-7-17 17:07 | 显示全部楼层
标准外设库的DMA例子里面有用FSMC的例子
