[STM32F1] [求助] 外部计数STM32 ETR计算频率问题
1248|8
 楼主| zhou0214 发表于 2015-7-23 11:07 | 显示全部楼层 |阅读模式
我用外部计数STM32 ETR计算频率,测量100K频率,用定时器2定时1S,定时器三PD2(TIM3_ETR)计数,计算公式f=n/t;测量出来的结果是9999 HZ,整整少了一位数字,这是什么原因呢,大家分析一下,谢谢,附我的程序
void Time3_Configuration()
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
  TIM_TimeBaseStructure.TIM_Period = 0xFFFF;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);  // Time base configuration
  TIM_ETRClockMode2Config(TIM3, TIM_ExtTRGPSC_OFF, TIM_ExtTRGPolarity_NonInverted, 0);
  //TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);
  TIM_SetCounter(TIM3, 0);
  TIM_Cmd(TIM3, ENABLE);
        /*1S定时*/
void Tim2_Config(void)
   TIM_TimeBaseInitTypeDef   TIM2_TimeBaseStructure;
   NVIC_InitTypeDef NVIC_InitStructure;
   TIM_DeInit(TIM2);
   TIM2_TimeBaseStructure.TIM_Period =999;
   TIM2_TimeBaseStructure.TIM_Prescaler = (7200-1);
   TIM2_TimeBaseStructure.TIM_ClockDivision = 0x0;//ÉèÖÃʱÖÓϵÊý ²»·ÖƵ
  TIM2_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//ÏòÉϼÆÊýģʽ
   TIM_TimeBaseInit(TIM2, &TIM2_TimeBaseStructure); // Time base configuration
   TIM_ClearFlag(TIM2,TIM_FLAG_Update);//Çå³þ¸üбê־λ
  TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE );
   TIM_Cmd(TIM2, ENABLE);
   NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
   NVIC_Init(&NVIC_InitStructure);
最后的计算部分:
void TIM2_IRQHandler(void)
       if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
            TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
            CAPTURE1=(u32)TIM_GetCounter(TIM3);
       sum+=CAPTURE1;
       count++;
       if(count==4)
        Frequency1=sum/4;//求频率公式F=n/t;这里求了4次的计数平均值,结果是1S的频率
       sum=0;
        count=0;
       TIM_SetCounter(TIM3,0);
 楼主| zhou0214 发表于 2015-7-23 11:08 | 显示全部楼层
自己给顶一个。。
sting_yang 发表于 2015-7-23 12:48 | 显示全部楼层
在72Mhz,这样是100ms,不是1S,测量结果9999hz,只差1hz,算是正确
zh113214 发表于 2015-7-23 12:50 | 显示全部楼层
TIM3中断加IO输出,用示波器测试一下波形。
小浣熊 发表于 2015-7-23 12:59 | 显示全部楼层
没有研究过,顶!!!
搞IT的 发表于 2015-7-23 13:16 | 显示全部楼层
帮顶!!!!进来看看
 楼主| zhou0214 发表于 2015-7-23 13:28 | 显示全部楼层
目的是什么,TIM3只是计数:)
 楼主| zhou0214 发表于 2015-7-23 13:29 | 显示全部楼层
在72Mhz, ...
刚才是0.1S,现在是定时1S:(:(
sting_yang 发表于 2015-7-23 13:32 | 显示全部楼层
刚才是0.1S,现在是定时1S
"刚才是0.1S,现在是定时1S",什么意思?不懂
