kermit在启动时会查找~/.kermrc文件,调用里面的命令来初始化kermit。只要将你所需的命令写到~/.kermrc文件里,启动.<br /> vi ~/.kermrc <br /><br />set line /dev/ttyS0<br />set speed 115200<br />set carrier-watch off<br />set handshake none<br />set flow-control none<br />robust<br />set file type bin<br />set file name lit<br />set rec pack 1000<br />set send pack 1000<br />set window 5<br />c<br /><br />保存后退出即可。然后启动kermit,你会看到:<br /><br /># kermit<br />Connecting to /dev/ttyS0, speed 115200<br />Escape character: Ctrl- (ASCII 28, FS): enabled<br />Type the escape character followed by C to get back,<br />or followed by ? to see other options.<br /> <br /> <br /> |
