[51单片机] 按照周立功C51的例子,写了LCD1602显示时间的程序,在proteus...
2224|16
 楼主| any012 发表于 2015-7-26 12:22 | 显示全部楼层 |阅读模式
基本上是照抄下来的,51单片机的P1口驱动LCD1602,另有两个按键练到外部中断脚,来控制设置时间。
程序还没有消化,想用Proteus模拟看下效果,结果lcd无显示。
 楼主| any012 发表于 2015-7-26 12:51 | 显示全部楼层
  1. #include <reg51.h>
  2. #include <stdio.h>
  3. #include "MacroAndConst.h"
  4. //¶¨Ò嶨ʱÆ÷0µÄ֨װֵ
  5. #define RELOAD_HIGH 0x3C
  6. #define RELOAD_LOW  0xD2
  7. //¶¨Òå°´¼üµ¯ÌøÊ±¼ä
  8. #define DB_VAL        10
  9. //¶¨ÒåÉèÖÃģʽµÄ×î´óʱ¼ä¼ä¸ô
  10. #define TIMEOUT 200
  11. //¶¨Òå¹â±êλÖó£Êý
  12. #define HOME 0
  13. #define HOUR 1
  14. #define MIN  2
  15. #define SEC  3
  16. //¶¨Òå¹â±ê״̬³£Êý
  17. #define OFF 0
  18. #define ON  1
  19. //¶¨ÒåÏÔʾÃüÁî³£Êý
  20. #define DISP_BUSY   0x80
  21. #define DISP_FUNC   0x38
  22. #define DISP_ENTRY  0x06
  23. #define DISP_CNTL   0x080
  24. #define DISP_ON     0x04
  25. #define DISP_CURSOR 0x02
  26. #define DISP_CLEAR  0x01
  27. #define DISP_HOME   0x02
  28. #define DISP_POS    0x80
  29. #define DISP_LINE2  0x40
  30. sbit SET         = P3^4;                //ÉèÖð´¼üÊäÈë
  31. sbit SELECT = P3^5;                //Ñ¡Ôñ°´¼üÊäÈë
  32. sbit ENABLE = P3^1;                //ÏÔʾʹÄÜÊä³ö
  33. sbit REGSEL = P3^7;                //ÏÔʾ¼Ä´æÆ÷Ñ¡ÔñÊä³ö
  34. sbit RDWR   = P3^6;                //ÏÔʾģʽÊä³ö
  35. sfr DISPDATA = 0x90;                //ÏÔʾ8λÊý¾Ý×ÜÏß
  36. typedef struct                        //¶¨Òå´æ´¢Ã¿ÈÕʱ¼äµÄ½á¹¹
  37. {
  38.         uchar hour, min, sec;
  39. }timestruct;
  40. bit set_mode         = 0;                //½øÈëÉèÖÃģʽʱÖÃλ
  41. bit disp_updata = 0;        //ÐèҪˢÐÂÏÔʾʱÖÃλ
  42. uchar set_mode_to           = 0;        //Ϊÿ´Î°´¼ü²Ù×÷µÄʱ¼ä¼ä¸ô¼ÆÊ±
  43. uchar switch_debounce = 0;        //°´¼üÌø¶¯Éè¼Æ
  44. uchar cur_field           = HOME;        //ÉèÖÃģʽµÄµ±Ç°Î»ÖÃÑ¡Ôñ
  45. timestruct curtime;                //´æ·Åµ±Ç°µÄʱ¼ä
  46. timestruct timeholder;        //´æ·ÅÏÔʾʱ¼ä
  47. uchar code fieldpos[3] = {
  48.                                                         DISP_LINE2 | 0x01,
  49.                                                         DISP_LINE2 | 0x04,
  50.                                                         DISP_LINE2 | 0x07,
  51. };
  52. #define T_HOURT        16
  53. #define T_HOUR  17
  54. #define T_MINT         19
  55. #define T_MIN        20
  56. #define T_SECT  22
  57. #define T_SEC   23
  58. char code bcdmap[60][2] = {
  59.         "00","01","02","03","04","05","06","07","08","09",
  60.         "10","11","12","13","14","15","16","17","18","19",
  61.         "20","21","22","23","24","25","26","27","28","29",
  62.         "30","31","32","33","34","35","36","37","38","39",
  63.         "40","41","42","43","44","45","46","47","48","49",
  64.         "50","51","52","53","54","55","56","57","58","59",
  65. };
  66. //º¯ÊýÉùÃ÷
  67. void disp_cmd(uchar);
  68. void disp_init(void);
  69. uchar disp_read(void);
  70. void disp_time(void);
  71. void disp_write(uchar);
  72. void incr_field(void);
  73. void second_tick(void);
  74. void set_cursor(bit, uchar);
  75. /********************************/
  76. //¹¦ÄÜ£ºÖ÷º¯Êý
  77. //ÃèÊö£º³ÌÐòÈë¿Úº¯Êý£¬³õʼ»¯8051£¬¿ªÖжϣ¬½øÈë¿ÕÏÐģʽ¡£Ã¿´ÎÖжÏÖ®ºó²éѯ±ê־룬ÊÇ·ñË¢ÐÂÏÔʾ
  78. //²ÎÊý£ºÎÞ
  79. //·µ»Ø£ºÎÞ
  80. /********************************/
  81. void main(void)
  82. {
  83.         disp_init();                        //ÏÔʾ³õʼ»¯
  84.         TMOD = 0x11;                        //ÉèÖö¨Ê±Æ÷ģʽ£¬T0,T1 16λ²»¿ÉÖØ×°Ä£Ê½
  85.         TCON = 0x15;
  86.         IE          = 0x82;                        //ÔÊÐíT0ÖжÏ
  87.         while(1)
  88.         {
  89.                 if(disp_updata)
  90.                 {
  91.                         disp_time();        //ÏÔʾÐÂʱ¼ä
  92.                 }
  93.                 PCON = 0x01;
  94.         }
  95. }
  96. /********************************/
  97. //¹¦ÄÜ£ºdisp_cmd
  98. //ÃèÊö£ºÏòlcdÇý¶¯Æ÷дÈëÃüÁ²¢µÈ´ýÃüÁî±»Ö´ÐÐ
  99. //²ÎÊý£ºÃüÁî
  100. //·µ»Ø£ºÎÞ
  101. /********************************/
  102. void disp_cmd(uchar cmd)
  103. {
  104.         DISPDATA = cmd;                        //Ëø×¡ÃüÁî
  105.         REGSEL = 0;                                //Ñ¡ÔñÃüÁî¼Ä´æÆ÷
  106.         RDWR = 0;                                //Ñ¡Ôñдģʽ
  107.         ENABLE = 1;
  108.         ENABLE = 0;
  109.         TH1 = 0;                                //¶¨Ê±85ms
  110.         TL1 = 0;
  111.         TF1 = 0;
  112.         TR1 = 1;
  113.         while(!TF1 && disp_read() & DISP_BUSY);        //µÈ´ýÃüÁî±»Ö´ÐÐ
  114.         TR1 = 0;
  115. }
  116. /********************************/
  117. //¹¦ÄÜ£ºdisp_init
  118. //ÃèÊö£º³õʼ»¯ÏÔʾ
  119. //²ÎÊý£ºÎÞ
  120. //·µ»Ø£ºÎÞ
  121. /********************************/
  122. void disp_init(void)
  123. {
  124.         TH1 = 0;
  125.         TL1 = 0;
  126.         TF1 = 0;
  127.         TR1 = 1;
  128.         while(!TF1 && disp_read() & DISP_BUSY);
  129.         TR1 = 0;
  130.         disp_cmd(DISP_FUNC);                        //ÉèÖÃÏÔʾ¸ñʽ
  131.         disp_cmd(DISP_ENTRY);                        //ÿÊäÈëÒ»¸ö×Ö·û£¬ÏÔʾµØÖ·¼Ó1
  132.         disp_cmd(DISP_CNTL | DISP_ON);        //´ò¿ªÏÔʾ£¬¹Ø±Õ¹â±ê
  133.         disp_cmd(DISP_CLEAR);                        //Çå³ýÏÔʾ
  134. }
  135. /********************************/
  136. //¹¦ÄÜ£ºdisp_read
  137. //ÃèÊö£º¶ÁÏÔʾ״̬¼Ä´æÆ÷
  138. //²ÎÊý£ºÎÞ
  139. //·µ»Ø£º´Ó״̬¼Ä´æÆ÷ÖжÁ»ØµÄÊý¾Ý
  140. /********************************/
  141. uchar disp_read(void)
  142. {
  143.         uchar value;
  144.         DISPDATA = 0xFF;
  145.         REGSEL = 0;                                //Ñ¡ÔñÃüÁî¼Ä´æÆ÷
  146.         RDWR = 1;                                //Ñ¡Ôñ¶Áģʽ
  147.         ENABLE = 1;                                //ʹÄÜLCDÊä³ö
  148.         value = DISPDATA;                //¶ÁÊý¾Ý
  149.         ENABLE = 0;
  150.         return (value);
  151. }
  152. /********************************/
  153. //¹¦ÄÜ£ºdisp_time
  154. //ÃèÊö£ºÈ¡ÏÔʾÊý¾Ý½øÐиñʽ»¯
  155. //²ÎÊý£ºÎÞ
  156. //·µ»Ø£ºÎÞ
  157. /********************************/
  158. void disp_time(void)
  159. {
  160.         static char time_str[32] = "TIME OF DAY IS:XX:XX:XX";
  161.         uchar i;
  162.         time_str[T_HOURT] = bcdmap[timeholder.hour][0];
  163.         time_str[T_HOUR]  = bcdmap[timeholder.hour][1];
  164.         time_str[T_MINT]  = bcdmap[timeholder.min][0];
  165.         time_str[T_MIN]   = bcdmap[timeholder.min][1];
  166.         time_str[T_SECT]  = bcdmap[timeholder.sec][0];
  167.         time_str[T_SEC]   = bcdmap[timeholder.sec][1];
  168.         putchar(0xFF);
  169.         for(i = 0; i < 32; i++)
  170.         {
  171.                 putchar(time_str[i]);
  172.         }
  173.         disp_updata = 0;
  174. }
  175. /********************************/
  176. //¹¦ÄÜ£ºdisp_write
  177. //ÃèÊö£ºÐ´ÈëÒ»¸ö×Ö½ÚÊý¾Ý
  178. //²ÎÊý£ºÒªÐ´ÈëµÄ×Ö½Ú
  179. //·µ»Ø£ºÎÞ
  180. /********************************/
  181. void disp_write(uchar value)
  182. {
  183.         DISPDATA = value;
  184.         REGSEL = 1;
  185.         RDWR = 0;
  186.         ENABLE = 1;
  187.         ENABLE = 0;
  188. }
  189. /********************************/
  190. //¹¦ÄÜ£ºincr_field
  191. //ÃèÊö£ºÔö¼ÓÊýÖµ
  192. //²ÎÊý£ºÎÞ
  193. //·µ»Ø£ºÎÞ
  194. /********************************/
  195. void incr_field(void)
  196. {
  197.         if(cur_field == SEC)
  198.         {
  199.                 curtime.sec++;
  200.                 if(curtime.sec > 59)
  201.                         curtime.sec = 0;
  202.         }
  203.         if(cur_field == MIN)
  204.         {
  205.                 curtime.min++;
  206.                 if(curtime.min > 59)
  207.                         curtime.min = 0;
  208.         }
  209.         if(cur_field == HOUR)
  210.         {
  211.                 curtime.hour++;
  212.                 if(curtime.hour > 23)
  213.                         curtime.hour = 0;
  214.         }
  215. }
  216. /********************************/
  217. //¹¦ÄÜ£ºputchar
  218. //ÃèÊö£ºÌæ´ú±ê×¼putcharº¯Êý£¬Êä³ö×Ö·û
  219. //²ÎÊý£ºÒªÏÔʾµÄ×Ö·û
  220. //·µ»Ø£º¸Õ¸Õ±»Ð´µÄ×Ö·û
  221. /********************************/
  222. char putchar(char c)
  223. {
  224.         static uchar flag = 0;
  225.         if(!flag || c == 255)
  226.         {
  227.                 disp_cmd(DISP_HOME);
  228.                 flag = 0;
  229.                 if(c == 255)
  230.                         return c;
  231.         }
  232.         if(flag == 16)
  233.                 disp_cmd(DISP_POS | DISP_LINE2);
  234.         disp_write(c);
  235.         while(disp_read() & DISP_BUSY);
  236.         flag++;
  237.         if(flag >= 32)
  238.                 flag = 0;
  239.         return c;
  240. }
  241. /********************************/
  242. //¹¦ÄÜ£ºsecond_tick
  243. //ÃèÊö£ºÃ¿ÃëÖÓÖ´ÐÐÒ»´Îº¯Êý¹¦ÄÜ£¬Ê±¼ä¸üÐÂ
  244. //²ÎÊý£ºÎÞ
  245. //·µ»Ø£ºÎÞ
  246. /********************************/
  247. void second_tick(void)
  248. {
  249.         curtime.sec++;                                        //ÃëÖÓ¼Ó1
  250.         if(curtime.sec > 59)                        //¼ì²âÊÇ·ñ³¬³ö·¶Î§
  251.         {
  252.                 curtime.sec = 0;
  253.                 curtime.min++;                                //·ÖÖÓ¼Ó1
  254.                 if(curtime.min > 59)                //¼ì²âÊÇ·ñ³¬³ö·¶Î§
  255.                 {
  256.                         curtime.min = 0;
  257.                         curtime.hour++;                        //СʱÊý¼Ó1
  258.                         if(curtime.hour > 23)        //¼ì²âÊÇ·ñ³¬³ö·¶Î§
  259.                                 curtime.hour = 0;
  260.                 }
  261.         }
  262.         if(!disp_updata)                                //È·ÐÅtimeholderûÓб»ÏÔʾ
  263.         {
  264.                 timeholder = curtime;                //×°ÈëÐÂʱ¼ä
  265.                 disp_updata = 1;                        //¸üÐÂÏÔʾ
  266.         }
  267. }
  268. /********************************/
  269. //¹¦ÄÜ£ºset_cursor
  270. //ÃèÊö£ºÏÔʾ»ò¹Ø±Õ¹â±ê£¬²¢°Ñ¹â±êÒÆµ½Ìض¨µÄλÖÃ
  271. //²ÎÊý£ºnew_mode 룬Òþ²Ø¹â±êʱÖÃλ
  272. //                field          ÏÔʾ¹â±êµÄλÖÃ
  273. //·µ»Ø£ºÎÞ
  274. /********************************/
  275. void set_cursor(bit new_mode, uchar field)
  276. {
  277.         uchar mask;
  278.         mask = DISP_CNTL | DISP_ON;
  279.         if(new_mode)
  280.                 mask |= DISP_CURSOR;
  281.         disp_cmd(mask);
  282.         if(field == HOME)
  283.                 mask = DISP_HOME;
  284.         else
  285.                 mask = DISP_POS | fieldpos[field - 1];
  286.         disp_cmd(mask);
  287. }
  288. /********************************/
  289. //¹¦ÄÜ£ºsystem_tick
  290. //ÃèÊö£º¶¨Ê±Æ÷0µÄÖжϷþÎñ³ÌÐò£¬ÃÃ50msÖØ×°Ò»´Î¶¨Ê±Æ÷
  291. //²ÎÊý£ºÎÞ
  292. //·µ»Ø£ºÎÞ
  293. /********************************/
  294. void system_tick(void) interrupt 1
  295. {
  296.         static uchar second_cnt = 20;
  297.         TR0 = 0;
  298.         TH0 = RELOAD_HIGH;                        //Éè¶¨ÖØ×°Öµ
  299.         TL0 = RELOAD_LOW;
  300.         TR0 = 1;                                        //¿ªÊ¼¶¨Ê±
  301.         if(switch_debounce)                        //°´¼ü¶¶¶¯
  302.                 switch_debounce--;
  303.         if(!switch_debounce)
  304.         {
  305.                 if(!SET)                                                        //Èç¹ûÉèÖð´¼ü±»°´ÏÂ
  306.                 {
  307.                         switch_debounce = DB_VAL;                //ÉèÖÃÏû¶¶Ê±¼ä
  308.                         if(!set_mode && !disp_updata)        //Èç¹û²»ÊÇÉèÖÃģʽ
  309.                         {
  310.                                 set_mode = 1;                                //½øÈëÉèÖÃģʽ
  311.                                 set_mode_to = TIMEOUT;                //ÉèÖÿÕÏÐʱ¼ä
  312.                                 cur_field = HOUR;                        //Ñ¡Ôñ¹â±êÆðʼλÖÃ
  313.                                 set_cursor(ON, HOUR);                //ʹÄܹâ±ê
  314.                         }
  315.                         else
  316.                         {
  317.                                 cur_field++;                                //¹â±êλÖÃǰ½ø
  318.                                 if(cur_field > SEC)                        //¹â±êÊÇ·ñ³¬³ö·¶Î§
  319.                                 {
  320.                                         set_mode = 0;                        //Í˳öÉèÖÃģʽ
  321.                                         set_mode_to = 0;
  322.                                         set_cursor(OFF, HOME);        //½ûÄܹâ±ê
  323.                                 }
  324.                                 else
  325.                                 {
  326.                                         set_cursor(ON, cur_field);        //¹â±êÒÆµ½ÏÂÒ»¸öλÖÃ
  327.                                         set_mode_to = TIMEOUT;
  328.                                 }
  329.                         }
  330.                 }
  331.                 if(set_mode && !SELECT)                                //Èç¹û°´ÏÂÑ¡Ôñ°´Å¥
  332.                 {
  333.                         set_mode_to = TIMEOUT;
  334.                         incr_field();                                        //ËùÑ¡Ôñ´¦ÊýÖµÔö¼Ó
  335.                         disp_time();                                        //ÏÔʾʱ¼ä
  336.                 }
  337.         }
  338.         if(!set_mode)                        //ÉèÖÃģʽֹͣʱÖÓ
  339.         {
  340.                 second_cnt--;                //¼ÆÊýÖµ¼õ1
  341.                 if(!second_cnt)                //Èç¹û¾­¹ý1Ãë
  342.                 {
  343.                         second_cnt = 20;//ÉèÖüÆÊýÖµ
  344.                         second_tick();
  345.                 }
  346.         }
  347. }
 楼主| any012 发表于 2015-7-26 13:13 | 显示全部楼层
试着修改了下,T0中断累计到1s时,使P2输出口自加一,protues仿真正确。
那可能是Lcd驱动程序的问题了。
 楼主| any012 发表于 2015-7-26 13:49 | 显示全部楼层
找到问题了:
写成了#define DISP_CNTL   0x080
导致没有打开显示.
不过还有其他问题,估计也是输入错误引起的。
本来应该是两行显示,现在是滚动显示。
 楼主| any012 发表于 2015-7-28 19:55 | 显示全部楼层
现在显示总是向后滚动,修改了下void disp_time(void)函数的条件循环,
改成for(i = 0; i<31;i++)
不滚动了,但是首字符是个黑块。
whirt_noob 发表于 2015-7-29 13:20 | 显示全部楼层
注释是哪国语言?
评分
参与人数 1威望 +2 收起 理由
any012 + 2 淡定
查看全部评分
 楼主| any012 发表于 2015-7-29 15:48 | 显示全部楼层
注释是哪国语言?
编码不对,赋值过来就成这样子了。
注释内容和附件里的PDF注释一致。
 楼主| any012 发表于 2015-8-14 11:09 | 显示全部楼层
注释是哪国语言?
简体中文...
不过我每次复制程序过来,注释都会变成乱码。
不知道别人是怎么处理的。
qq4988 发表于 2015-8-14 13:16 | 显示全部楼层
这个例子,网上现成好好多,好多,随便找一个就可显示了
评分
参与人数 1威望 +2 收起 理由
any012 + 2 淡定
查看全部评分
 楼主| any012 发表于 2015-8-14 14:45 | 显示全部楼层
不是为了做这个功能,而是想学里面教的编程方法进而试着把例程打了一遍。
先找一个可以显示的例程,然后再去学习里面的东西  发表于 2015-8-14 14:49
 楼主| any012 发表于 2015-8-14 14:59 | 显示全部楼层
不是为了做这个功能,而是想学里面教的编程方法进而试着把例程打了一遍。 ...
已经可以显示了。
之前不能显示是有个命令,是控制显示开关的,应该给LCD0602命令字0x08,结果我输入成了0x080。当然,显示就没有被打开。
现在的问题都是,字符是滚动的...
正在研究为什么会这样。
 楼主| any012 发表于 2015-8-14 16:17 | 显示全部楼层
  1. void disp_time(void)
  3.         static char time_str[32] = "TIME OF DAY IS: XX:XX:XX        ";
  4.         uchar i;
  5.         time_str[T_HOURT] = bcdmap[timeholder.hour][0];
  6.         time_str[T_HOUR]  = bcdmap[timeholder.hour][1];
  7.         time_str[T_MINT]  = bcdmap[timeholder.min][0];
  8.         time_str[T_MIN]   = bcdmap[timeholder.min][1];
  9.         time_str[T_SECT]  = bcdmap[timeholder.sec][0];
  10.         time_str[T_SEC]   = bcdmap[timeholder.sec][1];
  11.         putchar(0xFF);
  12.         for(i = 0; i < 31; i++)
  13.         {
  14.                 putchar(time_str[i]);
  15.         }
  16.         disp_updata = 0;
  17. }
time_str[32]是定义的一个32个字节的数组,对应屏上的32个字符。(最后有几个空字符,不知道为什么合并到一块了)
T_HOURT被宏定义为16,按PDF上打的字符算,其实对应的应该是15,后来我在IS:后多加了个空格。
putchar(0xFF);是将flag标志位清零,并且指向屏的第一个字符。
    putchar(time_str);
这个循环是输出屏上的32个字符,不知道为什么设成32的话,字就循环向后移位。
感觉前边多了个黑字符...
 楼主| any012 发表于 2015-8-14 17:01 | 显示全部楼层
#define T_HOURT        16
T_HOURT定义为16,time_str[T_HOURT]应该对应的是第二行第一个字符。结果却在第二行第二个字符显示...
 楼主| any012 发表于 2015-8-15 09:47 | 显示全部楼层
找到问题了。
putchar(0xFF);
        putchar(time_str);
在发送需要显示的字符之前,调用了这么个函数putchar(0xFF),在这个函数里,判断如果传入的参数是256的话,就光标回原位。
问题出在putchar()函数的参数是声明为char类型的,改成unsigned char就好了。
 楼主| any012 发表于 2015-8-15 11:09 | 显示全部楼层
发现按完设置键后,再按选择键,对应的时间应该增加,但没有显示出来,设置完成后才可看到增加了。
所以修改了下:
                        incr_field();
                        timeholder = curtime;                                //此处是为了显示出来我后加上去的
                        disp_time();
                        set_cursor(ON, cur_field);                   //此处是为了显示光标我后加上去的
并且,原来按了选择按键后,光标马上就关闭了,看上去仿佛是退出了设置模式,其实没有。我在上边函数里最后加上了显示光标。
 楼主| any012 发表于 2015-8-15 11:16 | 显示全部楼层
还有些其他问题。
SET按键设置了消抖(其实好象是防止按下不放误判成多次),但SELECT按键没有设置,并且SELECT也不适合设置成像SET那样消抖500ms,那样太久了。如果单独给他设置个消抖变量,感觉程序又不那么简练了。
现在退出设置模式,必须是按三次SET按键,才能推出。程序里其实定义了个变量set_mode_to,好象是用来作为在设置模式下长时间无按键动作时的超时判断用的,不过原例子里没有做处理。
