[STM32F0] 为什么我用tim3使能PWM没有波
1437|9
 楼主| billbillqaz 发表于 2015-7-26 16:44 | 显示全部楼层 |阅读模式
TI, PWM, IO, ST, pi
我不用TIM1,程序如下:
#include "time.h"
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
uint16_t TimerPeriod = 0;
uint16_t Channel1Pulse = 0, Channel2Pulse = 0, Channel3Pulse = 0, Channel4Pulse = 0;
void TIM_Config(void)
  /* 使能GPIO时钟 */
  RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOA, ENABLE);
  /* 配置GPIO管脚复用*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 ;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_1);
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_1);
void TIM_PWM_Config(void)
    /*计算预定表的值,也就是多少个时钟计数为一个周期*/
  TimerPeriod = (SystemCoreClock / 17570 ) - 1;
  /*计算CCR1 跳转值 在占空比为50%时*/
   Channel1Pulse = (uint16_t) (((uint32_t) 5 * (TimerPeriod - 1)) / 10);
/*计算CCR2 跳转值 在占空比为37.5%时*/
  Channel2Pulse = (uint16_t) (((uint32_t) 375 * (TimerPeriod - 1)) / 1000);
  /* TIM1 时钟使能 */
  RCC_APB2PeriphClockCmd(RCC_APB1Periph_TIM3 , ENABLE);
  /* Time 定时基础设置*/
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  /* Time 定时设置为上升沿计算模式*/
  TIM_TimeBaseStructure.TIM_Period = TimerPeriod;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  /* 频道1,2,3,4的PWM 模式设置 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  TIM_OCInitStructure.TIM_Pulse = Channel1Pulse;//使能频道1配置
  TIM_OC1Init(TIM3, &TIM_OCInitStructure);
  TIM_OCInitStructure.TIM_Pulse = Channel2Pulse;//使能频道2配置
  TIM_OC2Init(TIM3, &TIM_OCInitStructure);
//  TIM_OCInitStructure.TIM_Pulse = Channel3Pulse;//使能频道3配置
//  TIM_OC3Init(TIM1, &TIM_OCInitStructure);
//  TIM_OCInitStructure.TIM_Pulse = Channel4Pulse;//使能频道4配置
//  TIM_OC4Init(TIM1, &TIM_OCInitStructure);
  /* TIM1 计算器使能*/
  TIM_Cmd(TIM3, ENABLE);
  /* TIM1 主输出使能 */
  TIM_CtrlPWMOutputs(TIM3, ENABLE);
fengchi 发表于 2015-7-26 17:03 | 显示全部楼层
还缺这两句
TIM_ITConfig(TIM3,TIM_IT_Update, ENABLE);
可以看下风驰的F0开源程序
小浣熊 发表于 2015-7-26 18:48 | 显示全部楼层
是楼上这样么?、
尤彼卡 发表于 2015-7-26 18:58 | 显示全部楼层
可以参考例程,然后根据例程修改
 楼主| billbillqaz 发表于 2015-8-7 17:40 | 显示全部楼层
还缺这两句
不好使啊,而且不用使能TIM的中断吧?
 楼主| billbillqaz 发表于 2015-8-8 08:24 | 显示全部楼层
还缺这两句
不是这个原因,但是我照着风驰的重新粘贴了一遍就好使了,谢谢啊
FireRiver9 发表于 2015-8-8 16:22 | 显示全部楼层
是哪里出了问题呢
lwsn 发表于 2015-8-8 22:00 | 显示全部楼层
关键是为什么呢,什么原因
 楼主| billbillqaz 发表于 2015-8-11 13:33 | 显示全部楼层
关键是为什么呢,什么原因
我也不知到啊
tgwfcc 发表于 2015-8-12 11:04 | 显示全部楼层
1、TIM_CtrlPWMOutputs(TIM3, ENABLE);
奇怪的是那样写也不报错。
不用使能TIM3在CCR1、2、3、4和ARR上的预装载寄存器吗?
2、计算CCR1、2、3、4的值,应该是(Period+1)*5/10吧?
