void initEMIOS_0ch22(void) { /* EMIOS 0 CH 22: Output Pulse Width Modulation */
EMIOS_0.CH[22].CADR.R = 500; /* Leading edge when channel counter bus=500*/
EMIOS_0.CH[22].CBDR.R = 999; /* Trailing edge when channel's counter bus=999*/
EMIOS_0.CH[22].CCR.B.BSL = 0x0; /* Use counter bus A (default) */
EMIOS_0.CH[22].CCR.B.EDPOL = 1; /* Polarity-leading edge sets output/trailing clears*/
EMIOS_0.CH[22].CCR.B.MODE = 0x60; /* Mode is OPWM Buffered */
SIU.PCR[70].R = 0x0600; /* MPC56xxS: Assign EMIOS_0 ch 22 to pad */
给位高手看看,上面说的是什么含义啊,万分感谢!!! |
