[i.MX] IMX6Q编译LTIB出错
1057|3
 楼主| qqman173 发表于 2015-7-27 20:11 | 显示全部楼层 |阅读模式
飞卡版本好,在 执行./ltib后出错,错误信息详细情况在host_config.log里,下面是我贴出log信息,请问一下怎么解决这个问题呢?非常感谢Updating lpp from local packages
Processing platform: Host support packages
using /home/zj/LTIB/ltib_bsp/ltib/config/platform/host/ltib.preconfig
Processing: fake-provides
Processing: mkspooflinks
Processing: distcc
Processing: ccache
Processing: m4
Processing: bison
Build path taken because: directory build, no prebuilt rpm,
Cowardly refusing to clobber existing directory:
/opt/freescale/ltib/usr/src/rpm/BUILD/bison-2.6
Remove this by hand if you really want to rebuild this package from scratch
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
  main::host_checks:1447
   main:554
Started: Mon Jul 27 20:00:42 2015
Ended:   Mon Jul 27 20:00:44 2015
Elapsed: 2 seconds
These packages failed to build:
bison
Build Failed
mini1986 发表于 2015-7-28 08:23 | 显示全部楼层
 楼主| qqman173 发表于 2015-7-28 09:04 | 显示全部楼层
Remove this by hand if you really want to rebuild th ...
/opt/freescale/ltib/usr/src/rpm/BUILD/bison-2.6删除这个目录,然后重新./ltib吗?
mini1986 发表于 2015-7-28 11:21 | 显示全部楼层
