[DemoCode下载]
软件RTC
1441|6
a_ziliu|  楼主 | 2015-7-28 16:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
因为有很多型号没有RTC功能,用TIMER 中断的方式计时,用软体的方式作处理年,月,日,时,分,秒。
NUC123SeriesBSP_CMSIS_V3.00.003-SOFTWARE RTC.zip (362.05 KB)
gaoyang9992006| | 2015-7-28 20:16 | 只看该作者
* @file     main.c
* @version  V3.00
* $Revision: 5 $
* $Date: 15/07/02 11:18a $
* @brief    Demonstrate how to perform timer counting in periodic mode.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC123.h"
#define HCLK_CLOCK           72000000
unsigned int t_flag=0;
* @brief       Timer0 IRQ
* @param       None
* @return      None
* @Details     The Timer0 default IRQ, declared in startup_NUC123.s.
void TMR0_IRQHandler(void)
    if(TIMER_GetIntFlag(TIMER0) == 1)
        /* Clear Timer0 time-out interrupt flag */
        TIMER_ClearIntFlag(TIMER0);
        t_flag=1;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable IRC22M clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for IRC22M clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable XT1_OUT(PF.0) and XT1_IN(PF.1) */
    SYS->GPF_MFP |= SYS_GPF_MFP_PF0_XT1_OUT | SYS_GPF_MFP_PF1_XT1_IN;
    /* Enable external 12 MHz XTAL, IRC10K */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC10K_EN_Msk);
    /* Waiting for clock ready */
    while(!CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_OSC10K_STB_Msk));
    /* Set core clock as HCLK_CLOCK */
    CLK_SetCoreClock(HCLK_CLOCK);
    /* Enable peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(TMR0_MODULE);
    /* Peripheral clock source */
    CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0_S_HXT, 0);
    /* Init I/O Multi-function        */
    /* Set PB multi-function pins for UART0 RXD, TXD */
    SYS->GPB_MFP = SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
void UART0_Init(void)
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
unsigned int g_year=2015;
unsigned char g_month=2;
unsigned char g_day=28;
unsigned char g_day_old;
unsigned char g_weekly=2;
unsigned char hour=23;
unsigned char min=59;
unsigned char  sec=30;
void SoftwareRTC(void)
        if(t_flag==0)
                return;
          sec++;
    if(sec==60)
     sec=0;
     min++;
                if(min==60)
                 min=0;
     hour++;
                if(hour==24)
                        hour=0;
                        g_day++;
                        g_weekly++;
                printf("hr.:%d :min: %d: sec: %d\n\r",hour,min,sec);
                t_flag=0;
int isLeapYear(int year) {
return (year%400==0) || ((year%4==0) && (year%100!=0));
void SoftwareYMD(void)
        int days[] = {31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31};
        days[1] += isLeapYear(g_year);
        if(g_day==g_day_old)
          return;
          g_day_old=g_day;
         if(g_day>days[g_month-1])
   g_day=1;
         g_month++;
         if(g_weekly>7)//7 is sum day
                 g_weekly=1;
         if(g_month>12)
                 g_month=1;
                 g_year++;
         printf("Y:%d, M:%d, D:%d, Weekly:%d\n\r",g_year,g_month,g_day,g_weekly);
/*  MAIN function        */
int main(void)
    volatile uint32_t u32InitCount;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    //SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU @ %d Hz\n", SystemCoreClock);
    /* Open Timer0 in periodic mode, enable interrupt and 1 interrupt tick per second */
    TIMER_Open(TIMER0, TIMER_PERIODIC_MODE, 1);
    TIMER_EnableInt(TIMER0);
    /* Enable Timer0 ~ Timer3 NVIC */
    NVIC_EnableIRQ(TMR0_IRQn);
    /* Start Timer0 ~ Timer3 counting */
    TIMER_Start(TIMER0);
    //g_offset=g_weekly-getWeekday(g_year, g_month, g_day, 0);
    while(1){
                        SoftwareRTC();
                        SoftwareYMD();
/*** (C) COPYRIGHT 2014~2015 Nuvoton Technology Corp. ***/
gaoyang9992006| | 2015-7-28 20:17 | 只看该作者
代码又不长,可以贴出来,大家看看,觉得对胃口了,再下载。
捉虫天师| | 2015-7-28 20:38 | 只看该作者
稳稳の幸福| | 2015-7-28 21:14 | 只看该作者
这个万年历里用啊
稳稳の幸福| | 2015-7-28 21:16 | 只看该作者
做51时候都是软件模拟的,都是这样,说实在的,实在用不惯硬件的。
huxidong| | 2015-7-29 00:15 | 只看该作者
RTC的意义都没有搞明白,掉电你那软件时间有什么意义?
