Device Information
Manufacturer: Micron
Memory part number: MT41K128M16JT-125
Memory type: DDR3-1600 1600
DRAM density (Gb) 2
DRAM Bus Width 16
Number of Banks 8
Number of ROW Addresses 14
Number of COLUMN Addresses 10
Page Size (K) 2
Self-Refresh Temperature (SRT) Normal
tRCD=tRP=CL (ns) 13.75
tRC Min (ns) 48.75
tRAS Min (ns) 35
System Information
i.Mx Part i.Mx6Q Arik
Bus Width 64
Density per chip select (Gb) 8
Number of Chip Selects used 1 If only one CS is used, that must be CS0.
Total DRAM Density (Gb) 8
DRAM Clock Freq (MHz) 528
DRAM Clock Cycle Time (ns) 1.894
Address Mirror (for CS1) Disable
SI Configuration
DRAM DSE Setting - DQ/DQM (ohm) 48 40ohm is used in FSL reference design.
DRAM DSE Setting - ADDR/CMD/CTL (ohm) 48 40ohm is used in FSL reference design.
DRAM DSE Setting - CK (ohm) 48 40ohm is used in FSL reference design.
DRAM DSE Setting - DQS (ohm) 48 40ohm is used in FSL reference design.
System ODT Setting (ohm) 60
