[STM32F4] 关于RTC时间和日历的问题
4706|10
 楼主| njpanyi 发表于 2015-8-7 10:39 | 显示全部楼层 |阅读模式
我正在做RTC时钟显示在LCD上的程序,但是问题是每个几秒就会跳一秒,比如说11:11:51然后可能就直接跳到53了这样,大概是4秒左右会跳一下吧~我也不知道是什么问题,感觉配置也是按照一般的来的。
程序在下面麻烦各位大神指导指导,不太懂呢~谢谢哈
配置:
void RTC_Config(void)
{ __IO uint32_t AsynchPrediv = 0, SynchPrediv = 0;
        RTC_InitTypeDef RTC_InitStructure;
        RTC_TimeTypeDef RTC_TimeStructure;
  RTC_DateTypeDef RTC_DateStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR,ENABLE);
  PWR_BackupAccessCmd(ENABLE);
  RCC_LSICmd(ENABLE);
    while(RCC_GetFlagStatus(RCC_FLAG_LSIRDY) == RESET);
    RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);
    RCC_RTCCLKCmd(ENABLE);
    RTC_WaitForSynchro();
  if(RTC_ReadBackupRegister(RTC_BKP_DR0) != 0x5050)
    RTC_WriteProtectionCmd(DISABLE);
    RTC_EnterInitMode();
    RTC_InitStructure.RTC_HourFormat = RTC_HourFormat_24;
    RTC_InitStructure.RTC_AsynchPrediv = AsynchPrediv; //也用过0x7D-1
    RTC_InitStructure.RTC_SynchPrediv = SynchPrediv; //0XFF-1
    RTC_Init(&RTC_InitStructure);
    RTC_TimeStructure.RTC_Seconds = 0x00;
    RTC_TimeStructure.RTC_Minutes = 0x01;
    RTC_TimeStructure.RTC_Hours = 0x11;
    //RTC_TimeStructure.RTC_H12 = RTC_H12_AM;
    RTC_SetTime(RTC_Format_BIN,&RTC_TimeStructure);
    RTC_DateStructure.RTC_Date = 30;
    RTC_DateStructure.RTC_Month = 5;
    //RTC_DateStructure.RTC_WeekDay= RTC_Weekday_Thursday;
    RTC_DateStructure.RTC_Year = 12;
    RTC_SetDate(RTC_Format_BIN,&RTC_DateStructure);
    RTC_ExitInitMode();
    RTC_WriteBackupRegister(RTC_BKP_DR0,0x5050);
    RTC_WriteProtectionCmd(ENABLE);
  PWR_BackupAccessCmd(DISABLE);
显示的话是下面这个程序,LCD已经在main里写好了,所以这边没写了。
void Get_TD(void){
LCD_ClearLine(LINE(7));
LCD_ClearLine(LINE(8));
LCD_ClearLine(LINE(9));
RTC_GetTime(RTC_Format_BIN,&RTC_TimeStructure);
sprintf((char*)tbuf,"Time:%02d:%02d:%02d",
                          RTC_TimeStructure.RTC_Hours,
                          RTC_TimeStructure.RTC_Minutes,
                          RTC_TimeStructure.RTC_Seconds);
LCD_DisplayStringLine(LINE(7),tbuf);
RTC_GetDate(RTC_Format_BIN, &RTC_DateStructure);
sprintf((char*)tbuf,"Date:20%02d/%02d/%02d",
                           RTC_DateStructure.RTC_Year,
                           RTC_DateStructure.RTC_Month,
                           RTC_DateStructure.RTC_Date);
LCD_DisplayStringLine(LINE(8),tbuf);        }
 楼主| njpanyi 发表于 2015-8-7 11:04 | 显示全部楼层
哎呀我知道了,是我main里有一个delay对它有影响了
进击的ic 发表于 2015-8-7 13:21 | 显示全部楼层
呵呵,多实践总是好的
mmuuss586 发表于 2015-8-7 13:22 | 显示全部楼层
解决了就好;
 楼主| njpanyi 发表于 2015-8-9 07:00 | 显示全部楼层
呵呵,多实践总是好的
谢谢回复~
谢谢回复~
豆腐块 发表于 2015-8-9 10:04 | 显示全部楼层
main里有一个delay对它有影响了,可以详细说一下吗
 楼主| njpanyi 发表于 2015-8-23 00:29 | 显示全部楼层
就是我delay100毫秒才获取时间然后显示,然后这样几次之后delay到一秒了显示就看起来像跳了一秒,我觉得好像是这样,我后来改了10毫秒就好了
米尔豪斯 发表于 2015-8-23 15:41 | 显示全部楼层
几次之后delay到一秒了显示就看起来像跳了一秒,是的
好风四季 发表于 2018-11-17 10:26 | 显示全部楼层
不是很明白,delay也不会影响到RTC的运行,就像我看手表,我1s内看10次手表,不可能51s直接跳到53s呀,至少也得有9次52s呀。而且我的跳秒比你的还严重,延时500ms,会跳1~10s。
handlike 发表于 2018-11-17 16:44 | 显示全部楼层
读取RTC和显示LCD的函数没有及时刷新或执行,这不是大问题把更重要的事情及时处理了是关键,没有更要的事情刷新执行的频率提高些都解决了。
