[Atmel]
SAML21走起12:ADC中断
921|0
这个程序是中断方式来AD转换。128个全转换完成就产生中断,而结果存在缓冲数组里。
程序是根据快速指导建立的。
程序如下:
#include <asf.h>
struct adc_module adc_instance;
#define ADC_SAMPLES 128
uint16_t adc_result_buffer[ADC_SAMPLES];
volatile bool adc_read_done = false;
void adc_complete_callback(struct adc_module *const module);
void configure_adc(void);
void configure_adc_callbacks(void);
        adc_read_done = true;
        struct adc_config config_adc;
        adc_get_config_defaults(&config_adc);
        #if (!SAML21)
        config_adc.gain_factor     = ADC_GAIN_FACTOR_DIV2;
        #endif
        config_adc.clock_prescaler = ADC_CLOCK_PRESCALER_DIV8;
        config_adc.reference       = ADC_REFERENCE_INTVCC1;
        config_adc.positive_input  = ADC_POSITIVE_INPUT_PIN6;
        config_adc.resolution      = ADC_RESOLUTION_12BIT;
        adc_init(&adc_instance, ADC, &config_adc);
        adc_enable(&adc_instance);
        adc_register_callback(&adc_instance,
        adc_complete_callback, ADC_CALLBACK_READ_BUFFER);
        adc_enable_callback(&adc_instance, ADC_CALLBACK_READ_BUFFER);
uint16_t result;
int main (void)
        system_init();
     configure_adc();
     configure_adc_callbacks();
         system_interrupt_enable_global();
         adc_read_buffer_job(&adc_instance, adc_result_buffer, ADC_SAMPLES);
         while (adc_read_done == false) {
                 /* Wait for asynchronous ADC read to complete */
         while (1) {
                 /* Infinite loop */
运行结果,可以看到数组里的数:
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2403
