小问个DB串口的简单问题
1597|1
 楼主| coolmark 发表于 2007-7-6 10:07 | 显示全部楼层 |阅读模式
引脚上的1--5是从针那端还是孔那端看的啊<br />3X
 楼主| coolmark 发表于 2007-7-6 11:03 | 显示全部楼层
找到答案了
在硬件手册上找到答案了,转到接头上还要换一下顺序<br /><br /><br /><br /><br /><br />&nbsp;(at&nbsp;the&nbsp;Computer)<br /><br />9&nbsp;PIN&nbsp;D-SUB&nbsp;MALE&nbsp;at&nbsp;the&nbsp;Computer.<br /><br />Pin&nbsp;Name&nbsp;RS232&nbsp;V.24&nbsp;Dir&nbsp;Description&nbsp;<br />1&nbsp;CD&nbsp;CF&nbsp;109&nbsp;&nbsp;Carrier&nbsp;Detect&nbsp;<br />2&nbsp;RXD&nbsp;BB&nbsp;104&nbsp;&nbsp;Receive&nbsp;Data&nbsp;<br />3&nbsp;TXD&nbsp;BA&nbsp;103&nbsp;&nbsp;Transmit&nbsp;Data&nbsp;<br />4&nbsp;DTR&nbsp;CD&nbsp;108.2&nbsp;&nbsp;Data&nbsp;Terminal&nbsp;Ready&nbsp;<br />5&nbsp;GND&nbsp;AB&nbsp;102&nbsp;&nbsp;System&nbsp;Ground&nbsp;<br />6&nbsp;DSR&nbsp;CC&nbsp;107&nbsp;&nbsp;Data&nbsp;Set&nbsp;Ready&nbsp;<br />7&nbsp;RTS&nbsp;CA&nbsp;105&nbsp;&nbsp;Request&nbsp;to&nbsp;Send&nbsp;<br />8&nbsp;CTS&nbsp;CB&nbsp;106&nbsp;&nbsp;Clear&nbsp;to&nbsp;Send&nbsp;<br />9&nbsp;RI&nbsp;CE&nbsp;125&nbsp;&nbsp;Ring&nbsp;Indicator&nbsp;<br /><br />Note:&nbsp;Direction&nbsp;is&nbsp;DTE&nbsp;(Computer)&nbsp;relative&nbsp;DCE&nbsp;(Modem).<br />Note:&nbsp;RS232&nbsp;column&nbsp;is&nbsp;RS232&nbsp;circuit&nbsp;name.<br />Note:&nbsp;V.24&nbsp;column&nbsp;is&nbsp;ITU-TSS&nbsp;V.24&nbsp;circuit&nbsp;name.&nbsp;<br />
