With regret I have to inform you that VC33 processors are obsolete processors and hence the Code Composer which is the IDE used for this processor is no longer supported by TI. Hence I would request you to try and rely on your retained employees and consultants and/or procure engineering services from a licensed professional engineer (LPE). |
