这个出错报告啥意思
528|4
jiajs|  楼主 | 2015-8-16 09:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TI, ST, rc, ce, se
出错报告:
Error connecting to the target:
Error 0x80000244/-1202
Fatal Error during: Register, Initialization, OCS,
CPU continually indicated it was 'not ready'
This is considered a catastrophic event, user can either force CPU ready
and continue the debug process by choosing button 'YES', or abort current
by reset the system
Sequence ID: 0
Error Code: -1202
Error Class: 0x80000244
Board Name: C6455 XDS560 Emulator
Cpu Name: C6400PLUS_0
Abort:  Close Code Composer Studio.
Retry:  Try to connect to the target again.
Cancel:  Remain disconnected from the target
Diagnostic: Run diagnostic utility.
zhanghqi| | 2015-8-16 09:04 | 只看该作者
你遇到什么问题了
jiajs|  楼主 | 2015-8-16 09:04 | 只看该作者
求教dsp的复位信号时间能不能过长,1.2v内核电压纹波值200mv算不算大?
jiajs|  楼主 | 2015-8-16 09:05 | 只看该作者
?就是连不上仿真器,不知道是什么问题
vivilzb1985| | 2015-8-16 22:56 | 只看该作者
这个我得经验是检查下你的仿真编译器的连接的吧。
