版主选的**真不错
14498|46
 楼主| iC921 发表于 2008-3-12 00:23 | 显示全部楼层 |阅读模式
在模拟技术,如图是曾经有人跟帖说不明白如图的电-光驱动电路。那些电阻,那些二极管为什么要加?如何加?<br /><br />时间好长了,记得当时没有明确的答案,我也答这不上。偶然碰到一个器件手册内的部分内容,这就有了明确的答案了。前面部分我译出来了,感觉还可以,可是后面部分有的有点难,看看哪位来?<br /><br /><b>Common-Mode&nbsp;Rejection&nbsp;&&nbsp;LED&nbsp;Driver&nbsp;Circuits</b><br /><br />[1]With&nbsp;the&nbsp;combination&nbsp;of&nbsp;a&nbsp;high&nbsp;efficiency&nbsp;AlGaAs&nbsp;LED&nbsp;and&nbsp;a&nbsp;high-gain&nbsp;amplifier&nbsp;in&nbsp;the&nbsp;HCPL-&nbsp;47XX&nbsp;optocoupler,&nbsp;a&nbsp;few&nbsp;circuit&nbsp;techniques&nbsp;can&nbsp;enhance&nbsp;the&nbsp;common-mode&nbsp;rejection&nbsp;(CMR)&nbsp;of&nbsp;this&nbsp;optocoupler.&nbsp;First,&nbsp;use&nbsp;good&nbsp;high-frequency&nbsp;circuit&nbsp;layout&nbsp;practices&nbsp;to&nbsp;minimize&nbsp;coupling&nbsp;of&nbsp;common-mode&nbsp;signals&nbsp;between&nbsp;input&nbsp;and&nbsp;output&nbsp;circuits.&nbsp;Keep&nbsp;input&nbsp;traces&nbsp;away&nbsp;from&nbsp;output&nbsp;traces&nbsp;to&nbsp;minimize&nbsp;capacitive&nbsp;coupling&nbsp;of&nbsp;interference&nbsp;between&nbsp;input&nbsp;and&nbsp;output&nbsp;sections.&nbsp;If&nbsp;possible,&nbsp;parallel,&nbsp;or&nbsp;shunt&nbsp;switch&nbsp;the&nbsp;LED&nbsp;current&nbsp;as&nbsp;shown&nbsp;in&nbsp;Figure&nbsp;13,&nbsp;rather&nbsp;than&nbsp;series&nbsp;switch&nbsp;the&nbsp;LED&nbsp;current&nbsp;as&nbsp;illustrated&nbsp;in&nbsp;Figure&nbsp;15.&nbsp;Not&nbsp;only&nbsp;will&nbsp;CMR&nbsp;be&nbsp;enhanced&nbsp;with&nbsp;these&nbsp;circuits&nbsp;(Figures&nbsp;13&nbsp;and&nbsp;14),&nbsp;but&nbsp;the&nbsp;switching&nbsp;speed&nbsp;of&nbsp;the&nbsp;optocoupler&nbsp;will&nbsp;be&nbsp;improved&nbsp;as&nbsp;well.&nbsp;This&nbsp;is&nbsp;because&nbsp;in&nbsp;the&nbsp;parallel&nbsp;switched&nbsp;case&nbsp;the&nbsp;LED&nbsp;current&nbsp;is&nbsp;current-steered&nbsp;into&nbsp;or&nbsp;away&nbsp;from&nbsp;the&nbsp;LED,&nbsp;rather&nbsp;than&nbsp;being&nbsp;fully&nbsp;turned&nbsp;off&nbsp;as&nbsp;in&nbsp;the&nbsp;series&nbsp;switched&nbsp;case.<br /><br />一些电路技术能增强集高效率和高增益放大器于一体的HCPL-&nbsp;47XX光电耦合器的共模抑制(CMR)[效果]。好的高频布线习惯能让输入输出端的共模信号耦合最小化。布线时,让输入线路和输出线路尽可能地远离,可让输入输出侧的偶合电容最小化。如果可以,象图13那样并联或串联开关,其效果将优于图15那样的开关串联在LED二极管回路中的方法。这样的电路(Figures&nbsp;13&nbsp;and&nbsp;14)不但共模抑制CMR增强,光耦的开关速度也将得到改善。这是因为并联的开关可以直接引起LED二极管电流的流入或流出,其效果将优于完全依靠串联开关关断(控制通断)的情况。<br /><br />[2]&nbsp;Figure&nbsp;13&nbsp;illustrates&nbsp;this&nbsp;type&nbsp;of&nbsp;circuit.&nbsp;The&nbsp;Schottky&nbsp;diode&nbsp;helps&nbsp;quickly&nbsp;to&nbsp;discharge&nbsp;and&nbsp;pre-bias&nbsp;the&nbsp;LED&nbsp;in&nbsp;the&nbsp;off&nbsp;state.&nbsp;If&nbsp;a&nbsp;common-mode&nbsp;voltage&nbsp;across&nbsp;the&nbsp;optocoupler&nbsp;suddenly&nbsp;attempts&nbsp;to&nbsp;inject&nbsp;a&nbsp;current&nbsp;into&nbsp;the&nbsp;off&nbsp;LED&nbsp;anode,&nbsp;the&nbsp;Schottky&nbsp;diode&nbsp;would&nbsp;divert&nbsp;the&nbsp;interfering&nbsp;current&nbsp;to&nbsp;ground.&nbsp;The&nbsp;combination&nbsp;of&nbsp;the&nbsp;Schottky&nbsp;diode&nbsp;forward&nbsp;voltage&nbsp;and&nbsp;the&nbsp;Vol&nbsp;saturation&nbsp;voltage&nbsp;of&nbsp;the&nbsp;driver&nbsp;output&nbsp;stage&nbsp;(on-condition)&nbsp;will&nbsp;keep&nbsp;the&nbsp;LED&nbsp;voltage&nbsp;at&nbsp;or&nbsp;below&nbsp;0.8&nbsp;V.&nbsp;This&nbsp;will&nbsp;prevent&nbsp;the&nbsp;LED&nbsp;(off-condition)&nbsp;from&nbsp;conducting&nbsp;any&nbsp;significant&nbsp;forward&nbsp;current&nbsp;that&nbsp;might&nbsp;cause&nbsp;the&nbsp;HCPL-47XX&nbsp;to&nbsp;turn&nbsp;on.&nbsp;Also,&nbsp;if&nbsp;the&nbsp;driver&nbsp;stage&nbsp;is&nbsp;an&nbsp;active&nbsp;totem-pole&nbsp;output,&nbsp;the&nbsp;Schottky&nbsp;diode&nbsp;allows&nbsp;the&nbsp;active&nbsp;output&nbsp;pull-up&nbsp;section&nbsp;to&nbsp;disconnect&nbsp;from&nbsp;the&nbsp;LED&nbsp;and&nbsp;pull&nbsp;high.<br /><br />如图13所示的电路型式,肖特基二极管可以帮助关断状态的LED快速充电和预偏置。如果光耦的共模电压地试图注入关断中的LED阳极,则肖特基二极管会帝路此电流到地GND。肖特基二极管的正向电压和驱动器输出级的饱和导通电压(on-condition)将一起保持LED在/低于0.8&nbsp;V,也就防止了能引起HCPL-47XX导通的任何正向电流进入LED二极管(off-condition)。同样,如果驱动级是有源的图腾柱输出(totem-pole&nbsp;output),肖特基二极管允许有源输出的上拉但却截断了LED的联系。<br /><br />&nbsp;<br />&nbsp;<br />[3]As&nbsp;shown&nbsp;in&nbsp;Figure&nbsp;14,&nbsp;most&nbsp;active&nbsp;output&nbsp;driver&nbsp;integrated&nbsp;circuits&nbsp;can&nbsp;source&nbsp;directly&nbsp;the&nbsp;forward&nbsp;current&nbsp;needed&nbsp;to&nbsp;operate&nbsp;the&nbsp;LED&nbsp;of&nbsp;the&nbsp;HCPL-47XX&nbsp;optocoupler.&nbsp;The&nbsp;advantage&nbsp;of&nbsp;using&nbsp;the&nbsp;silicon&nbsp;diode&nbsp;in&nbsp;this&nbsp;circuit&nbsp;is&nbsp;to&nbsp;conduct&nbsp;charge&nbsp;out&nbsp;of&nbsp;the&nbsp;LED&nbsp;quickly&nbsp;when&nbsp;the&nbsp;LED&nbsp;is&nbsp;turned&nbsp;off.&nbsp;Upon&nbsp;turn-on&nbsp;of&nbsp;the&nbsp;LED,&nbsp;the&nbsp;silicon&nbsp;diode&nbsp;capacitance&nbsp;will&nbsp;provide&nbsp;a&nbsp;rapid&nbsp;charging&nbsp;path&nbsp;(peaking&nbsp;current)&nbsp;for&nbsp;the&nbsp;LED.&nbsp;In&nbsp;addition,&nbsp;this&nbsp;silicon&nbsp;diode&nbsp;prevents&nbsp;commonmode&nbsp;current&nbsp;from&nbsp;entering&nbsp;the&nbsp;LED&nbsp;anode&nbsp;when&nbsp;the&nbsp;driver&nbsp;IC&nbsp;is&nbsp;on&nbsp;and&nbsp;no&nbsp;operating&nbsp;LED&nbsp;current&nbsp;exists.<br /><br />如图14所示,大多数集成电路有源驱动器能泵出HCPL-47XX光电耦合器的LED所需的正向工作电流。该电路用硅二极管的优势在于在关闭LED二极管时能快速抽出它的电荷。而要点亮该LED二极管时,硅二极管的电容又能为它提供快速充电的路径(即峰值电流)。另外,在驱动器IC导通(ON)和LED不存在工作电流时,该硅二极管还可以防止共模电流注入发光二极管的阳极。<br /><br /><img src="http://blog.21ic.com/uploadfiles/2008-5/3311478008.gif"><br />原图不能显示,改由BLOG上传补上https://bbs.21ic.com/upfiles/img/20083/200831201718650.gif<br /><br /><b>以下部分怎么也译不好,看看哪位来?!</b><br /><br />[4]&nbsp;In&nbsp;general,&nbsp;series&nbsp;switching&nbsp;the&nbsp;low&nbsp;input&nbsp;current&nbsp;of&nbsp;the&nbsp;HCPL-47XX&nbsp;LED&nbsp;is&nbsp;not&nbsp;recommended.&nbsp;This&nbsp;is&nbsp;particularly&nbsp;valid&nbsp;when&nbsp;in&nbsp;a&nbsp;high&nbsp;common-mode&nbsp;interference&nbsp;environment.&nbsp;However,&nbsp;if&nbsp;series&nbsp;switching&nbsp;of&nbsp;the&nbsp;LED&nbsp;current&nbsp;must&nbsp;be&nbsp;done,&nbsp;use&nbsp;an&nbsp;additional&nbsp;pull-up&nbsp;resistor&nbsp;from&nbsp;the&nbsp;cathode&nbsp;of&nbsp;the&nbsp;LED&nbsp;to&nbsp;the&nbsp;input&nbsp;VCC&nbsp;as&nbsp;shown&nbsp;in&nbsp;Figure&nbsp;15.&nbsp;This&nbsp;helps&nbsp;minimize&nbsp;any&nbsp;differential-mode&nbsp;current&nbsp;from&nbsp;conducting&nbsp;in&nbsp;the&nbsp;LED&nbsp;while&nbsp;the&nbsp;LED&nbsp;is&nbsp;off,&nbsp;due&nbsp;to&nbsp;a&nbsp;common-mode&nbsp;signal&nbsp;occurring&nbsp;on&nbsp;the&nbsp;input&nbsp;VCC&nbsp;(anode)&nbsp;of&nbsp;the&nbsp;LED.&nbsp;The&nbsp;commonmode&nbsp;signal&nbsp;coupling&nbsp;to&nbsp;the&nbsp;anode&nbsp;and&nbsp;cathode&nbsp;could&nbsp;be&nbsp;slightly&nbsp;different.&nbsp;This&nbsp;could&nbsp;potentially&nbsp;create&nbsp;a&nbsp;LED&nbsp;current&nbsp;to&nbsp;flow&nbsp;that&nbsp;would&nbsp;rival&nbsp;the&nbsp;normal,&nbsp;low&nbsp;input&nbsp;current&nbsp;needed&nbsp;to&nbsp;operate&nbsp;the&nbsp;optocoupler.&nbsp;This&nbsp;additional&nbsp;parallel&nbsp;resistor&nbsp;can&nbsp;help&nbsp;shunt&nbsp;any&nbsp;leakage&nbsp;current&nbsp;around&nbsp;the&nbsp;LED&nbsp;should&nbsp;the&nbsp;drive&nbsp;circuit,&nbsp;in&nbsp;the&nbsp;off&nbsp;state,&nbsp;have&nbsp;any&nbsp;significant&nbsp;leakage&nbsp;current&nbsp;on&nbsp;the&nbsp;order&nbsp;of&nbsp;40&nbsp;μA.<br /><br /><br />[5]With&nbsp;the&nbsp;use&nbsp;of&nbsp;this&nbsp;parallel&nbsp;resistor,&nbsp;the&nbsp;total&nbsp;drive&nbsp;current&nbsp;conducted&nbsp;when&nbsp;the&nbsp;LED&nbsp;is&nbsp;on&nbsp;is&nbsp;the&nbsp;sum&nbsp;of&nbsp;the&nbsp;parallel&nbsp;resistor&nbsp;and&nbsp;LED&nbsp;currents.&nbsp;In&nbsp;the&nbsp;series&nbsp;circuit&nbsp;of&nbsp;Figure&nbsp;15&nbsp;with&nbsp;the&nbsp;LED&nbsp;off,&nbsp;if&nbsp;a&nbsp;common-mode&nbsp;voltage&nbsp;were&nbsp;to&nbsp;couple&nbsp;to&nbsp;the&nbsp;LED&nbsp;cathode,&nbsp;there&nbsp;can&nbsp;be&nbsp;enough&nbsp;imbalance&nbsp;of&nbsp;common-mode&nbsp;voltage&nbsp;across&nbsp;the&nbsp;LED&nbsp;to&nbsp;cause&nbsp;a&nbsp;LED&nbsp;current&nbsp;to&nbsp;flow&nbsp;and,&nbsp;inadvertently,&nbsp;turn&nbsp;on&nbsp;the&nbsp;optocoupler.&nbsp;This&nbsp;series,&nbsp;switching&nbsp;circuit&nbsp;has&nbsp;no&nbsp;protection&nbsp;against&nbsp;a&nbsp;negative-transition,&nbsp;input&nbsp;commonmode&nbsp;signal.<br />
ocon 发表于 2008-3-12 16:36 | 显示全部楼层
简单的电路原来有这么多道理,
看来电路上到高频后要考虑的问题真不少。
ocon 发表于 2008-3-12 18:11 | 显示全部楼层
接上,
[4]一般不推荐串联开关在低端的办法来控制HCPL-47XX&nbsp;LED的输入电流。这在高共模干扰环境下显而易见。然而,如果一定要这么干,需要依图15所示从LED的负极接个上拉电阻到VCC,这有助于降低LED关闭时串过来的差模干扰电流,原因是,共模干扰信号作用于LED的正极的VCC,而此信号在LED的正负两端耦合情况有些微差异,这将可能在LED上产生电流并导致其工作异常。这个额外并联的电阻将有助于消除泄漏电流对LED的影响,在LED关闭状态,对于工作电流只有40μA的LED来说任何泄漏电流都很重要。
 楼主| iC921 发表于 2008-3-12 20:55 | 显示全部楼层
谢谢老乡!
这句可能没有处理好,我也是在这被堵住了----<br />This&nbsp;could&nbsp;potentially&nbsp;create&nbsp;a&nbsp;LED&nbsp;current&nbsp;to&nbsp;flow&nbsp;that&nbsp;would&nbsp;rival&nbsp;the&nbsp;normal,&nbsp;low&nbsp;input&nbsp;current&nbsp;needed&nbsp;to&nbsp;operate&nbsp;the&nbsp;optocoupler.<br />“这将可能在LED上产生电流并导致其工作异常”
ocon 发表于 2008-3-12 21:06 | 显示全部楼层
继续
[5]由于这个并联电阻,当LED点亮时,总驱动电流等于LED电流与并联电阻电流之和。在图15的串联电路里,当LED关闭时,如果一个共模电压耦合到LED负极,将在LED上产生足够的不平衡电压,致使电流流过LED导致光耦意外导通。这个串联开关电路,对输入的共模信号的负跃迁没有保护功能。
ocon 发表于 2008-3-12 21:10 | 显示全部楼层
用金山词霸译的,可能有问题,我的英语在高中时就没及格
 楼主| iC921 发表于 2008-3-12 21:20 | 显示全部楼层
没事,我也是瞎碰撞
后面的我正在尝试进行中……
 楼主| iC921 发表于 2008-3-12 22:38 | 显示全部楼层
很不错啊!不过此处turn on译作点亮什么的比较好
<br /><br />[5]With&nbsp;the&nbsp;use&nbsp;of&nbsp;this&nbsp;parallel&nbsp;resistor,&nbsp;the&nbsp;total&nbsp;drive&nbsp;current&nbsp;conducted&nbsp;when&nbsp;the&nbsp;LED&nbsp;is&nbsp;on&nbsp;is&nbsp;the&nbsp;sum&nbsp;of&nbsp;the&nbsp;parallel&nbsp;resistor&nbsp;and&nbsp;LED&nbsp;currents.&nbsp;<font color=#0000FF>In&nbsp;the&nbsp;series&nbsp;circuit&nbsp;of&nbsp;Figure&nbsp;15&nbsp;with&nbsp;the&nbsp;LED&nbsp;off,&nbsp;if&nbsp;a&nbsp;common-mode&nbsp;voltage&nbsp;were&nbsp;to&nbsp;couple&nbsp;to&nbsp;the&nbsp;LED&nbsp;cathode,&nbsp;there&nbsp;can&nbsp;be&nbsp;enough&nbsp;imbalance&nbsp;of&nbsp;common-mode&nbsp;voltage&nbsp;across&nbsp;the&nbsp;LED&nbsp;to&nbsp;cause&nbsp;a&nbsp;LED&nbsp;current&nbsp;to&nbsp;flow&nbsp;and,&nbsp;inadvertently,&nbsp;turn&nbsp;on&nbsp;the&nbsp;optocoupler.</font>&nbsp;This&nbsp;series,&nbsp;switching&nbsp;circuit&nbsp;has&nbsp;no&nbsp;protection&nbsp;against&nbsp;a&nbsp;negative-transition,&nbsp;input&nbsp;commonmode&nbsp;signal.<br /><br />用了并联电阻后,发光二极管LED导通时,总驱动电流为该电阻和二极管的电流之和。如图15所示的一类电路,发光二极管LED关闭时,如果有共模电压耦合到它的阴极,就有足够的不平衡电压致使流过而意外地点亮光耦的LED。也就是说,这种开关串联于LED的电路,对负向共模输入信号不提供保护。<br />
 楼主| iC921 发表于 2008-3-12 22:40 | 显示全部楼层
问:什么情况下会在阴极出现“负”干扰呢?
decoder8 发表于 2008-3-13 12:55 | 显示全部楼层
做个记号慢慢看!
 楼主| iC921 发表于 2008-3-13 18:51 | 显示全部楼层
内容不多,有E文才显得太长
不知道谁给我加酷,打乱了我要记录55000分的计划。当然,这也得谢谢它,省得老hot谰我“腐败”……
mxh0506 发表于 2008-3-14 22:27 | 显示全部楼层
版主选的**真不错
又学习了
asunmad 发表于 2008-3-17 22:44 | 显示全部楼层
RE:电路精选:曾经有人说不明白的驱动电路
[4]&nbsp;In&nbsp;general,&nbsp;series&nbsp;switching&nbsp;the&nbsp;low&nbsp;input&nbsp;current&nbsp;of&nbsp;the&nbsp;HCPL-47XX&nbsp;LED&nbsp;is&nbsp;not&nbsp;recommended.&nbsp;This&nbsp;is&nbsp;particularly&nbsp;valid&nbsp;when&nbsp;in&nbsp;a&nbsp;high&nbsp;common-mode&nbsp;interference&nbsp;environment.&nbsp;However,&nbsp;if&nbsp;series&nbsp;switching&nbsp;of&nbsp;the&nbsp;LED&nbsp;current&nbsp;must&nbsp;be&nbsp;done,&nbsp;use&nbsp;an&nbsp;additional&nbsp;pull-up&nbsp;resistor&nbsp;from&nbsp;the&nbsp;cathode&nbsp;of&nbsp;the&nbsp;LED&nbsp;to&nbsp;the&nbsp;input&nbsp;VCC&nbsp;as&nbsp;shown&nbsp;in&nbsp;Figure&nbsp;15.&nbsp;This&nbsp;helps&nbsp;minimize&nbsp;any&nbsp;differential-mode&nbsp;current&nbsp;from&nbsp;conducting&nbsp;in&nbsp;the&nbsp;LED&nbsp;while&nbsp;the&nbsp;LED&nbsp;is&nbsp;off,&nbsp;due&nbsp;to&nbsp;a&nbsp;common-mode&nbsp;signal&nbsp;occurring&nbsp;on&nbsp;the&nbsp;input&nbsp;VCC&nbsp;(anode)&nbsp;of&nbsp;the&nbsp;LED.&nbsp;The&nbsp;commonmode&nbsp;signal&nbsp;coupling&nbsp;to&nbsp;the&nbsp;anode&nbsp;and&nbsp;cathode&nbsp;could&nbsp;be&nbsp;slightly&nbsp;different.&nbsp;This&nbsp;could&nbsp;potentially&nbsp;create&nbsp;a&nbsp;LED&nbsp;current&nbsp;to&nbsp;flow&nbsp;that&nbsp;would&nbsp;rival&nbsp;the&nbsp;normal,&nbsp;low&nbsp;input&nbsp;current&nbsp;needed&nbsp;to&nbsp;operate&nbsp;the&nbsp;optocoupler.&nbsp;This&nbsp;additional&nbsp;parallel&nbsp;resistor&nbsp;can&nbsp;help&nbsp;shunt&nbsp;any&nbsp;leakage&nbsp;current&nbsp;around&nbsp;the&nbsp;LED&nbsp;should&nbsp;the&nbsp;drive&nbsp;circuit,&nbsp;in&nbsp;the&nbsp;off&nbsp;state,&nbsp;have&nbsp;any&nbsp;significant&nbsp;leakage&nbsp;current&nbsp;on&nbsp;the&nbsp;order&nbsp;of&nbsp;40&nbsp;μA.<br /><br />[4]&nbsp;LED附件的泄漏电流得以分流。一般不建议对小电流的HCPL-47XX&nbsp;LED实行串联开关驱动,在共模干扰强的环境中尤其如此。如果必须使用串联开关驱动,则应该在LED的阴极到VCC输入之间增加一个上拉电阻,如图15所示。这样,在LED关闭期间LED的VCC输入端(阳极)出现的共模信号时,尽可能地减小了差模电流使LED导通的可能性。耦合到阳极和阴极的共模信号可能略有差别,这将可能建立起足以强过使光耦工作的正常模式小电流。如果驱动电路在关态有40μA数量级的明显的泄漏电流,增加这个并联电阻使LED附近的泄漏电流得以分流。<br />
 楼主| iC921 发表于 2008-3-18 01:03 | 显示全部楼层
OK,终于完全明白了!无论翻译还是理解,这句是关键----
The&nbsp;commonmode&nbsp;signal&nbsp;coupling&nbsp;to&nbsp;the&nbsp;anode&nbsp;and&nbsp;cathode&nbsp;could&nbsp;be&nbsp;slightly&nbsp;different.<br />共模电压(电源VCC)加到发光二极管LED两极后会小有不同,原因就是那个串联的开关会漏电吧。<br /><br />[这样,在LED关闭期间LED的VCC输入端(阳极)出现的共模信号时,尽可能地减小了差模电流使LED导通的可能性。耦合到阳极和阴极的共模信号可能略有差别]<br />[原因是,共模干扰信号作用于LED的正极的VCC,而此信号在LED的正负两端耦合情况有些微差异]。<br /><br /><br /><br />[4]&nbsp;In&nbsp;general,&nbsp;series&nbsp;switching&nbsp;the&nbsp;low&nbsp;input&nbsp;current&nbsp;of&nbsp;the&nbsp;HCPL-47XX&nbsp;LED&nbsp;is&nbsp;not&nbsp;recommended.&nbsp;This&nbsp;is&nbsp;particularly&nbsp;valid&nbsp;when&nbsp;in&nbsp;a&nbsp;high&nbsp;common-mode&nbsp;interference&nbsp;environment.&nbsp;However,&nbsp;if&nbsp;series&nbsp;switching&nbsp;of&nbsp;the&nbsp;LED&nbsp;current&nbsp;must&nbsp;be&nbsp;done,&nbsp;use&nbsp;an&nbsp;additional&nbsp;pull-up&nbsp;resistor&nbsp;from&nbsp;the&nbsp;cathode&nbsp;of&nbsp;the&nbsp;LED&nbsp;to&nbsp;the&nbsp;input&nbsp;VCC&nbsp;as&nbsp;shown&nbsp;in&nbsp;Figure&nbsp;15.&nbsp;This&nbsp;helps&nbsp;minimize&nbsp;any&nbsp;differential-mode&nbsp;current&nbsp;from&nbsp;conducting&nbsp;in&nbsp;the&nbsp;LED&nbsp;while&nbsp;the&nbsp;LED&nbsp;is&nbsp;off,&nbsp;due&nbsp;to&nbsp;a&nbsp;common-mode&nbsp;signal&nbsp;occurring&nbsp;on&nbsp;the&nbsp;input&nbsp;VCC&nbsp;(anode)&nbsp;of&nbsp;the&nbsp;LED.&nbsp;<font color=#0000FF>The&nbsp;commonmode&nbsp;signal&nbsp;coupling&nbsp;to&nbsp;the&nbsp;anode&nbsp;and&nbsp;cathode&nbsp;could&nbsp;be&nbsp;slightly&nbsp;different.&nbsp;</font>This&nbsp;could&nbsp;potentially&nbsp;create&nbsp;a&nbsp;LED&nbsp;current&nbsp;to&nbsp;flow&nbsp;that&nbsp;would&nbsp;rival&nbsp;the&nbsp;normal,&nbsp;low&nbsp;input&nbsp;current&nbsp;needed&nbsp;to&nbsp;operate&nbsp;the&nbsp;optocoupler.&nbsp;This&nbsp;additional&nbsp;parallel&nbsp;resistor&nbsp;can&nbsp;help&nbsp;shunt&nbsp;any&nbsp;leakage&nbsp;current&nbsp;around&nbsp;the&nbsp;LED&nbsp;should&nbsp;the&nbsp;drive&nbsp;circuit,&nbsp;in&nbsp;the&nbsp;off&nbsp;state,&nbsp;have&nbsp;any&nbsp;significant&nbsp;leakage&nbsp;current&nbsp;on&nbsp;the&nbsp;order&nbsp;of&nbsp;40&nbsp;μA.<br /><br />[4]&nbsp;LED附件的泄漏电流得以分流。一般不建议对小电流的HCPL-47XX&nbsp;LED实行串联开关驱动,在共模干扰强的环境中尤其如此。如果必须使用串联开关驱动,则应该在LED的阴极到VCC输入之间增加一个上拉电阻,如图15所示。这样,在LED关闭期间LED的VCC输入端(阳极)出现的共模信号时,尽可能地减小了差模电流使LED导通的可能性。耦合到阳极和阴极的共模信号可能略有差别,这将可能建立起足以强过使光耦工作的正常模式小电流。如果驱动电路在关态有40μA数量级的明显的泄漏电流,增加这个并联电阻使LED附近的泄漏电流得以分流。<br /><br /><br />[4]一般不推荐串联开关在低端的办法来控制HCPL-47XX&nbsp;LED的输入电流。这在高共模干扰环境下显而易见。然而,如果一定要这么干,需要依图15所示从LED的负极接个上拉电阻到VCC,这有助于降低LED关闭时串过来的差模干扰电流,原因是,共模干扰信号作用于LED的正极的VCC,而此信号在LED的正负两端耦合情况有些微差异,这将可能在LED上产生电流并导致其工作异常。这个额外并联的电阻将有助于消除泄漏电流对LED的影响,在LED关闭状态,对于工作电流只有40μA的LED来说任何泄漏电流都很重要。<br /><br />
asunmad 发表于 2008-3-18 21:53 | 显示全部楼层
不小心把尾巴贴到开头了。
昨晚匆匆一贴,突然发现有名字,改一下,却把错误的尾巴弄到开头来了:(<br /><br />最后一句自己也感觉译得拗口,但觉得意义是我理解的那个。<br /><br />This&nbsp;additional&nbsp;parallel&nbsp;resistor&nbsp;can&nbsp;help&nbsp;shunt&nbsp;any&nbsp;leakage&nbsp;current&nbsp;around&nbsp;the&nbsp;LED&nbsp;should&nbsp;the&nbsp;drive&nbsp;circuit,&nbsp;in&nbsp;the&nbsp;off&nbsp;state,&nbsp;have&nbsp;any&nbsp;significant&nbsp;leakage&nbsp;current&nbsp;on&nbsp;the&nbsp;order&nbsp;of&nbsp;40&nbsp;μA.<br />&nbsp;=<br />This&nbsp;additional&nbsp;parallel&nbsp;resistor&nbsp;can&nbsp;help&nbsp;shunt&nbsp;any&nbsp;leakage&nbsp;current&nbsp;around&nbsp;the&nbsp;LED&nbsp;if&nbsp;the&nbsp;drive&nbsp;circuit&nbsp;should&nbsp;have&nbsp;any&nbsp;significant&nbsp;leakage&nbsp;current&nbsp;on&nbsp;the&nbsp;order&nbsp;of&nbsp;40&nbsp;μA&nbsp;when&nbsp;it&nbsp;is&nbsp;in&nbsp;the&nbsp;off&nbsp;state.<br />所以on&nbsp;the&nbsp;order&nbsp;of&nbsp;40&nbsp;μA指的是leakage&nbsp;current。<br />其中should&nbsp;....&nbsp;=&nbsp;if&nbsp;....&nbsp;should,是虚拟语句的一种表达方式。<br />shunt是旁路,如果没有这个电阻,驱动电路的关态漏电流只能从LED流过,有了这个电阻,就可以从这个电阻流过了,这就把LED给旁路了。
 楼主| iC921 发表于 2008-3-18 22:20 | 显示全部楼层
哈哈,我以为你是突出那一句的呢……
从应用上说,确实是这一句有意义。但从理解上说,我倒是觉得共模电压在两点上存在差异是关键,比如开关泄漏电流,共模电压波动而通过开关两端的电容耦合成回路等。
anewlife 发表于 2008-3-19 12:55 | 显示全部楼层
学习学习~~~
apcfy 发表于 2008-3-20 11:13 | 显示全部楼层
牛人,谢谢!
5_0_5 发表于 2008-3-20 12:54 | 显示全部楼层
学习的
要多动脑筋 发表于 2008-3-27 18:45 | 显示全部楼层
