AC(alternating current) 交流(电)<br />A/D(analog to digital) 模拟/数字转换<br />ADC(analog to digital convertor) 模拟/数字转换器<br />ADM(adaptive delta modulation) 自适应增量调制<br />ADPCM(adaptive differential pulse code modulation) 自适应差分脉冲编码调制<br />ALU(arithmetic logic unit) 算术逻辑单元<br />ASCII(American standard code for information interchange) 美国信息交换标准码<br />AV(audio visual) 声视,视听<br />BCD(binary coded decimal) 二进制编码的十进制数<br />BCR(bi-directional controlled rectifier)双向晶闸管<br />BCR(buffer courtier reset) 缓冲计数器<br />BZ(buzzer) 蜂鸣器,蜂音器<br />C(capacitance,capacitor) 电容量,电容器<br />CATV(cable television) 电缆电视<br />CCD(charge-coupled device) 电荷耦合器件<br />CCTV(closed-circuit television) 闭路电视<br />CMOS(complementary) 互补MOS<br />CPU(central processing unit)中央处理单元<br />CS(control signal) 控制信号<br />D(diode) 二极管<br />DAST(direct analog store technology) 直接模拟存储技术<br />DC(direct current) 直流<br />DIP(dual in-line package) 双列直插封装<br />DP(dial pulse) 拨号脉冲<br />DRAM(dynamic random access memory) 动态随机存储器<br />DTL(diode-transistor logic) 二极管晶体管逻辑<br />DUT(device under test) 被测器件<br />DVM(digital voltmeter) 数字电压表<br />ECG(electrocardiograph) 心电图<br />ECL(emitter coupled logic) 射极耦合逻辑<br />EDI(electronic data interchange) 电子数据交换<br />EIA(Electronic Industries Association) 电子工业联合会<br />EOC(end of conversion) 转换结束<br />EPROM(erasable programmable read only memory) 可擦可编程只读存储器<br />EEPROM(electrically EPROM) 电可擦可编程只读存储器<br />ESD(electro-static discharge) 静电放电<br />FET(field-effect transistor) 场效应晶体管<br />FS(full scale) 满量程<br />F/V(frequency to voltage convertor) 频率/电压转换<br />FM(frequency modulation) 调频<br />FSK(frequency shift keying) 频移键控<br />FSM(field strength meter) 场强计<br />FST(fast switching shyster) 快速晶闸管<br />FT(fixed time) 固定时间<br />FU(fuse unit) 保险丝装置<br />FWD(forward) 正向的<br />GAL(generic array logic) 通用阵列逻辑<br />GND(ground) 接地,地线<br />GTO(Sate turn off thruster) 门极可关断晶体管<br />HART(highway addressable remote transducer) 可寻址远程传感器数据公路<br />HCMOS(high density COMS) 高密度互补金属氧化物半导体(器件)<br />HF(high frequency) 高频<br />HTL(high threshold logic) 高阈值逻辑电路<br />HTS(heat temperature sensor) 热温度传感器<br />IC(integrated circuit) 集成电路<br />ID(international data) 国际数据<br />IGBT(insulated gate bipolar transistor) 绝缘栅双极型晶体管<br />IGFET(insulated gate field effect transistor) 绝缘栅场效应晶体管<br />I/O(input/output) 输入/输出<br />I/V(current to voltage convertor) 电流-电压变换器<br />IPM(incidental phase modulation) 附带的相位调制<br />IPM(intelligent power module) 智能功率模块<br />IR(infrared radiation) 红外辐射<br />IRQ(interrupt request) 中断请求<br />JFET(junction field effect transistor) 结型场效应晶体管<br />LAS(light activated switch)光敏开关<br />LASCS(light activated silicon controlled switch) 光控可控硅开关<br />LCD(liquid crystal display) 液晶显示器<br />LDR(light dependent resistor) 光敏电阻<br />LED(light emitting diode) 发光二极管<br />LRC(longitudinal redundancy check) 纵向冗余(码)校验<br />LSB(least significant bit) 最低有效位<br />LSI(1arge scale integration) 大规模集成电路<br />M(motor) 电动机<br />MCT(MOS controlled gyrator) 场控晶闸管<br />MIC(microphone) 话筒,微音器,麦克风<br />min(minute) 分<br />MOS(metal oxide semiconductor)金属氧化物半导体<br />MOSFET(metal oxide semiconductor FET) 金属氧化物半导体场效应晶体管<br />N(negative) 负<br />NMOS(N-channel metal oxide semiconductor FET) N沟道MOSFET<br />NTC(negative temperature coefficient) 负温度系数<br />OC(over current) 过电流<br />OCB(overload circuit breaker) 过载断路器<br />OCS(optical communication system) 光通讯系统<br />OR(type of logic circuit) 或逻辑电路<br />OV(over voltage) 过电压<br />P(pressure) 压力<br />FAM(pulse amplitude modulation) 脉冲幅度调制<br />PC(pulse code) 脉冲码<br />PCM(pulse code modulation) 脉冲编码调制<br />PDM(pulse duration modulation) 脉冲宽度调制<br />PF(power factor) 功率因数<br />PFM(pulse frequency modulation) 脉冲频率调制<br />PG(pulse generator) 脉冲发生器<br />PGM(programmable) 编程信号<br />PI(proportional-integral(controller)) 比例积分(控制器)<br />PID(proportional-integral-differential(controller))比例积分微分(控制器)<br />PIN(positive intrinsic-negative) 光电二极管<br />PIO(parallel input output) 并行输入输出<br />PLD(phase-locked detector) 同相检波<br />PLD(phase-locked discriminator) 锁相解调器<br />PLL(phase-locked loop) 锁相环路<br />PMOS(P-channel metal oxide semiconductor FET) P沟道MOSFET<br />P-P(peak-to-peak) 峰--峰<br />PPM(pulse phase modulation) 脉冲相位洲制<br />PRD(piezoelectric radiation detector) 热电辐射控测器<br />PROM(programmable read only memory) 可编只读程存储器<br />PRT(platinum resistance thermometer) 铂电阻温度计<br />PRT(pulse recurrent time) 脉冲周期时间<br />PUT(programmable unijunction transistor) 可编程单结晶体管<br />PWM(pulse width modulation) 脉宽调制<br />R(resistance,resistor) 电阻,电阻器<br />RAM(random access memory) 随机存储器<br />RCT(reverse conducting thyristor) 逆导晶闸管<br />REF(reference) 参考,基准<br />REV(reverse) 反转<br />R/F(radio frequency) 射频<br />RGB(red/green/blue) 红绿蓝<br />ROM(read only memory) 只读存储器<br />RP(resistance potentiometer) 电位器<br />RST(reset) 复位信号<br />RT(resistor with inherent variability dependent) 热敏电阻<br />RTD(resistance temperature detector) 电阻温度传感器<br />RTL(resistor transistor logic) 电阻晶体管逻辑(电路)<br />RV(resistor with inherent variability dependent on the voltage) 压敏电阻器<br />SA(switching assembly) 开关组件<br />SBS(silicon bi-directional switch) 硅双向开关,双向硅开关<br />SCR(silicon controlled rectifier) 可控硅整流器<br />SCS(safety control switch) 安全控制开关<br />SCS(silicon controlled switch) 可控硅开关<br />SCS(speed control system) 速度控制系统<br />SCS(supply control system) 电源控制系统<br />SG(spark gap) 放电器<br />SIT(static induction transformer) 静电感应晶体管<br />SITH(static induction thyristor) 静电感应晶闸管<br />SP(shift pulse) 移位脉冲<br />SPI(serial peripheral interface) 串行外围接口<br />SR(sample realy,saturable reactor) 取样继电器,饱和电抗器<br />SR(silicon rectifier) 硅整流器<br />SRAM(static random access memory) 静态随机存储器<br />SSR(solid-state relay) 固体继电器<br />SSR(switching select repeater) 中断器开关选择器<br />SSS(silicon symmetrical switch) 硅对称开关,双向可控硅<br />SSW(synchro-switch) 同步开关<br />ST(start) 启动<br />ST(starter) 启动器<br />STB(strobe) 闸门,选通脉冲<br />T(transistor) 晶体管,晶闸管<br />TACH(tachometer) 转速计,转速表<br />TP(temperature probe) 温度传感器<br />TRIAC(triodes AC switch) 三极管交流开关<br />TTL(transistor-transistor logic) 晶体管一晶体管逻辑<br />TV(television) 电视<br />UART(universal asynchronous receiver transmitter) 通用异步收发器<br />VCO(voltage controlled oscillator) 压控振荡器<br />VD(video decoders) 视频译码器<br />VDR(voltage dependent resistor) 压敏电阻<br />VF(video frequency) 视频<br />V/F(voltage-to-frequency) 电压/频率转换<br />V/I(voltage to current convertor) 电压-电流变换器<br />VM(voltmeter) 电压表<br />VS(vacuum switch) 电子开关<br />VT(visual telephone) 电视电话<br />VT(video terminal) 视频终端 |
